QLIR05FYAM
QLIR05FYAM
    QUELIGHTING
    4-PLCC
    红外(IR) 发射器 1300nm 1.5V 100mA 2mW/sr @ 100mA 4-PLCC
QLIR05FYAM 数据手册
QLIR05FYAM PLCC4 1300nm QLIR05FYAM V1.0 Product Outline: This is PLCC-4 series with high output reflector type 3528 LEDs are available in Infrared Emitter. With special binning technology, Quelighting is able to provide special binning for customer’s needs Features: • • • • • High brightness output @ 100mA Package Dimension = 3.5mmX2.8mmX1.9mm PLCC-4 1300nm LED RoHS compliant Custom Bin available upon special request Application: • • • • • Mechanically and spectrally matched to the phototransistor Infrared Illumination for cameras Sensor technology Gesture Recognition Surveillance Compliance and Certification: 1 QLIR05FYAM V1.0 Mechanical Property: (Dimension) Units: mm Recommended Solder footprint: Units: mm 2 QLIR05FYAM V1.0 Electrical / Optical Characteristic (T=25 oC) λp (nm) VF(V) Product Color QLIR05FYAM Iv(mW) IF(mA) Infrared 100 Typ. max 1.5 2.0 Min. Typ. Max. 1300 min typ. 2 3 (1) The Forward Voltage tolerance is ±0.1V (2) The λD tolerance is ±1nm (3) The Iv tolerance is ± 7% Absolute Maximum Rating (T=25 oC) Part # Pd (mW) IF (mA) IFP (mA)* VR (V) TOP (oC) TST (oC) TSOL (oC)** Infrared 200 100 100 5 -40 – 85 -40 - 100 260 *Duty 1/10 @ 10Khz ** Junction Temperature *** IR Reflow for no more than 10 sec @ 260 oC **** Thermal resistance is calculated from junction to solder Forward Voltage (VF) Bin: VF rank @ 100mA Code name Min. Max. Unit L6 1.4 2.0 V The forward voltage tolerance is ± 0.1V Radiant Intensity Bin: Po (mW/sr) rank @ 100mA Code name Min. Max. Unit P00022 2 4 mW luminous intensity tolerance is ± 7% 3 QLIR05FYAM V1.0 Characteristic Curves Forward Voltage vs. Forward Current Forward current vs. Relative luminous intensity Radiation Pattern 4 QLIR05FYAM V1.0 Spectrum Distribution Relative Luminous Intensity vs Ambient Temperature 5 QLIR05FYAM V1.0 Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): - When soldering LEDs, - Do not solder/reflow the same LED over two times. - Recommend soldering conditions: Hand soldering: 300 ℃ max , 3 sec. max. Reflow soldering: Pre-heat 150 max , 180 sec. max. ℃ Peak Temp. 260 C Max 10 Sec Max. 260 Temperature ( C) - Peak 260 ma ℃ x , 5 sec. max. Reflow temperature profile as below: (lead-free solder) 220 200 Gradual Cooling 160 Preheat Zone Soldering Zone Time 90 ~ 220 Sec 60 Sec Max. 6 QLIR05FYAM V1.0 Taping & Packing: Unit : mm 7 QLIR05FYAM V1.0 8 QLIR05FYAM V1.0 Labeling Ordering Information: Part # QLIR05FYAM Multiple Quantities Quantity per Reel 1000pcs, 2000 pcs 9 QLIR05FYAM V1.0 Revision History: Revision Date: 08-05-2020 Changes: Initial release Version #: 1.0 10
QLIR05FYAM 价格&库存
很抱歉,暂时无法提供与“QLIR05FYAM”相匹配的价格&库存,您可以联系我们找货
QLIR05FYAM
  • 1+29.492991+3.81369
  • 10+21.5377910+2.78502
  • 100+16.80866100+2.17350
  • 500+14.73189500+1.90496
库存:172
QLIR05FYAM
    • 1+27.22680
    • 200+10.86480
    • 500+10.49760
    • 1000+10.32480
    QLIR05FYAM
    • 1000+14.055751000+1.81753
    • 2000+13.483462000+1.74352
    • 3000+13.190383000+1.70563
    • 5000+12.859955000+1.66290
    库存:172
