QLSP04BU
QLSP04BU
    QUELIGHTING
    SMD3030_2P
    发光二极管/LED 蓝色 SMD3030_2P 473nm
QLSP04BU 数据手册
QLSP04BU (High Power color 3030 LEDs) QLSP04BU Color LED V1.1 Product Outline: This is the high power LED with reflector type. EMC 3030 Single color is a surface-mount LED which with heat sink to enhance operating performance. With special binning technology, these LEDs are ideal for architecture lighting and special lighting needs. Features: • • • • • • • Blue Color High brightness output @ 350mA, High driving current to 1000mA Package Dimension = 3.2mmX3.0mmX0.6mm ESD protection up to 8KV RoHS compliant Custom Bin available upon special request Application: • • • • Warning lamp Decoration lamp Architecture Lighting Garden Lighting Compliance and Certification: 1 QLSP04BU Color LED V1.1 Mechanical Property: (Dimension) * All dimensions are in millimeters, * Tolerances are ± 0.10mm. Recommended Solder footprint: * All dimensions are in millimeters. * The LEDs is designed to be reflow soldered on to a PCB. IF dip soldered that QL cannot guarantee its reliability. * Reflow soldering must not be performed more than twice. 2 QLSP04BU Color LED V1.1 Characteristics ◼ Absolute Maximum Ratings (Ta=25℃) Parameter Symbol Rating Unit DC Forward Current If 1000 mA Leakage Current Ir 1.0 μA Power Dissipation Pd 3.3 W Pulse Forward Current Ifp 1000 mA LED Junction Temperature TJ 125 ℃ Storage Temperature Tstg -40 ~ 100 ℃ Operation Temperature Topr -40 ~ 85 ℃ Soldering Temperature Tsol 260 < 10 sec ℃ 8 KV 10 ℃W (Color for Royal Blue and Blue) ESD Sensitivity(HBM) Thermal Resistance Rth (1) Proper current rating must be observed to maintain junction temperature below maximum at all time (2) IFP Condition: Duty 1/10, Pulse within 10msec ◼ Electrical / Optical Characteristic VF(V) Product QLSP04BU Color Blue (Ta=25 oC) Wavelength IF(mA) 350 Luminous Flux(lm)/mW Typ. max nm min typ. 3.2 3.5 465~480 26 33.6 Refer @ 700mA Typ.(lm)/mW 56 3 QLSP04BU Color LED V1.1 ◼ Groups Dominant Wavelength Wd (nm) Color Blue Code name Min. Max. DD 465 470 DE 470 475 DF 475 480 Code name Low High 01 2.8 3.0 23 3.0 3.2 45 3.2 3.4 67 3.4 3.6 Measurement tolerance is +/- 1nm Forward Voltage (VF) Bin: VF Rank Color Blue The forward voltage tolerance is ± 0.1V Luminous Flux Bin: Rank @350mA (lm) Color Blue Code name Low High QJ9 20 30 QN9 30 40 QP9 40 50 luminous flux tolerance is ± 7% 4 QLSP04BU Color LED V1.1 Characteristic Curves (1) Color Spectrum (2). Typical Representative Spatial Radiation Pattern 5 QLSP04BU Color LED V1.1 (3). Forward Current Characteristics (4). Forward Current vs Forward Voltage 6 QLSP04BU Color LED V1.1 ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 1000 Hrs 20 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 1000 Hrs 20 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 1000 Hrs 20 pcs 4 Steady State Operating Life of Low Temperature 85℃ 85℃ Operating 1000 Hrs 20 pcs 5 Low temperature storage -40℃ -40℃ Storage 1000 Hrs 20 pcs 6 High temperature storage 100℃ 100℃ Storage 1000 Hrs 20 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 1000 Hrs 20 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 200 Cycle 20 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 20 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 20 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 300 Cycle 20 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Test Condition Judgment Criteria Forward Voltage Vf 350 mA △Vf< 10% Luminous Flux Iv 350 mA △Iv< 30% 7 QLSP04BU Color LED V1.1 Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): 8 QLSP04BU Color LED V1.1 Taping & Packing: Unit : mm 9 QLSP04BU Color LED V1.1 10 QLSP04BU Color LED V1.1 Labeling Ordering Information: Part # QLSP04BU Multiple Quantities Quantity per Reel 10000,2000 pcs 11 QLSP04BU Color LED V1.1 Revision History: Revision Date: Changes: Version #: 03-30-2017 Initial release 1.0 08-01-2018 Add color on Royal Blue, Cyan Green, Deep Red, Cherry Red 1.1 12
QLSP04BU
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款用于红外遥控系统的接收器,具有高灵敏度和低功耗特性。
3. 引脚分配:EL817共有3个引脚,分别为VCC、GND和OUT。
4. 参数特性:工作电压范围为2.5V至5.5V,工作电流为1.5mA,接收频率为38kHz。
5. 功能详解:EL817能够接收红外信号并输出相应的电信号,用于控制各种电子设备。
6. 应用信息:广泛应用于电视、空调、音响等家用电器的遥控操作。
7. 封装信息:EL817采用SOP-8封装形式。
QLSP04BU 价格&库存
很抱歉,暂时无法提供与“QLSP04BU”相匹配的价格&库存,您可以联系我们找货
