QLSP04RBH
QLSP04RBH
    QUELIGHTING
    SMD3030_2P
    发光二极管/LED 蓝色 SMD3030_2P 454nm
QLSP04RBH 数据手册
QLSP04RBH (Color 3030 LEDs) QLSP04RBH V1.0 Product Outline: This is the high efficiency LED with reflector type. EMC 3030 Single color is a surfacemount LED which with heat sink to enhance operating performance. With special binning technology, these LEDs are ideal for architecture lighting and special lighting needs. Features: • • • • • • Royal Blue color High brightness output @ 150mA, High driving current to 200mA. Package Dimension = 3.2mmX3.0mmX0.6mm RoHS compliant Custom Bin available upon special request Application: • • • • • Warning lamp Decoration lamp Architecture Lighting Garden Lighting Horticulture Lighting Compliance and Certification: 1 QLSP04RBH V1.0 Mechanical Property: (Dimension) * All dimensions are in millimeters, * Tolerances are ± 0.10mm. Recommended Solder footprint: * All dimensions are in millimeters. * The LEDs is designed to be reflow soldered on to a PCB. IF dip soldered that QL cannot guarantee its reliability. * Reflow soldering must not be performed more than twice. 2 QLSP04RBH V1.0 Characteristics ◼ Absolute Maximum Ratings (Ta=25℃) Parameter Symbol Rating Unit DC Forward Current If 200 mA Leakage Current Ir 1.0 μA Power Dissipation Pd 0.6 W Pulse Forward Current Ifp 240 mA LED Junction Temperature TJ 125 ℃ Storage Temperature Tstg -40 ~ 100 ℃ Operation Temperature Topr -40 ~ 85 ℃ Soldering Temperature Tsol 260 < 10 sec ℃ 8 KV 10 ℃W ESD Sensitivity(HBM) Thermal Resistance Rth (1) Proper current rating must be observed to maintain junction temperature below maximum at all time (2) IFP Condition: Duty 1/10, Pulse within 10msec ◼ Electrical / Optical Characteristic VF(V) Product QLSP04RBH Color Royal Blue (Ta=25 oC) Wavelength IF(mA) 150 Typ. max nm 3.0 3.5 447.5~460 Brightness (lm/mW) min typ. 250 mW 3 QLSP04RBH V1.0 Radiometric Power Bin Structure at 150mA Radiometric Power (mW) Product PPF (μmol/s) Color QLSP04RBH min. max. min. max. 240 280 0.93 1.04 Royal Blue PPF/W (μmol/J) Typ. 2.4 ◼ Groups Dominant Wavelength Wd (nm) @ 150mA Color Royal Blue Code name Min. Max. DA 450 455 DB 455 460 Measurement tolerance is +/- 1nm Forward Voltage (VF) Bin: VF Rank @ 150mA (Vf) Color Royal Blue Code name Low High 01 2.8 3.0 23 3.0 3.2 45 3.2 3.4 67 3.4 3.6 The forward voltage tolerance is ± 0.1V Luminous Flux Bin: luminous flux tolerance is ± 7% Rank @ 150mA (mW) Color Code name Low High Royal Blue MN1 240 280 luminous flux tolerance is ± 7% 4 QLSP04RBH V1.0 Characteristic Curves (1) Color Spectrum 5 QLSP04RBH V1.0 (2). Typical Representative Spatial Radiation Pattern (3). Forward Current Characteristics 6 QLSP04RBH V1.0 (4). Forward Current vs Forward Voltage 7 QLSP04RBH V1.0 ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 1000 Hrs 20 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 1000 Hrs 20 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 1000 Hrs 20 pcs 4 Steady State Operating Life of Low Temperature 85℃ 85℃ Operating 1000 Hrs 20 pcs 5 Low temperature storage -40℃ -40℃ Storage 1000 Hrs 20 pcs 6 High temperature storage 100℃ 100℃ Storage 1000 Hrs 20 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 1000 Hrs 20 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 200 Cycle 20 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 20 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 20 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 300 Cycle 20 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Test Condition Judgment Criteria Forward Voltage Vf 150 mA △Vf< 10% Luminous Flux Iv 150 mA △Iv< 30% 8 QLSP04RBH V1.0 Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): 9 QLSP04RBH V1.0 Taping & Packing: Unit : mm 10 QLSP04RBH V1.0 11 QLSP04RBH V1.0 Labeling Ordering Information: Part # QLSP04RBH Multiple Quantities Quantity per Reel 1000, 2000 pcs 12 QLSP04RBH V1.0 Revision History: Revision Date: 09-21-2020 Changes: Initial release Version #: 1.0 13
QLSP04RBH 价格&库存
很抱歉,暂时无法提供与“QLSP04RBH”相匹配的价格&库存,您可以联系我们找货
