QLSP04RU
(High Power color 3030 LEDs)
QLSP04RU Color LED V1.1
Product Outline:
This is the high power LED with reflector type. EMC 3030 Single color is a surface-mount
LED which with heat sink to enhance operating performance. With special binning
technology, these LEDs are ideal for architecture lighting and special lighting needs.
Features:
Red Color
High brightness output @ 350mA,
High driving current to 700mA
Package Dimension = 3.2mmX3.0mmX0.6mm
ESD protection up to 8KV
RoHS compliant
Custom Bin available upon special request
Application:
Warning lamp
Decoration lamp
Architecture Lighting
Garden Lighting
Compliance and Certification:
1
Mechanical Property:
(Dimension)
* All dimensions are in millimeters,
* Tolerances are ± 0.10mm.
Recommended Solder footprint:
* All dimensions are in millimeters.
* The LEDs is designed to be reflow soldered on to a PCB. IF dip soldered that QL cannot guarantee its
reliability.
* Reflow soldering must not be performed more than twice.
2
Characteristics
◼ Absolute Maximum Ratings
(Ta=25℃)
Parameter
Symbol
Rating
Unit
DC Forward Current
If
700
mA
Leakage Current
Ir
1.0
μA
Power Dissipation
Pd
2.3
W
Pulse Forward Current
Ifp
1000
mA
LED Junction Temperature
TJ
125
Storage Temperature
Tstg
-40 ~ 100
Operation Temperature
Topr
-40 ~ 85
Soldering Temperature
Tsol
260 < 10 sec
8
KV
10
℃W
ESD Sensitivity(HBM)
Thermal Resistance
Rth
(1) Proper current rating must be observed to maintain junction temperature below maximum at all time
(2) IFP Condition: Duty 1/10, Pulse within 10msec
Electrical / Optical Characteristic
VF(V)
Product
QLSP04RU
Color
Red
(Ta=25 oC)
Wavelength
IF(mA)
350
Luminous
Flux(lm)/mW
Typ.
max
nm
min
typ.
2.4
2.6
615~630
40
44
Refer @ 700mA
Typ.(lm)/mW
76
3
◼ Groups
Dominant Wavelength
Wd (nm)
Color
Red
Code name
Min.
Max.
A7
615
620
A8
620
625
A9
625
630
Code name
Low
High
PQ
1.8
2.0
RS
2.0
2.2
TU
2.2
2.4
VW
2.4
2.6
Measurement tolerance is +/- 1nm
Forward Voltage (VF) Bin:
VF Rank
Color
Red
The forward voltage tolerance is ± 0.1V
Luminous Flux Bin:
Rank @350mA (lm)
Color
Red
Code name
Low
High
QP9
40
50
QR9
50
60
luminous flux tolerance is ± 7%
4
Characteristic Curves
(1) Color Spectrum
(2). Typical Representative Spatial Radiation Pattern
5
(3). Forward Current Characteristics
(4). Forward Current vs Forward Voltage
6
◼ Reliability test:
No
Item
Condition
Time/Cycle
Sample
size
1
Steady State Operating Life of Room
Temperature
25℃ Operating
1000 Hrs
20 pcs
2
Steady State Operating Life of Low
Temperature -40℃
-40℃ Operating
1000 Hrs
20 pcs
3
Temperature 60℃
60℃ Operating
1000 Hrs
20 pcs
4
Temperature 85℃
85℃ Operating
1000 Hrs
20 pcs
5
Low temperature storage -40℃
-40℃ Storage
1000 Hrs
20 pcs
6
High temperature storage 100℃
100℃ Storage
1000 Hrs
20 pcs
7
Steady State Operating Life of High
Humidity Heat 60℃90%
60oC/90% Operating
1000 Hrs
20 pcs
8
Steady State
Condition
25℃10Hz duty=1/10 Operating
200 Cycle
20 pcs
9
Resistance to soldering heat on PCB
(JEDEC MSL3)
pre-store@60℃, 60%RH for
52hrs Tsld max.=260 10sec
3 Times
20 pcs
10
Heat Cycle Test (JEDEC MRC)
25℃~65℃~-10℃, 90%RH,
24hr/1cycle
10 Cycle
20 pcs
11
Thermal shock
-40℃/ 20minr~ 5minr~100℃
/20min
300 Cycle
20 pcs
Pulse Operating Life
◼ Judgment Criteria:
Item
Symbol
Test Condition
Judgment
Criteria
Forward Voltage
Vf
350 mA
△Vf< 10%
Luminous Flux
Iv
350 mA
△Iv< 30%
7
Solder Profile:
-The recommended reflow soldering profile is as follows (temperatures indicated are as
measured on the surface of the LED resin):
8
Taping & Packing:
Unit : mm
9
10
Labeling
Ordering Information:
Part #
QLSP04RU
Multiple Quantities
Quantity per Reel
1000, 2000 pcs
11
Revision History:
Revision Date:
Changes:
Version #:
03-30-2017
Initial release
1.0
08-01-2018
Add color on Royal Blue, Cyan Green, Deep Red,
Cherry Red
1.1
12
很抱歉,暂时无法提供与“QLSP04RU”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.72840
- 200+2.68920
- 500+2.60280
- 1000+2.55960
