QLSP05PCAG
QLSP05PCAG
    QUELIGHTING
    PLCC-6
    发光二极管/LED 琥珀色 PLCC-6 SMT
QLSP05PCAG 数据手册
QLSP05PCAG (3528 PLCC 6 LED) QLSP05PCAG PLCC 6 Series V1.0 Product Outline: This is the small TOP LED with reflector type with single color led. This special package is ideal for customer’s application in traffic signal and sign boards. With special binning technology, Quelighting is able to provide special binning for customer’s needs Features: • • • • • • • • • PC Amber color High brightness output @ 140mA, High driving current to 250mA. Package Dimension = 3.4mmX3.3mmX1.9mm MSL level 2 RoHS compliant Custom Bin available upon special request View angel >110° AEC-Q101 Application: • • • • • Architecture Lighting Sign board backlighting Emergency vehicle lighting Traffic signal lighting Automotive lighting Compliance and Certification: 1 QLSP05PCAG PLCC 6 Series V1.0 Mechanical Property: (Dimension) * All dimensions are in millimeters, * Tolerances are ± 0.10mm. Recommended Solder footprint: * All dimensions are in millimeters. * The LEDs is designed to be reflow soldered on to a PCB. IF dip soldered that QL cannot guarantee its reliability. * Reflow soldering must not be performed more than twice. 2 QLSP05PCAG PLCC 6 Series V1.0 Characteristics ◼ Absolute Maximum Ratings (Ta=25℃) Parameter Symbol Rating Unit DC Forward Current If 250 mA Power Dissipation Pd 0.82 W Pulse Forward Current Ifp 400 mA Storage Temperature Tstg -40 ~ 105 ℃ Operation Temperature Topr -40 ~ 105 ℃ Soldering Temperature Tsol 260 < 10 sec ℃ ESD (HBM) ESD(HBM) 8000 V (1) Proper current rating must be observed to maintain junction temperature below maximum at all time (2) IFP Condition: Duty 1/10, Pulse within 10msec ◼ Electrical / Optical Characteristic Parameter Symbol Condition Forward Voltage Vf (Ta=25 oC) Min. Typ. 2.7 Max. Unit 3.3 V 50mA θ View Angle 120 deg (1) Tolerance of measurement: VF=+/- 0.1V ◼ Specification Product Color Vf(V) IF=50mA QLSP05PCAD PC Amber 3.0 Luminous intensity Color IF=50mA (lm) Temperature (K) Min. Typ. - 10 13.5 *Tolerance = +/- 10% 3 QLSP05PCAG PLCC 6 Series V1.0 ◼ Groups Dominate Wavelength (nm) Bin: Tolerance of measurements of the Chromaticity Coordinate is ±0.005. Forward Voltage (VF) Bin: VF Rank (V) @ 140mA Color PC Amber Condition Code name Low High A 3.0 3.2 B 3.2 3.4 C 3.4 3.6 unit V The forward voltage tolerance is ± 0.1V Luminous Intensity Bin: Intensity Rank (lm) @ 140mA Code name Min. Max. Units A6 20.1 23.1 lm 4 QLSP05PCAG PLCC 6 Series V1.0 A7 23.1 26.6 A8 26.6 30.6 A9 30.6 35.2 Luminous intensity tolerance is ± 8% ◼ Characteristic Curves (1) Color Spectrum (2). Typical Representative Spatial Radiation Pattern 5 QLSP05PCAG PLCC 6 Series V1.0 (3). Forward Current Characteristics (4). Forward Current vs Forward Voltage 6 QLSP05PCAG PLCC 6 Series V1.0 ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 1000 Hrs 20 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 1000 Hrs 20 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 1000 Hrs 20 pcs 4 Steady State Operating Life of Low Temperature 85℃ 85℃ Operating 1000 Hrs 20 pcs 5 Low temperature storage -40℃ -40℃ Storage 1000 Hrs 20 pcs 6 High temperature storage 100℃ 100℃ Storage 1000 Hrs 20 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 1000 Hrs 20 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 200 Cycle 20 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 20 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 20 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 300 Cycle 20 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Test Condition Judgment Criteria Forward Voltage Vf 140 mA △Vf< 10% Luminous Flux Iv 140 mA △Iv< 30% 7 QLSP05PCAG PLCC 6 Series V1.0 ◼ Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): 8 QLSP05PCAG PLCC 6 Series V1.0 ◼ Taping & Packing: 9 QLSP05PCAG PLCC 6 Series V1.0 10 QLSP05PCAG PLCC 6 Series V1.0 ◼ Labeling ◼ Ordering Information: Part # QLSP05PCAG Multiple Quantities Quantity per Reel 500,1000,2000 pcs 11 QLSP05PCAG PLCC 6 Series V1.0 ◼ Revision History: Revision Date: 07-04-2021 Changes: Initial release Version #: 1.0 12
QLSP05PCAG 价格&库存
很抱歉,暂时无法提供与“QLSP05PCAG”相匹配的价格&库存,您可以联系我们找货
