QLSP05RD
QLSP05RD
    QUELIGHTING
    PLCC-4
    发光二极管/LED 红色 PLCC-4 618nm 2750mcd SMT
QLSP05RD 数据手册
QLSP05RD (3528 PLCC 4 LED) QLSP05RD PLCC 4 V1.0 Product Outline: This is the small TOP LED with reflector type with single color led. This special package is ideal for customer’s application in traffic signal and sign boards. With special binning technology, Quelighting is able to provide special binning for customer’s needs Features: • • • • • • • • • Red color LED High brightness output @ 50mA, High driving current to 70mA. Package Dimension = 3.5mmX2.8mmX1.9mm MSL level 2 RoHS compliant Custom Bin available upon special request View angel >110° AEC-Q101 Application: • • • • • Architecture Lighting Sign board backlighting Emergency vehicle lighting Traffic signal lighting Automotive lighting Compliance and Certification: 1 QLSP05RD PLCC 4 V1.0 Mechanical Property: (Dimension) * All dimensions are in millimeters, * Tolerances are ± 0.10mm. Recommended Solder footprint: * All dimensions are in millimeters. * The LEDs is designed to be reflow soldered on to a PCB. IF dip soldered that QL cannot guarantee its reliability. * Reflow soldering must not be performed more than twice. 2 QLSP05RD PLCC 4 V1.0 Characteristics ◼ Absolute Maximum Ratings (Ta=25℃) Parameter Symbol Rating Unit DC Forward Current If 70 mA Power Dissipation Pd 0.12 W Pulse Forward Current Ifp 100 mA Storage Temperature Tstg -40 ~ 105 ℃ Operation Temperature Topr -30 ~ 105 ℃ Soldering Temperature Tsol 260 < 10 sec ℃ ESD (HBM) ESD(HBM) 2000 V (1) Proper current rating must be observed to maintain junction temperature below maximum at all time (2) IFP Condition: Duty 1/10, Pulse within 10msec ◼ Electrical / Optical Characteristic Parameter Symbol Condition Forward Voltage Vf (Ta=25 oC) Min. Typ. 1.9 Max. Unit 2.65 V 50mA θ View Angle 120 deg (1) Tolerance of measurement: VF=+/- 0.1V ◼ Specification Product QLSP05RD Color Red Vf(V) IF=50mA Dominant Wavelength (nm) 2.2 612~635 Luminous intensity IF=50mA (mcd) Min. Typ. 1400 2750 *Tolerance = +/- 10% 3 QLSP05RD PLCC 4 V1.0 ◼ Groups Dominate Wavelength (nm) Bin: Wd Rank (nm) @ 50mA Color Red Condition Code name Low High A1000 612 616 A2000 616 620 A3000 620 624 A4000 624 630 A5000 630 635 Unit nm Measurement tolerance is +/- 1nm Forward Voltage (VF) Bin: VF Rank (V) @ 50mA Color Red Condition Code name Low High A 1.9 2.05 B 2.05 2.2 C 2.2 2.35 D 2.35 2.5 E 2.5 2.65 unit V The forward voltage tolerance is ± 0.1V Luminous Intensity Bin: Intensity Rank (mcd) @ 50mA Code name Min. Max. S1 1400 1800 S2 1800 2240 S3 2240 2800 S4 2800 3550 Units mcd Luminous intensity tolerance is ± 7% 4 QLSP05RD PLCC 4 V1.0 ◼ Characteristic Curves (1) Color Spectrum (2). Typical Representative Spatial Radiation Pattern 5 QLSP05RD PLCC 4 V1.0 (3). Forward Current Characteristics (4). Forward Current vs Forward Voltage 6 QLSP05RD PLCC 4 V1.0 ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 1000 Hrs 20 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 1000 Hrs 20 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 1000 Hrs 20 pcs 4 Steady State Operating Life of Low Temperature 85℃ 85℃ Operating 1000 Hrs 20 pcs 5 Low temperature storage -40℃ -40℃ Storage 1000 Hrs 20 pcs 6 High temperature storage 100℃ 100℃ Storage 1000 Hrs 20 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 1000 Hrs 20 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 200 Cycle 20 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 20 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 20 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 300 Cycle 20 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Test Condition Judgment Criteria Forward Voltage Vf 20 mA △Vf< 10% Luminous Flux Iv 20 mA △Iv< 30% 7 QLSP05RD PLCC 4 V1.0 ◼ Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): 8 QLSP05RD PLCC 4 V1.0 ◼ Taping & Packing: Unit : mm 9 QLSP05RD PLCC 4 V1.0 10 QLSP05RD PLCC 4 V1.0 ◼ Labeling ◼ Ordering Information: Part # QLSP05RD PLCC 4 Multiple Quantities Quantity per Reel 500, 1000, 2000 pcs 11 QLSP05RD PLCC 4 V1.0 ◼ Revision History: Revision Date: 07-04-2020 Changes: Initial release Version #: 1.0 12
QLSP05RD 价格&库存
很抱歉,暂时无法提供与“QLSP05RD”相匹配的价格&库存,您可以联系我们找货
