QLSP05W
QLSP05W
    QUELIGHTING
    SMD3528_2P
    发光二极管/LED 白色 SMD3528_2P
QLSP05W 数据手册
QLSP05W (3528 PLCC 2 LED) QLSP05W PLCC 2 Series V1.0 Product Outline: This is the small TOP LED with reflector type with single color led. This special package is ideal for customer’s application in traffic signal and sign boards. With special binning technology, Quelighting is able to provide special binning for customer’s needs Features: • • • • • • • • • White color LED High brightness output @ 20mA, High driving current to 30mA. Package Dimension = 3.5mmX2.7mmX1.8mm MSL level 2 RoHS compliant Custom Bin available upon special request View angel >110° AEC-Q101 Application: • • • • • Architecture Lighting Sign board backlighting Emergency vehicle lighting Traffic signal lighting Automotive lighting Compliance and Certification: 1 QLSP05W PLCC 2 Series V1.0 Mechanical Property: (Dimension) * All dimensions are in millimeters, * Tolerances are ± 0.10mm. Recommended Solder footprint: * All dimensions are in millimeters. * The LEDs is designed to be reflow soldered on to a PCB. IF dip soldered that QL cannot guarantee its reliability. * Reflow soldering must not be performed more than twice. 2 QLSP05W PLCC 2 Series V1.0 Characteristics ◼ Absolute Maximum Ratings (Ta=25℃) Parameter Symbol Rating Unit DC Forward Current If 30 mA Power Dissipation Pd 0.06 W Pulse Forward Current Ifp 50 mA Storage Temperature Tstg -40 ~ 105 ℃ Operation Temperature Topr -40 ~ 105 ℃ Soldering Temperature Tsol 260 < 10 sec ℃ ESD (HBM) ESD(HBM) 8000 V (1) Proper current rating must be observed to maintain junction temperature below maximum at all time (2) IFP Condition: Duty 1/10, Pulse within 10msec ◼ Electrical / Optical Characteristic Parameter Symbol Condition Forward Voltage Vf (Ta=25 oC) Min. Typ. 2.8 Max. Unit 3.4 V 20mA θ View Angle 120 deg (1) Tolerance of measurement: VF=+/- 0.1V ◼ Specification Product Color Vf(V) IF=20mA QLSP05W White 3.2 Luminous intensity Color IF=20mA (mcd) Temperature (K) Min. Typ. 4000K~6500K 1120 2000 *Tolerance = +/- 10% 3 QLSP05W PLCC 2 Series V1.0 ◼ Groups Dominate Wavelength (nm) Bin: Tolerance of measurements of the Chromaticity Coordinate is ±0.005. Forward Voltage (VF) Bin: VF Rank (V) @ 20mA Color White Condition Code name Low High A 2.8 3.0 B 3.0 3.2 C 3.2 3.4 unit V The forward voltage tolerance is ± 0.1V Luminous Intensity Bin: Intensity Rank (mcd) @ 20mA Code name Min. Max. AA 1120 1400 AB 1400 1800 BA 1800 2240 BB 2240 2280 Units mcd Luminous intensity tolerance is ± 8% 4 QLSP05W PLCC 2 Series V1.0 ◼ Characteristic Curves (1) Color Spectrum (2). Typical Representative Spatial Radiation Pattern 5 QLSP05W PLCC 2 Series V1.0 (3). Forward Current Characteristics (4). Forward Current vs Forward Voltage 6 QLSP05W PLCC 2 Series V1.0 ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 1000 Hrs 20 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 1000 Hrs 20 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 1000 Hrs 20 pcs 4 Steady State Operating Life of Low Temperature 85℃ 85℃ Operating 1000 Hrs 20 pcs 5 Low temperature storage -40℃ -40℃ Storage 1000 Hrs 20 pcs 6 High temperature storage 100℃ 100℃ Storage 1000 Hrs 20 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 1000 Hrs 20 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 200 Cycle 20 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 20 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 20 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 300 Cycle 20 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Test Condition Judgment Criteria Forward Voltage Vf 20 mA △Vf< 10% Luminous Flux Iv 20 mA △Iv< 30% 7 QLSP05W PLCC 2 Series V1.0 ◼ Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): 8 QLSP05W PLCC 2 Series V1.0 ◼ Taping & Packing: Unit : mm 9 QLSP05W PLCC 2 Series V1.0 10 QLSP05W PLCC 2 Series V1.0 ◼ Labeling ◼ Ordering Information: Part # QLSP05W Multiple Quantities Quantity per Reel 1000,2000 pcs 11 QLSP05W PLCC 2 Series V1.0 ◼ Revision History: Revision Date: 07-04-2020 Changes: Initial release Version #: 1.0 12
QLSP05W 价格&库存
很抱歉,暂时无法提供与“QLSP05W”相匹配的价格&库存,您可以联系我们找货
