QLSP05WCWW
QLSP05WCWW
    QUELIGHTING
    PLCC-4
    发光二极管/LED 白色,暖色/白色,冷色 PLCC-4 SMT
QLSP05WCWW 数据手册
QLSP05WCWW QLSP05WCWW ◼ Product Outline: This high output reflector type 2835S LEDs are available in Dual white color ( cold white and Warm white ) to suit customer’s application. These 0.5W LEDs are equipped with heat sink to enhance operating performance. With special binning technology, these LEDs are ideal for architecture lighting and special lighting needs. ◼ Features: • • • • • High brightness output @ 20mA Max. current @ 60mA Package Dimension = 3.8mmX2.8mmX0.65mm RoHS compliant Custom Bin available upon special request ◼ Application: • • • • Architecture Lighting Tube Lighting Interior Lighting General Lighting Compliance and Certification: 1 www.quelighting.com QLSP05WCWW ◼ Mechanical Property: (Dimension) Unit: mm Recommended Solder footprint: 2 QLSP05WCWW ◼ Electrical / Optical Characteristic Parameter Symbol Forward voltage(1) Vf Color Rendering Index(2) Ra Condition Min. Typ. Max. Unit 2.8 - 3.4 V 70 - - - If=20mA View angle θ - 120 - Deg Thermal Resistance(3) Rth - 25 - ℃/W (1) The forward voltage tolerance is ± 0.1V (2) The Color Rendering Index tolerance is ± 2 ◼ Performance at Commonly Used Drive Currents Product Color Color range (CCT) QLSP05WCWW QLSP05WCWW Warm white Cold white 2800-3200 6000-6500 Drive Current1 (mA) Typical Vf Tsp = 25°C (V) Viewing Angle (Degree) Typical Pulsed Flux2 Tsp = 25°C (lm) 20 20 3.2 3.2 120 120 23 23 ◼ Absolute Maximum Rating (T=25 oC) Part # Pd (mW) IF (mA) IFP (mA)* VR (V) TOP (oC) TST (oC) TSOL (oC)** QLS05WCWW 200 60 100 5 -40 – 85 -40 - 85 260 *Duty 1/10 @ 10Khz ** IR Reflow for no more than 10 sec @ 250 oC 3 QLSP05WCWW ◼ Binning Luminous Flux Bin: lm rank (lm) @ 20mA Code name Low High QJ 20 22.5 QK 22.5 25 QL 25 28 Unit lm The luminous flux tolerance is ± 10% Forward Voltage (VF) Bin: VF rank @ 20mA Code name Low High 2 3 3.1 3 3.1 3.2 4 3.2 3.3 5 3.3 3.4 6 3.0 3.4 Unit V The forward voltage tolerance is ± 0.1V 4 QLSP05WCWW Color Bin (CCT) : lm rank (lm) @ 20mA Code name Low High WW 2800 3200 WC 6000 6500 Unit CCT 5 QLSP05WCWW ◼ Characteristic Curves Forward Voltage vs. Forward Current Forward current vs. Relative luminous intensity Ambient Temp VS Forward Current Spectrum Distribution 6 QLSP05WCWW Radiation Pattern 7 QLSP05WCWW ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 1000 Hrs 20 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 1000 Hrs 20 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 1000 Hrs 20 pcs 4 Steady State Operating Life of Low Temperature 85℃ 85℃ Operating 1000 Hrs 20 pcs 5 Low temperature storage -40℃ -40℃ Storage 1000 Hrs 20 pcs 6 High temperature storage 100℃ 100℃ Storage 1000 Hrs 20 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 1000 Hrs 20 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 200 Cycle 20 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 20 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 20 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 200 Cycle 20 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Test Condition Judgment Criteria Forward Voltage Vf 150 mA △Vf< 10% Luminous Flux Iv 150 mA △Iv< 30% 8 QLSP05WCWW ◼ Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): 9 QLSP05WCWW ◼ Taping & Packing Unit : mm 10 QLSP05WCWW Labeling Ordering Information: Part # QLSP05WCWW Multiple Quantities Quantity per Reel 4000 pcs 11 QLSP05WCWW Revision History: Revision Date: 08-10-2020 Changes: Version #: Initial release 1.0 12
QLSP05WCWW 价格&库存
很抱歉,暂时无法提供与“QLSP05WCWW”相匹配的价格&库存,您可以联系我们找货
QLSP05WCWW
  • 1+2.730191+0.35345
  • 10+1.8695410+0.24203
  • 100+1.31678100+0.17047
  • 500+1.06503500+0.13788
  • 1000+0.981771000+0.12710
  • 2000+0.910912000+0.11793
库存:7123
QLSP05WCWW
    • 1+1.21468
    • 200+0.48471
    • 500+0.46851
    • 1000+0.46052
    QLSP05WCWW
      • 4000+0.850584000+0.11012
      • 8000+0.799338000+0.10348
      • 12000+0.7730312000+0.10008
      • 20000+0.7433220000+0.09623
      • 28000+0.7256428000+0.09394
      • 40000+0.7083840000+0.09171
      库存:7123
