QLSP06RGBXWAJ
QLSP06RGBXWAJ
    QUELIGHTING
    SMD3030_2P
    发光二极管/LED 红色,翠绿色,蓝色,白色 SMD3030_2P
QLSP06RGBXWAJ 数据手册
QLSP06RGBXWAJ (3030RGBW HP LED) QLSP06RGBXWAJ V1.0 Product Outline: This is a small package with ceramic substrate for multi-color high power LED, that provides high lumen output in the 3030 package. Creating a small optical light source because of the compact design it’s ideal for color mixing applications Features: • • • • • • • Multi-Color LED, Red/Green/Blue/White LED Ceramic substrate High brightness output @ 350mA, Package Dimension = 3.0mmX3.0mmX1.8mm RoHS compliant Custom Bin available upon special request View angel >120° Application: • • • • • Entertainment lighting Architecture Lighting Garden Lighting Indoor and Outdoor Lighting Entertainment lighting. Compliance and Certification: 1 QLSP06RGBXWAJ V1.0 Mechanical Property: (Dimension) * All dimensions are in millimeter and tolerances are ± 0.10mm. * Please do not bend the leads of the LED, otherwise it will damage the LED. * Please do not use a force of over 0.3kgf impact or pressure on the lens of the LED, it will cause a failure. Recommended Solder footprint: * All dimensions are in millimeters. * The LEDs is designed to be reflow soldered on to a PCB. IF dip soldered that QL cannot guarantee its reliability. * Reflow soldering must not be performed more than twice. 2 QLSP06RGBXWAJ V1.0 Characteristics ◼ Absolute Maximum Ratings (Ta=25℃) Parameter Symbol Rating Unit DC Forward Current If 400 mA Leakage Current (5V) Ir 10 μA Total Power Dissipation Pd 5000 mW Pulse Forward Current Ifp 500 mA LED Junction Temperature TJ 120 ℃ Storage Temperature Tstg -40 ~ 85 ℃ Operation Temperature Topr -40 ~ 120 ℃ Soldering Temperature Tsol 260 < 10 sec ℃ (1) Proper current rating must be observed to maintain junction temperature below maximum at all time (2) IFP Condition: Duty 1/10, Pulse within 10msec ◼ Electrical / Optical Characteristic Parameter Symbol Condition (Ta=25 oC) Max. Unit 2.0 2.6 V 2.8 3.6 V Blue 2.8 3.6 V White 2.8 3.6 V Red Green Vf View Angle θ Min. Typ. 350mA 120 deg (1) Tolerance of measurement: VF=+/- 0.1V 3 QLSP06RGBXWAJ V1.0 ◼ Specification Product Flux ΦV(lm) Vf(V) Typ. Wd / CCT (nm) Min. Typ. 2.2 620~630 45 55 3.2 520~530 90 110 Blue 3.2 450~460 19 22 White 3.2 4480~6970K 80 105 Color Current Red Green QLSP06RGBXWAJ 350mA *Tolerance = +/- 10% ◼ Groups Dominant Wavelength Wd (nm) Color Code name Min. Max. Red A82 620 630 Green DN2 520 530 Blue DA2 450 460 Condition 350mA Measurement tolerance is +/- 1nm Forward Voltage (VF) Bin: VF Rank Color Code name Low High Red R6 2.0 2.6 Green Z8 2.8 3.6 Blue Z8 2.8 3.6 White Z8 2.8 3.6 Condition 350mA The forward voltage tolerance is ± 0.1V 4 QLSP06RGBXWAJ V1.0 Luminous Flux Bin: Flux ΦV(lm) Color Code name Low High A 45 58 B 58 75 A 90 115 B 115 147 A 19 25 B 25 33 A 80 105 B 105 130 Condition Red Green 350mA Blue White luminous flux tolerance is ± 7% ◼ White Binning Cold White Binning: 5 QLSP06RGBXWAJ V1.0 Characteristic Curves (1) Color Spectrum 6 QLSP06RGBXWAJ V1.0 (2). Typical Representative Spatial Radiation Pattern (3). Forward Current vs Relative Luminous Flux 7 QLSP06RGBXWAJ V1.0 (4). Forward Current vs Forward Voltage 8 QLSP06RGBXWAJ V1.0 (5). Relative Light Output vs. Junction Temperature (6). Board Temperature vs. Maximum Forward Current 9 QLSP06RGBXWAJ V1.0 ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 1000 Hrs 20 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 1000 Hrs 20 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 1000 Hrs 20 pcs 4 Steady State Operating Life of Low Temperature 85℃ 85℃ Operating 1000 Hrs 20 pcs 5 Low temperature storage -40℃ -40℃ Storage 1000 Hrs 20 pcs 6 High temperature storage 100℃ 100℃ Storage 1000 Hrs 20 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 1000 Hrs 20 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 200 Cycle 20 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 20 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 20 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 300 Cycle 20 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Test Condition Judgment Criteria Forward Voltage Vf 350 mA △Vf< 10% Luminous Flux Iv 350 mA △Iv< 30% 10 QLSP06RGBXWAJ V1.0 Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): Note: 1. 2. 3. The recommended reflow temperature is 230°C, the maximum soldering temperature should be limited to 240°C Do not stress the silicone resign while it is exposed to high temperature. The number of reflow process should not exceed 3 times 11 QLSP06RGBXWAJ V1.0 Taping & Packing: Unit : mm Notes: 1. Drawing not to scale. 2. All dimensions are in millimeters. 3. Unless otherwise indicated, tolerances are ± 0.10mm. 12 QLSP06RGBXWAJ V1.0 13 QLSP06RGBXWAJ V1.0 Labeling Ordering Information: Part # QLSP06RGBXWAJ Multiple Quantities Quantity per Reel 250,500,1000 pcs 14 QLSP06RGBXWAJ V1.0 Revision History: Revision Date: 11-26-2020 Changes: Initial release Version #: 1.0 15
QLSP06RGBXWAJ 价格&库存
很抱歉,暂时无法提供与“QLSP06RGBXWAJ”相匹配的价格&库存,您可以联系我们找货
