QLSP07ZCE
(3535 4W Flat White LED)
QLSP07ZCE
Product Outline:
QLSP07ZCE series is a High Power LED with high performance and light quality. it also
provide high flux density of lighting source for 2nd lens design. The lighting application
such as cation light, Fog light, working light, Head lamp, specific industrial and commercial
lighting.
Features:
High brightness output @ 1000mA,
High Junction Temperature @ 150°C
Ceramic substrate
Plating material is gold for good sulfur resistance.
Ra 70
Package Dimension = 3.5mmX3.5mmX0.79mm
Low thermal resistance : 4.5°C/W
ESD protection up to 8KV
RoHS compliant
Custom Bin available upon special request
Application:
Outdoor Lighting
Working Light
Daytime Running Light
Fog light
Head lamp
Compliance and Certification:
1
QLSP07ZCE
Mechanical Property:
(Dimension)
Notes:
1. Drawing not to scale.
2. All dimensions are in millimeters.
3. Unless otherwise indicated, tolerances are ± 0.10mm.
4. Please do not solder the emitter by manual hand soldering, otherwise it will damage the emitter.
5. Please do not use a force of over 0.3kgf impact or pressure on the lens of the LED, otherwise
it will cause a catastrophic failure.
2
QLSP07ZCE
Recommended Solder footprint:
Electrical / Optical Characteristic
(T=25 oC)
VF(V)
Product
Color
QLSP07ZCE
Cold White
CCT
Luminous Flux(lm)
IF(mA)
Typ.
max
Typ
min
typ.
2.9
3.7
6000K
320
340
1000
(1) The Forward Voltage tolerance is ±0.1V
(2) The luminous flux tolerance is ±10%
(3) Thermal resistance is calculated from junction to solder
(4) Electric and optical data is tested at 50 ms pulse condition
(5) The color coordinates measurement tolerance is ±0.005
Absolute Maximum Rating
Part #
QLSP07ZCE
Pd (mW) IF (mA)
4000
1200
(T=25 oC)
IFP (mA)*
VR (V)
Tj(oC)
TOP (oC)
TST (oC)
TSOL (oC)**
Rth(J-S)
(C/W)***
2000
5
150
-40 – 125
-40 - 125
260
4.5
*Duty 1/10 @ 10Khz
** IR Reflow for no more than 10 sec @ 260 oC
*** Junction to substrate
3
QLSP07ZCE
White Binning
Forward Voltage (VF) Bin:
VF Rank @ 1000mA (V)
Code name
Low
High
02
2.8
3.1
14
3.1
3.4
47
3.4
3.7
The forward voltage tolerance is ± 0.1V
Luminous Flux Bin:
Rank @ 1000mA (lm)
Code name
Low
High
U6
320
340
U7
340
360
U8
360
380
luminous flux tolerance is ± 10%
4
QLSP07ZCE
Characteristic Curves
(1) Color Spectrum
(2). Typical Representative Spatial Radiation Pattern
5
QLSP07ZCE
(3). Forward Current Characteristics
(4). Forward Current vs Forward Voltage
6
QLSP07ZCE
(5). Forward Current vs. Chromaticity Coordinate
(6). Chromaticity Coordinate vs. Junction Temperature
7
QLSP07ZCE
(7). Relative Forward Voltage vs. Junction Temperature
(8). Forward Current Derating Curve
8
QLSP07ZCE
◼ Reliability test:
No
Item
Condition
1
Steady State Operating Life of
Room Temperature
25℃ Operating
Standard of
criterion
Result
Pass
2
Steady State Operating Life of Low
Temperature -40℃
-40℃ Operating
1000 Hrs
20 pcs
3
Temperature 60℃
60℃ Operating
1000 Hrs
20 pcs
4
Temperature 85℃
85℃ Operating
1000 Hrs
20 pcs
5
Low temperature storage -40℃
-40℃ Storage
1000 Hrs
20 pcs
6
High temperature storage 100℃
100℃ Storage
1000 Hrs
20 pcs
7
Steady State Operating Life of High
Humidity Heat 60℃90%
60oC/90% Operating
1000 Hrs
20 pcs
8
Steady State Pulse Operating Life
Condition
25℃10Hz duty=1/10 Operating
200 Cycle
20 pcs
9
Resistance to soldering heat on
PCB (JEDEC MSL3)
pre-store@60℃, 60%RH for
52hrs Tsld max.=260 10sec
3 Times
20 pcs
10
Heat Cycle Test (JEDEC MRC)
25℃~65℃~-10℃, 90%RH,
24hr/1cycle
10 Cycle
20 pcs
11
Thermal shock
-40℃/ 20minr~ 5minr~100℃
/20min
300 Cycle
20 pcs
◼ Judgment Criteria:
Item
Symbol
Test Condition
Judgment
Criteria
Forward Voltage
Vf
1000 mA
△Vf< 10%
Luminous Flux
Iv
1000 mA
△Iv< 20%
9
QLSP07ZCE
Solder Profile:
-The recommended reflow soldering profile is as follows (temperatures indicated are as
measured on the surface of the LED resin):
Profile Feature
Sn-Pb Eutectic Assembly
Pb-Free Assembly
Temperature Min(Tsmin)
100℃
150℃
Temperature Max(Tsmax)
150℃
200℃
Time(ta) from (Tsmin to Tsmax)
60-120 seconds
60-120 seconds
Ramp-up rate(TL to TP)
3℃/second max.
3℃/second max.
Liquidous Temperature(TL)
183℃
217℃
Time(tL) maintained above TL
60-150 seconds
60-150 seconds
Peak package body temperature(TP)
235℃
260℃
Time within 5℃ of Actual Peak
temperature (tp)
Ramp-down rate(TP to TL)
20seconds*
30 seconds*
6℃/second max.
6℃/second max.
Time 25℃ to peak temperature
6 minutes max.
8 minutes max.
* Tolerance for peak profile temperature (TP) is defined as a supplier minimum and a user
maximum.
10
QLSP07ZCE
The selection of nozzle for SMT:
If the nozzle is not suitable for the sample, it drops easily, when it is picked up.
Recommended nozzle size is as the following list.
Precautions for SMT:
Undergoing the SMT, beware of the way of picking and pressing the sample, the appearance
of sample is easily broken by the stress or the shear.
⚫ After LEDs have been soldered, strongly recommend not to repair to keep the LEDs
performance.
⚫ Thicker solder will induce higher heat resistance. Thickness of solder is recommended to
be thinner than 75um, at least 100um.
The void rate of the solder on heat transparent lower than 10% is recommended.
11
QLSP07ZCE
Taping & Packing:
Unit : mm
12
QLSP07ZCE
13
QLSP07ZCE
Handling of LEDs
1. Under SMT process, mechanical stress on the LED surface should be avoided.
2. In general, LEDs should be handled from the side of the substrate, since the surface will be
scratched or the white reflector will be peeled off.
3. There are no restrictions on the form of the pick and place nozzle, except that mechanical
stress on the surface of LED must be prevented. Lextar recommend that the material of
nozzle is the rubber or the silicone, which the property is soft to prevent break the LED.
Soldering Notice and Conditions
Handling indications:
The sample cannot be picked up by touching the white PKG body. The sample must be
picked up by gripping the side of the PKG substrate.
14
QLSP07ZCE
Labeling
Ordering Information:
Part #
QLSP07ZCE
Multiple Quantities
Quantity per Reel
1000 / 1500 / 2000pcs
15
QLSP07ZCE
Revision History:
Revision Date:
Changes:
Version #:
03-27-2021
Initial release
1.0
16
很抱歉,暂时无法提供与“QLSP07ZCE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+15.72480
- 200+6.27480
- 500+6.06960
- 1000+5.96160
