QLSP08RGBW
QLSP08RGBW
    QUELIGHTING
    SMD5050
    发光二极管/LED 红色,翠绿色,蓝色,白色 SMD5050 467nm,623nm,525nm 1500mcd,500mcd,700mcd SMT
QLSP08RGBW 数据手册
QLSP08RGBW (5050 RGBW Multi-Color LED) QLSP08RGBW V1.0 Product Outline: This is a multi-color LED that provides high lumen output in the 5050 package. Creating a small optical light source because of the compact design it’s ideal for color mixing applications Features: • • • • • • Multi-Color LED, Red/Green/Blue/White LED High brightness output @ 20mA, Package Dimension = 5.4mmX5.0mmX1.6mm RoHS compliant Custom Bin available upon special request View angel >120° Application: • • • • • Stage lighting, Architecture Lighting Garden Lighting Indoor and Outdoor display Entertainment lighting. Compliance and Certification: 1 QLSP08RGBW V1.0 Mechanical Property: (Dimension) * All dimensions are in millimeters, * Tolerances are ± 0.10mm. * Please do not bend the leads of the LED, otherwise it will damage the LED. * Please do not use a force of over 0.3kgf impact or pressure on the lens of the LED, otherwise it will cause a catastrophic failure. 2 QLSP08RGBW V1.0 Recommended Solder footprint: * All dimensions are in millimeters. * The LEDs is designed to be reflow soldered on to a PCB. IF dip soldered that QL cannot guarantee its reliability. * Reflow soldering must not be performed more than twice. Characteristics ◼ Absolute Maximum Ratings (Ta=25℃) Parameter Symbol Rating Unit DC Forward Current - R,G,B If 20 mA DC Forward Current – White If 60 mA Leakage Current (5V) Ir 10 μA Total Power Dissipation Pd 360 mW Pulse Forward Current - R,G,B Ifp 30 mA Pulse Forward Current - White Ifp 90 mA LED Junction Temperature TJ 105 ℃ Storage Temperature Tstg -40 ~ 85 ℃ Operation Temperature Topr -40 ~ 85 ℃ Soldering Temperature Tsol 260 < 10 sec ℃ (1) Proper current rating must be observed to maintain junction temperature below maximum at all time (2) IFP Condition: Duty 1/10, Pulse within 10msec 3 QLSP08RGBW V1.0 ◼ Electrical / Optical Characteristic Parameter Symbol Red Vf Green Vf Blue Vf White Vf View Angle θ Condition (Ta=25 oC) Min. 20mA 60mA Typ. Max. Unit 2.0 2.4 V 2.8 3.4 V 2.8 3.4 V 2.8 3.4 V 120 deg (1) Tolerance of measurement: VF=+/- 0.1V ◼ Specification Product Color Curren Vf(V) t Typ. Red QLSP08RGBXW Green 20mA Blue Wd / CCT (nm) Intensity(mcd) or Flux ΦV(lm) Min. Typ. 2.2 620~625 600 700 3.2 520~525 1400 1500 3.2 465~470 400 500 QLSP08RGBWW Warm White 60mA 3.2 2850~3150K 19 21 QLSP08RGBNW Netural White 60mA 3.2 3700~4250K 19 21 3.2 5640~6970K 19 21 QLSP08RGBCW Cold White 60mA *Tolerance = +/- 10% 4 QLSP08RGBW V1.0 ◼ Groups Dominant Wavelength Wd (nm) Color Code name Min. Max. Red A8 620 625 Green DN 520 525 Blue DD 465 470 Condition 20mA Measurement tolerance is +/- 1nm Forward Voltage (VF) Bin: VF Rank Color Code name Low High Red R4 2.0 2.4 Green Z6 2.8 3.4 Blue Z6 2.8 3.4 White Z6 2.8 3.4 Condition 20mA 60mA The forward voltage tolerance is ± 0.1V Luminous Intensity Bin: Rank (mcd) or Flux ΦV(lm) Color Red Green Blue White Code name Low High A 770 1000 B 1000 1300 A 1550 2000 B 2000 2600 A 330 430 B 430 560 A 19 24 B 24 30 Condition 20mA 60mA luminous flux tolerance is ± 7% 5 QLSP08RGBW V1.0 ◼ White Binning Warm White Binning: Neutral White Binning: 6 QLSP08RGBW V1.0 Cold White Binning: Characteristic Curves (1) Color Spectrum 7 QLSP08RGBW V1.0 (2). Typical Representative Spatial Radiation Pattern 8 QLSP08RGBW V1.0 (3). Forward Current vs Relative Luminous Flux (4). Forward Current vs Forward Voltage 9 QLSP08RGBW V1.0 (5). Relative Light Output vs. Junction Temperature 10 QLSP08RGBW V1.0 ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 1000 Hrs 20 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 1000 Hrs 20 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 1000 Hrs 20 pcs 4 Steady State Operating Life of Low Temperature 85℃ 85℃ Operating 1000 Hrs 20 pcs 5 Low temperature storage -40℃ -40℃ Storage 1000 Hrs 20 pcs 6 High temperature storage 100℃ 100℃ Storage 1000 Hrs 20 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 1000 Hrs 20 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 200 Cycle 20 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 20 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 20 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 300 Cycle 20 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Test Condition Judgment Criteria Forward Voltage Vf 20 mA △Vf< 10% Luminous Flux Iv 20 mA △Iv< 30% 11 QLSP08RGBW V1.0 Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): Note: 12 QLSP08RGBW V1.0 Taping & Packing: Unit : mm 13 QLSP08RGBW V1.0 14 QLSP08RGBW V1.0 Labeling Ordering Information: Part # QLSP08RGBXW Multiple Quantities Quantity per Reel 1000 pcs 15 QLSP08RGBW V1.0 Revision History: Revision Date: 11-23-2020 Changes: Initial release Version #: 1.0 16
QLSP08RGBW 价格&库存
很抱歉,暂时无法提供与“QLSP08RGBW”相匹配的价格&库存,您可以联系我们找货
