QLSP15RNB
QLSP15RNB
    QUELIGHTING
    SMD-4P,3.2x1.3mm
    发光二极管/LED 红色,蓝色 SMD-4P,3.2x1.3mm 624nm,472nm 130mcd,120mcd
QLSP15RNB 数据手册
QLSP15RNB Reverse Mount Bi-color Red/Blue QLSP15RNB V1.0 Product Outline: This is a reverse mountable bi color LED with AlInGaP Red and InGaN Blue. With small footprint and compact size, this package is ideal for status indication. Features: • • • • • • • • Package in 8mm tape on 7〞diameter reel Compatible with automatic placement equipment. Compliance with EU REACH RoHS compliant Compatible with infrared and vapor phase reflow solder process. Custom Bin available upon special request View angel >120° Color: AlInGaP Red / InGaN Blue Application: • • • • Backlighting in dashboard and switch. Telecommunication: indicator and backlighting in telephone and fax. Flat backlight for LCD switch and symbol. General use. Compliance and Certification: 1 QLSP15RNB V1.0 Mechanical Property: (Dimension) * All dimensions are in millimeters, * Tolerances are ± 0.10mm. Recommended Solder footprint: * All dimensions are in millimeters. * Reflow soldering must not be performed more than twice. 2 QLSP15RNB V1.0 Characteristics ◼ Absolute Maximum Ratings Color R (Red) NB (Blue) PD (mW) 50 65 IF (mA) 20 20 (Ta=25℃) IFP* (mA) 60 60 TOP (℃) -40 ~ 85 -40 ~ 85 TST (℃) -40 ~ 85 -40 ~ 85 VR (V) 5 5 *IFP: is pulse @ 1/10 duty cycle and 0.1ms ◼ Electrical / Optical Characteristic (Ta=25 oC) (AlInGaP RED = R) Parameter Symbol Min. Typ. Max. Unit Luminous Intensity Iv 120 mcd Peak Wavelength λp 632 nm Dominant Wavelength λd 624 nm Forward Voltage Vf View Angle θ Condition IF=20mA 1.9 2.4 120 V deg (InGaN Blue = NB) Parameter Symbol Min. Typ. Max. Unit Luminous Intensity Iv 130 mcd Peak Wavelength λp 470 nm Dominant Wavelength λd 472 nm Forward Voltage Vf View Angle θ Condition IF=20mA 2.9 3.4 120 V deg (1) Tolerance of Dominant Wavelength ±1nm (2) Tolerance of measurement: VF=+/- 0.1V (3) Tolerance of Luminous Intensity: ±11% 3 QLSP15RNB V1.0 Binning Brightness: ( R&NB ) Full 1 2 3 4 Low ( mcd ) 100 100 200 300 400 High ( mcd ) 600 200 300 400 600 Low ( V ) High ( V ) 1.9 2.1 2.2 2.1 2.3 2.4 Low ( V ) High ( V ) 2.8 3.0 3.2 3.4 Low ( nm ) High ( nm ) 465 615 475 625 Vf: ( R ) A B C Vf: ( NB ) X Y Color: ( NB & R ) Full ( Blue ) Full ( Red ) 4 QLSP15RNB V1.0 Characteristic Curves Relative Intensity vs Wavelength Forward current vs Forward Voltage Forward Current vs Soldering Pad Temp Relative Intensity vs Forward Current X radiation pattern Y Radiation pattern 5 QLSP15RNB V1.0 ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 1000 Hrs 20 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 1000 Hrs 20 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 1000 Hrs 20 pcs 4 Steady State Operating Life of Low Temperature 85℃ 85℃ Operating 1000 Hrs 20 pcs 5 Low temperature storage -40℃ -40℃ Storage 1000 Hrs 20 pcs 6 High temperature storage 100℃ 100℃ Storage 1000 Hrs 20 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 1000 Hrs 20 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 200 Cycle 20 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 20 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 20 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 300 Cycle 20 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Forward Voltage Vf Luminous Flux Iv Test Condition Judgment Criteria △Vf< 10% R:IF=20 mA △Iv< 30% 6 QLSP15RNB V1.0 Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): 7 QLSP15RNB V1.0 Taping & Packing: Unit : mm 8 QLSP15RNB V1.0 Labeling 9 QLSP15RNB V1.0 Ordering Information: Part # QLSP15RNB Multiple Quantities Quantity per Reel 3000 pcs 10 QLSP15RNB V1.0 Revision History: Revision Date: 2-5-2021 Changes: Initial release Version #: 1.0 11
QLSP15RNB 价格&库存
很抱歉,暂时无法提供与“QLSP15RNB”相匹配的价格&库存,您可以联系我们找货
