QLUV07N2DM
QLUV07N2DM
    QUELIGHTING
    紫外线(UV) 发射器 265nm ~ 285nm 7V 150mA 8mW/sr @ 100mA 35° 1414(3535 公制)
QLUV07N2DM 数据手册
QLUV07N2DM 3535 10mW UVC LED QLUV07N2DM V1.0 Product Outline: The high output ceramic type 3535 with 35 degree view angle LEDs, UVC LED series are designed for high current operation and high power output applications. Quelighting UV LED is ideal UV light source for water disinfection. Features: • • • • • • • • • • UVC LED Quartz glass lens Max. current = 150mA , up to 1.5W Package Dimension = 3.5mmX3.5mmX3.15mm Ceramic subtract MSL 3 qualified according to J-STD 020 Low thermal resistance View angle = 35 degree RoHS compliant Custom Bin available upon special request Application: • • • • • Water disinfection Air purifiers Disinfection Phototherapy Bio-Analysis/DetectionFeatures Compliance and Certification: 1 QLUV07N2DM V1.0 Mechanical Property: 35 Degree Field Angle Note: 1. All dimension in millimeters 2. tolerance is ±0.2mm 2 QLUV07N2DM V1.0 Recommended Solder footprint: Note: 1. All dimension in millimeters 2. The drawing without tolerances is for reference only 3. Suggest stencil T=0.12 mm Electrical / Optical Characteristic Product QLUV07N2DM View angle 35 VF(V) IF(mA) 100 (T=25 oC) Typ. max 7 10 Wavelength (nm) 265-285 Radiant Power(mW) min typ. 8 11.5 (1) The Forward Voltage tolerance is ±0.1V (2) The Peak wavelength tolerance is ±2 (3) The Radiant power is ± 7% 3 QLUV07N2DM V1.0 Absolute Maximum Rating (T=25 oC) Part # Pd (mW) IF (mA) IFP (mA)* VR (V) TOP (oC) TST (oC) Tj (oC)** TSOL (oC)** Rth(J-S) (C/W)*** QLUV07N2DM 1.5 150 180 -5 -40 – 60 -40 - 85 85 260 15 *Duty 1/10 @ 10Khz ** Junction Temperature *** IR Reflow for no more than 10 sec @ 260 oC **** Thermal resistance is calculated from junction to solder Peak Wavelength Binning Wavelength Rank @ 100mA Code name Low High U265T 265 275 U275T 275 285 Units nm Forward Voltage (VF) Bin: VF Rank @ 100mA Code name Min. Max. Units A B C D E F 5.0 5.5 6.0 6.5 7.0 7.5 5.5 6.0 6.5 7.0 7.5 8.0 V The forward voltage tolerance is ± 0.1V 4 QLUV07N2DM V1.0 Characteristic Curves Forward Voltage vs. Forward Current Relative Luminous Intensity vs Ambient Temperature Forward current vs. Relative luminous intensity Solder Temperature (Slug) vs. Maximum Forward Current 5 QLUV07N2DM V1.0 Spectrum Distribution Typical Representative Spatial Radiation Pattern 6 QLUV07N2DM V1.0 ◼ Reliability test: No Item Condition Time/Cycle Sample size 1 Steady State Operating Life of Room Temperature 25℃ Operating 500 Hrs 10 pcs 2 Steady State Operating Life of Low Temperature -40℃ -40℃ Operating 500 Hrs 10 pcs 3 Steady State Operating Life of Low Temperature 60℃ 60℃ Operating 500 Hrs 10 pcs 4 Steady State Operating Life of Low Temperature 85℃ 65℃ Operating 500 Hrs 10 pcs 5 Low temperature storage -40℃ -40℃ Storage 500 Hrs 10 pcs 6 High temperature storage 100℃ 100℃ Storage 500 Hrs 10 pcs 7 Steady State Operating Life of High Humidity Heat 60℃90% 60oC/90% Operating 500 Hrs 10 pcs 8 Steady State Condition 25℃10Hz duty=1/10 Operating 100 Cycle 10 pcs 9 Resistance to soldering heat on PCB (JEDEC MSL3) pre-store@60℃, 60%RH for 52hrs Tsld max.=260 10sec 3 Times 10 pcs 10 Heat Cycle Test (JEDEC MRC) 25℃~65℃~-10℃, 90%RH, 24hr/1cycle 10 Cycle 10 pcs 11 Thermal shock -40℃/ 20minr~ 5minr~100℃ /20min 100 Cycle 10 pcs Pulse Operating Life ◼ Judgment Criteria: Item Symbol Test Condition Judgment Criteria Forward Voltage Vf 100 mA △Vf< 10% Luminous Flux Iv 100 mA △Iv< 30% 7 QLUV07N2DM V1.0 Solder Profile: -The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): Profile Feature Sn-Pb Eutectic Assembly Pb-Free Assembly Temperature Min(Tsmin) 100℃ 150℃ Temperature Max(Tsmax) 150℃ 200℃ Time(ta) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up rate(TL to TP) 3℃/second max. 3℃/second max. Liquidous Temperature(TL) 183℃ 217℃ Time(tL) maintained above TL 60-150 seconds 60-150 seconds Peak package body temperature(TP) 235℃ 260℃ Time within 5℃ of Actual Peak temperature (tp) Ramp-down rate(TP to TL) 20seconds* 30 seconds* 6℃/second max. 6℃/second max. Time 25℃ to peak temperature 6 minutes max. 8 minutes max. * Tolerance for peak profile temperature (TP) is defined as a supplier minimum and a user maximum. 8 QLUV07N2DM V1.0 Taping & Packing: 9 QLUV07N2DM V1.0 10 QLUV07N2DM V1.0 Labeling Ordering Information: Part # Multiple Quantities QLUV07N2DM Quantity per Reel 250, 500 pcs Revision History: Revision Date: 07-04-2020 Changes: Initial release Version #: 1.0 11
QLUV07N2DM 价格&库存
很抱歉,暂时无法提供与“QLUV07N2DM”相匹配的价格&库存,您可以联系我们找货
