R201L00010
R201L00010
    RADIALL
    SMPM 连接器 插座,公插针 50 欧姆 板边缘,切口;表面贴装 焊接
R201L00010 数据手册
Technical Data Sheet MALE RECEPTACLE SMT EDGE CARD-TR500 PAGE 1/4 ISSUE 08-04-20A SERIES SMPM-L PART NUMBER R201L00010 All dimensions are in mm. Tolerances according ISO 2768 m-H . pn . ao COMPONENTS Body Center contact Outer contact Insulator Gasket Others parts - MATERIALS BERYLLIUM COPPER BERYLLIUM COPPER PLATING (µm) N2PGR N2PGR PEEK BERYLLIUM COPPER - N2PGR - This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary. Technical Data Sheet MALE RECEPTACLE SMT EDGE CARD-TR500 PAGE 2/4 ISSUE 08-04-20A SERIES SMPM-L PART NUMBER R201L00010 PACKAGING Standard 100 Unit Contact us Tape Reel 500 ELECTRICAL CHARACTERISTICS Impedance Frequency * + VSWR Insertion loss RF leakage -( Voltage rating Dielectric withstanding voltage Insulation resistance 50 0-65 0,0000 *.012 TBD 125 250 5000 Ω GHz x F(GHz) Maxi √F(GHz) dB Maxi - F(GHz)) dB Maxi Veff Maxi Veff mini MΩ mini RECOMMENDED SOLDERING PARAMETERS Solder paste deposit: Sn (96.5) - Ag (3.0) - Cu (0.5) Granulometry from 25 to 36 micrometer Deposit thickness: 100 micrometer Flux: low residue according to IEC 61760-1 and max 10s at max 260°C Soldering T°C MECHANICAL CHARACTERISTICS Center contact retention Axial force – Mating End Axial force – Opposite end Torque 6.7 6.7 NA N mini N mini N.cm mini ENVIRONMENTAL Recommended torque Mating Panel nut Mating life Nominal Weight (Add +15% for max weight) NA NA 500 0,5120 N.cm N.cm Cycles mini g Operating temperature Hermetic seal Panel leakage -65/+165 NA °C Atm.cm3/s SPECIFICATION OTHER CHARACTERISTICS Assembly instruction: Others: * 1.15 (DC-26.5 GHz) 1.35 (26.5-40 GHz) * Coaxial transmission line only * RF performances highly depend on PCB adaptation This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary. Technical Data Sheet MALE RECEPTACLE SMT EDGE CARD-TR500 PAGE 3/4 ISSUE 08-04-20A SERIES SMPM-L PART NUMBER R201L00010 PCB Dimension This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary. Technical Data Sheet MALE RECEPTACLE SMT EDGE CARD-TR500 PAGE 4/4 ISSUE 08-04-20A SERIES SMPM-L PART NUMBER R201L00010 PACKAGING This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary.
R201L00010 价格&库存
很抱歉,暂时无法提供与“R201L00010”相匹配的价格&库存,您可以联系我们找货
