R201L80000
R201L80000
    RADIALL
    SMPM 连接器 插头,母形插口 50 欧姆 自由悬挂 焊接
R201L80000 数据手册
Technical Data Sheet STRAIGHT PLUG SOLDER TYPE CABLE 1.42/50D PAGE 1/4 ISSUE 15-04-20A SERIES SMPM-L PART NUMBER R201L80000 All dimensions are in mm. Tolerances according ISO 2768 m-H . pn . ao COMPONENTS Body Center contact Outer contact Insulator Gasket Others parts - MATERIALS PLATING (µm) BERYLLIUM COPPER BERYLLIUM COPPER BERYLLIUM COPPER PTFE+PEEK N2PGR GOLD 1.3 OVER NICKEL2 N2PGR BRONZE,BERYLLIUM COPPER - NICKEL, GOLD - This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary. Technical Data Sheet STRAIGHT PLUG SOLDER TYPE CABLE 1.42/50D PAGE 2/4 ISSUE 15-04-20A SERIES SMPM-L PART NUMBER R201L80000 PACKAGING Standard 100 Unit Contact us Other Contact us ELECTRICAL CHARACTERISTICS Impedance Frequency VSWR Insertion loss RF leakage Voltage rating Dielectric withstanding voltage Insulation resistance * -( + 50 0-65 0,0000 0.12 ** 125 250 5000 ENVIRONMENTAL Ω GHz x F(GHz) Maxi √F(GHz) dB Maxi - F(GHz)) dB Maxi Veff Maxi Veff mini MΩ mini 6.7 6.7 NA Recommended torque Mating Panel nut Clamp nut A/F clamp nut Mating life Nominal Weight (Add +15% for max weight) NA NA NA 0,0000 500 0,6100 °C Atm.cm3/s SPECIFICATION MECHANICAL CHARACTERISTICS Center contact retention Axial force – Mating End Axial force – Opposite end Torque -65/+165 NA NA Operating temperature Hermetic seal Panel leakage CABLE ASSEMBLY N mini N mini N.cm mini N.cm N.cm N.cm mm Cycles mini g Stripping mm a 7,000 0 b 3,00 00 c 1,8000 8 d e f 0,0000 0,0000 0,0000 Recommended cable(s) 047SC-2901 Characteristics indicated on this data sheet are those that can be achieved with the highest performance cable. Intrinsic limitations of the cable may diminish the performance of the assembly Cable retention - pull off - torque 25 NA N mini N.cm TOOLING Part Number R282868370 R282740060 R282918230 Description LOCK AND UNLOCK TOOL (OPTION 1) BRAZING TOOL SMPM-LOCK LOCK AND UNLOCK TOOL (OPTION 2) Hexagon OTHER CHARACTERISTICS * 1.15 : DC->26.5 Ghz * 1.35 : 26->40Ghz **-80dB up to 3GHz This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary. Technical Data Sheet STRAIGHT PLUG SOLDER TYPE CABLE 1.42/50D PAGE 3/4 ISSUE 15-04-20A SERIES SMPM-L PART NUMBER R201L80000 - Before stripping: Strip jacket, and deep tin the naked braid. A 1 - Strip the cable inner conductor. - Make a Chamfer - Clean the cable 2 -Slide the insulator onto the cable inner conductor. B C 3 - Introduce the cable into the connector body until it stops. -Slide body into the positioner. - Introduce the cable into the connector body until it stops. -Place the sub assembly into the assembly and thighten it . -Solder the body onto the cable. -After cooling remove cable assembly from the jig. This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary. Technical Data Sheet STRAIGHT PLUG SOLDER TYPE CABLE 1.42/50D PAGE 4/4 ISSUE 15-04-20A SERIES SMPM-L PART NUMBER R201L80000 Locking Nut 1-  Pushed the connector in abutment against the other connector Do not make the coupling by the locking nut 2-  Pushed to the stop the Locking Nut with the tool Use Tool Option 1 or 2 OPTION: 1 OPTION: 2 This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary.
R201L80000 价格&库存
很抱歉,暂时无法提供与“R201L80000”相匹配的价格&库存,您可以联系我们找货
