R218423000
R218423000
    RADIALL
    SMPW MALE EDGE MOUNT FULL DETENT
R218423000 数据手册
Technical Data Sheet MALE EDGE MOUNT FULL DETENT PAGE 1/3 ISSUE 12-03-19A SERIES SMPW PART NUMBER R218423000 All dimensions are in mm. Tolerances according ISO 2768 m-H . pn . ao COMPONENTS Body Center contact Outer contact Insulator Gasket Others parts - MATERIALS BERYLLIUM COPPER BERYLLIUM COPPER PLATING (m) GOLD OVER NICKEL GOLD OVER NICKEL PEEK - - This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary. Technical Data Sheet MALE EDGE MOUNT FULL DETENT PAGE 2/3 ISSUE 12-03-19A SERIES SMPW PART NUMBER R218423000 PACKAGING Standard 100 Unit Contact us Other Contact us ELECTRICAL CHARACTERISTICS Impedance Frequency see* + VSWR Insertion loss RF leakage -( Voltage rating Dielectric withstanding voltage Insulation resistance 50 0-100 0,0000 125 250 3500  GHz x F(GHz) Maxi F(GHz) dB Maxi - F(GHz)) dB Maxi Veff Maxi Veff mini M mini ENVIRONMENTAL Operating temperature Hermetic seal Panel leakage -40/+125 NA NA °C Atm.cm3/s MECHANICAL CHARACTERISTICS SPECIFICATION Center contact retention Axial force – Mating End Axial force – Opposite end Torque NA N mini N mini N.cm mini OTHER CHARACTERISTICS Recommended torque Mating Panel nut Mating life Weight NA NA 100 0,1200 N.cm N.cm Assembly instruction: Cycles mini g Others: *Coaxial transmission line only *1.1(DC to 26.5Ghz) 1.25(26.5 to 65Ghz) - This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary. Technical Data Sheet MALE EDGE MOUNT FULL DETENT PAGE 3/3 ISSUE 12-03-19A SERIES SMPW PART NUMBER R218423000 PCB Copper: For Solder Past Varnish Complete and detailed information concerning PCB structure and layout for RF adaptation are available on demand. This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary.
R218423000 价格&库存
很抱歉,暂时无法提供与“R218423000”相匹配的价格&库存,您可以联系我们找货
