Technical Data Sheet
FEMALE - FEMALE ADAPTATOR -
PAGE 1/4
ISSUE 12-03-19C
SERIES SMPW
PART NUMBER R218705020
All dimensions are in mm. Tolerances according ISO 2768 m-H
pn
ao
COMPONENTS
Body
Center contact
Outer contact
Insulator
Gasket
Others parts
MATERIALS
BERYLLIUM COPPER
BERYLLIUM COPPER
PLATING (m)
GOLD OVER NICKEL
GOLD OVER NICKEL
PEEK
This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written
agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary.
PAGE 2/4
ISSUE 12-03-19C
SERIES SMPW
PACKAGING
Standard
100
Unit
Contact us
Other
Contact us
ELECTRICAL CHARACTERISTICS
Impedance
Frequency
See* +
VSWR
Insertion loss
RF leakage
Voltage rating
Dielectric withstanding voltage
Insulation resistance
50
0-100
0,0000
0.055
70**
125
250
3500
GHz
x F(GHz) Maxi
F(GHz) dB Maxi
- F(GHz)) dB Maxi
Veff Maxi
Veff mini
M mini
ENVIRONMENTAL
Operating temperature
Hermetic seal
Panel leakage
-40/+125
NA
NA
°C
Atm.cm3/s
MECHANICAL CHARACTERISTICS
SPECIFICATION
Center contact retention
Axial force – Mating End
Axial force – Opposite end
Torque
5.8
5.8
NA
N mini
N mini
N.cm mini
OTHER CHARACTERISTICS
Recommended torque
Mating
Panel nut
Mating
NA
NA
100
Cycles mini Fulldetent
Cycles Smoothbore
500
Weight
N.cm
N.cm
0,0500
g
Assembly instruction:
Others:
*1.1(DC to 26.5Ghz) 1.25(26.5 to 65Ghz)
**DC to 40 Ghz
PAGE 3/4
ISSUE 12-03-19C
SERIES SMPW
MISALIGNMENT AXIAL AND RADIAL
PAGE 4/4
ISSUE 12-03-19C
SERIES SMPW
PACKAGING
100 PER BOX
10 Bullets per cavity
很抱歉,暂时无法提供与“R218705020”相匹配的价格&库存,您可以联系我们找货
