TECHNICAL DATA SHEET
1/2
STRAIGHT MALE RECEPTACLE NON MAGNETIC
R222.946.314
Series : SMP-COM
SOLDER LEGS FOR PCB - LIMITED DETENT
All dimensions are in mm.
pn
ao
COMPONENTS
MATERIALS
BODY
CENTER CONTACT
OUTER CONTACT
INSULATOR
GASKET
OTHERS PARTS
NON MAGNETIC BRONZE
NON MAGNETIC BRONZE
PLATING (µm)
GOLD OVER COPPER
GOLD OVER COPPER
PTFE
Issue : 1219 B
In the effort to improve our products, we reserve the right to make changes judged to be
necessary.
2/2
R222.946.314
Series : SMP-COM
PACKAGING
Standard
100
Unit
SPECIFICATION
Other
Contact us
ELECTRICAL CHARACTERISTICS
ENVIRONMENTAL
Impedance
Operating temperature -55/+125 ° C
50 Ω
Frequency
Hermetic seal
0-12 GHz
NA Atm.cm3/s
VSWR
Panel leakage
1.15* + 0,0000 x F(GHz) Maxi
NA
Insertion loss
0.12* √F(GHz) dB Maxi
RF leakage
NA - F(GHz)) dB Maxi
Voltage rating
335 Veff Maxi
Dielectric withstanding voltage
500 Veff mini
Insulation resistance
5000 MΩ mini
OTHER CHARACTERISTICS
Assembly instruction
NA
Others :
MECHANICAL CHARACTERISTICS
Center contact retention
Axial force – Mating end
Axial force – Opposite end
Torque
6.8 N mini
NA N mini
NA N.cm mini
Recommended torque
Mating
Panel nut
NA N.cm
NA N.cm
Mating life
Weight
* Coaxial Transmission Line Only
Distorsion of the magnetic field
< 0.5 ppm at 10 mm at Bo = 1.5 Tesla
100 Cycles mini
0,4800 g
Issue : 1219 B
necessary.
很抱歉,暂时无法提供与“R222946314”相匹配的价格&库存,您可以联系我们找货
