R284C0351011
R284C0351011
    RADIALL
    BNC*2/RG223
R284C0351011 数据手册
PART NUMBER :R284C0351011 TECHNICAL DATA SHEET CABLE ASSEMBLY Issue : NA Date : NA No.390, Yong He Road, Shanghai 200072, China Customer : Specification : NA Issue : NA Date : N/A All dimensions are in mm Connectors designation : Connector 1 : BNC Straight Plug Crimp Type Cable 5/50 D (R141.083.000) Cable designation : Flexible Cable 5/50S (RG223) C291.330.000 Lg: 500 mm Nominal length : Cable colour : Connector 2 : BNC Straight Plug Crimp Type Cable 5/50 D (R141.083.000) Black 5.38 mm Outer diameter : Accessories : ELECTRICAL CHARACTERISTICS : High Frequency Low Frequency Characteristic impedance : 50±2 Ohms Insulation Resistance : 5000 MOhms min Frequency range : DC-4GHz Voltage Rating : 500 Veff max Insertion Loss : 0.58 dB max @ 3GHz & 20ºC VSWR. : TBT MECANICAL CHARACTERISTICS : Recommend min. bend radius : 25 mm Cable crush resistance : NA Life ( connectors) : 500 cycles ENVIRONMENTAL CHARACTERISTICS : Operating temperature range : CUSTOMER'S APPROVAL -40°C to +85°C Remark : NA Service or Company's stamp Attachment : R141.083.000-TDS , Name Date C291.330.000-TDS Cable Assembly is RoHS compliant. Willy A Name Issue 2007-6-18 Date Creation Garet Xie Modification Checked by PART NUMBER :R284C0351012 TECHNICAL DATA SHEET CABLE ASSEMBLY Issue : NA Date : NA No.390, Yong He Road, Shanghai 200072, China Customer : Specification : NA Issue : NA Date : N/A All dimensions are in mm Connectors designation : Connector 1 : BNC Straight Plug Crimp Type Cable 5/50 D (R141.083.000) Cable designation : Flexible Cable 5/50S (RG223) C291.330.000 Lg: 1000 mm Nominal length : Cable colour : Connector 2 : BNC Straight Plug Crimp Type Cable 5/50 D (R141.083.000) Black 5.38 mm Outer diameter : Accessories : ELECTRICAL CHARACTERISTICS : High Frequency Low Frequency Characteristic impedance : 50±2 Ohms Insulation Resistance : 5000 MOhms min Frequency range : DC-4GHz Voltage Rating : 500 Veff max Insertion Loss : 1.05 dB max @ 3GHz & 20ºC VSWR. : TBT MECANICAL CHARACTERISTICS : Recommend min. bend radius : 25 mm Cable crush resistance : NA Life ( connectors) : 500 cycles ENVIRONMENTAL CHARACTERISTICS : Operating temperature range : CUSTOMER'S APPROVAL -40°C to +85°C Remark : NA Service or Company's stamp Attachment : R141.083.000-TDS , Name Date C291.330.000-TDS Cable Assembly is RoHS compliant. Willy A Name Issue 2007-6-18 Date Creation Garet Xie Modification Checked by
R284C0351011 价格&库存
很抱歉,暂时无法提供与“R284C0351011”相匹配的价格&库存,您可以联系我们找货
