R284C0351024
R284C0351024
    RADIALL
    2*BNC/RG142
R284C0351024 数据手册
PART NUMBER :R284C0351024 TECHNICAL DATA SHEET CABLE ASSEMBLY Cable Assembly Business Unit No.390, Yong He Road, Shanghai 200072, China Customer : Specification : xxxx Issue : NA Date : NA Issue : xxx Date : xxx All dimensions are in mm 500 +/-10 mm 237 +/- 5mm 2X R280.570.000 Radiall Radiall R284C0351024 RADIALL ww/yy R161.083.000 501.14.033A Connectors designation : Connector 1 : BNC Straight Plug Crimp Type for Cable 5/50D (R141.083.000) Cable designation : Flexible Cable 5/50D (RG142) C291.320.007 Lg: 500mm Nominal length : Cable colour : R141.083.000 RG142 C291.320.007 Connector 2 : N Straight Plug Full-Crimp Type for Cable 5/50D (R161.083.000) Brown 4.95mm Outer diameter : ELECTRICAL CHARACTERISTICS : High Frequency Low Frequency Characteristic impedance : 50±2 Ohms Insulation Resistance : 5000 MOhms min Frequency range : DC-4GHz Voltage Rating : 500 Veff max Insertion Loss max : 0.56dB max at 3GHz and 20℃ VSWR. : TBT MECANICAL CHARACTERISTICS : Recommend. Min. bending radius : 25 mm Cable crush resistance : NA Life ( connectors) : 500 cycles ENVIRONMENTAL CHARACTERISTICS : Operating temperature range : -55℃ to +155℃ Remark : NA CUSTOMER'S APPROVAL Service or Company's stamp Attachment : R141.083.000-TDS Name Date R161.083.000-TDS C291.320.007(RG142)-TDS Cable Assembly is RoHS compliant. Jack Lv Name A Issue 2007-06-08 Date Creation Garet Xie Modification Checked by PART NUMBER :R284C0351025 TECHNICAL DATA SHEET CABLE ASSEMBLY Cable Assembly Business Unit No.390, Yong He Road, Shanghai 200072, China Customer : Specification : xxxx Issue : NA Date : NA Issue : xxx Date : xxx All dimensions are in mm 1000 +/-20 mm 487 +/- 10mm 2X R280.570.000 Radiall Radiall R284C0351025 RADIALL ww/yy R161.083.000 501.14.033A Connectors designation : Connector 1 : BNC Straight Plug Crimp Type for Cable 5/50D (R141.083.000) Cable designation : Flexible Cable 5/50D (RG142) C291.320.007 Lg: 1m Nominal length : Cable colour : R141.083.000 RG142 C291.320.007 Connector 2 : N Straight Plug Full-Crimp Type for Cable 5/50D (R161.083.000) Brown 4.95mm Outer diameter : ELECTRICAL CHARACTERISTICS : High Frequency Low Frequency Characteristic impedance : 50±2 Ohms Insulation Resistance : 5000 MOhms min Frequency range : DC-4GHz Voltage Rating : 500 Veff max Insertion Loss max : 1.01dB max at 3GHz and 20℃ VSWR. : TBT MECANICAL CHARACTERISTICS : Recommend. Min. bending radius : 25 mm Cable crush resistance : NA Life ( connectors) : 500 cycles ENVIRONMENTAL CHARACTERISTICS : Operating temperature range : -55℃ to +155℃ Remark : NA CUSTOMER'S APPROVAL Service or Company's stamp Attachment : R141.083.000-TDS Name Date R161.083.000-TDS C291.320.007(RG142)-TDS Cable Assembly is RoHS compliant. Jack Lv Name A Issue 2007-06-08 Date Creation Garet Xie Modification Checked by
R284C0351024 价格&库存
很抱歉,暂时无法提供与“R284C0351024”相匹配的价格&库存,您可以联系我们找货
