R284C0351030
R284C0351030
    RADIALL
    2*N/RG58
R284C0351030 数据手册
PART NUMBER :R284C0351028 TECHNICAL DATA SHEET CABLE ASSEMBLY Issue : NA Date : NA No.390, Yong He Road, Shanghai 200072, China Customer : Specification : NA Issue : NA Date : N/A All dimensions are in mm Connectors designation : Connector 1 :BNC straight plug crimp type cable 2.6/50 S (R141.075.000) Cable designation : Flexible Cable 2.6/50S (RG174) C291.150.000 Lg: 1000 mm Nominal length : Cable colour : Outer diameter : Black 2.79 mm Accessories : Plastic Boots (R280.560.000 / R280.566.000) Connector 2 : SMB straight plug crimp type cable 2.6/50+75 S (R114.075.000) ELECTRICAL CHARACTERISTICS : High Frequency Low Frequency Characteristic impedance : 50±2 Ohms Insulation Resistance : 1000 MOhms min Frequency range : DC-1GHz Voltage Rating : 335 Veff max Insertion Loss : 1.64 dB max @ 1GHz & 20ºC VSWR. : TBT MECANICAL CHARACTERISTICS : Recommend min. bend radius : 10 mm Cable crush resistance : NA Life ( connectors) : 500 cycles ENVIRONMENTAL CHARACTERISTICS : Operating temperature range : CUSTOMER'S APPROVAL -40°C to +85°C Remark : NA Service or Company's stamp Attachment : R141.075.000-TDS , R114.075.000-TDS Name Date C291.150.000 (RG174)-TDS Cable Assembly is RoHS compliant. Jacob A Name Issue 2007-6-11 Date Creation Willy Modification Checked by
R284C0351030 价格&库存
很抱歉,暂时无法提供与“R284C0351030”相匹配的价格&库存,您可以联系我们找货
R284C0351030
  • 50+630.2395050+80.26910
  • 100+558.95210100+71.18980
