PART NUMBER :R284C0351055
TECHNICAL DATA SHEET
CABLE ASSEMBLY
Issue : NA
Date : NA
No.390, Yong He Road,
Shanghai 200072, China
Customer :
Specification : NA
Issue : NA
Date : N/A
All dimensions are in mm
Connectors designation :
Connector 1 : SMA Straight Plug Crimp Type
Cable 2.6/50 S (R124.071.120)
Cable designation :
Flexible Cable 2.6/50S (RG316)
C291.170.007
Lg: 500 mm
Nominal length :
Cable colour :
Outer diameter :
Brown
2.49 mm
Accessories :
HeatShrink Sleeves (9.11.95.000.70)
Connector 2 : SMA Right Angle Plug Crimp Type
Cable 2.6/50 S (R124.172.120)
ELECTRICAL CHARACTERISTICS :
High Frequency
Low Frequency
Characteristic impedance : 50±2 Ohms
Insulation Resistance : 5000 MOhms min
Frequency range : DC-3GHz
Voltage Rating : 250 Veff max
Insertion Loss : 0.96 dB max @ 3GHz & 20ºC
VSWR. : TBT
MECANICAL CHARACTERISTICS :
Recommend min. bend radius : 10 mm
Cable crush resistance : NA
Life ( connectors) : 100 cycles
ENVIRONMENTAL CHARACTERISTICS :
Operating temperature range :
CUSTOMER'S APPROVAL
-55°C to +135°C
Remark : NA
Service or
Company's stamp
Attachment : R124.071.120-TDS , R124.172.120-TDS
Name
Date
C291.170.007 (RG316)-TDS
Cable Assembly is RoHS compliant.
Peter
A
Name
Issue
2007-5-25
Date
Creation
Willy
Modification
Checked by
PART NUMBER :R284C0351056
CABLE ASSEMBLY
Issue : NA
Date : NA
Customer :
Specification : NA
Issue : NA
Date : N/A
R124.071.120
R124.172.120
RADIALL
R284C0351056
AAMM/YYMM
YearMonth
C291.170.007
9.11.95.000.70
30±2mm
9.11.95.000.70
30±2mm
487±5mm
501.14.040A
1000±20mm
Cable designation :
C291.170.007
Lg: 1000 mm
Nominal length :
Cable colour :
Outer diameter :
Brown
2.49 mm
Accessories :
High Frequency
Low Frequency
Insertion Loss : 1.81 dB max @ 3GHz & 20ºC
VSWR. : TBT
CUSTOMER'S APPROVAL
-55°C to +135°C
Remark : NA
Service or
Company's stamp
Name
Date
Peter
A
Name
Issue
2007-5-25
Date
Creation
Willy
Modification
Checked by
很抱歉,暂时无法提供与“R284C0351055”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+400.91190
- 15+392.86201
- 50+380.52161
- 100+373.33606
- 250+366.80659
