Technical Data Sheet
PAGE 1/1
ISSUE 12/07/2021
SERIES TestPro VNA Series
PART NUMBER
VB01621590635ZT
All dimensions are in mm
For more details, please see connectors TDS
________________________________________________________________________________________
DESIGNATION
____________
Cable
Connector Left
Connector Right
Assembly Length
Assembly Weight
VNA cable - P/N - VNA cable type VB
1.85 mm - NMD female - Stainless steel - P/N: R327920031
1.85 mm - Straight plug - Stainless steel - P/N: R327900061
635 mm / 25.00 inch (tolerance = ± 2%)
273.07 gr / 9.63 oz (tolerance = ± 5%)
ELECTRICAL
CHARACTERISTICS
Characteristic impedance
Max operating frequency
Assembly Typ Insertion Loss
Assembly Typ VSWR
Assembly Max. Insertion Loss
Assembly Max VSWR
Assembly Max Return Loss
Dielectric withstanding voltage
Insulation resistance
Other
50 Ohms
67.0 GHz
4.39 dB (at 20 °C, at 67.0 GHz )
1.45 (at 67.0 GHz )
5.09 dB (at 20 °C, at 67.0 GHz )
1.50 (at 67.0 GHz )
14.0 dB (at 67.0 GHz )
500 V
5000 M.Ohms
Typical amplitude stability (dB) 0,01 @ 50GHz / 0,02 @ 67GHz
Typical phase stability 1,5° @50GHz / 4,5° @ 67GHz
Note: Max IL are indicative only when superior to 40dB
MECHANICAL
CHARACTERISTICS
Cable Outer diameter
Static bending radius
Dynamic bending radius
Other
14.1 mm Max | 0.555 inch
50.0 mm | 1.97 inch
100.0 mm | 3.94 inch
Flexure life cycle > 50,000
Mating cycles durability > 5,000
ENVIRONMENTAL
CHARACTERISTICS
Temperature range
Fire resistance
RoHS
Lab conditions 23±5°C
Yes
Yes
This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior
written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary.
很抱歉,暂时无法提供与“VB01621600635ZT”相匹配的价格&库存,您可以联系我们找货
