VB01621600965ZT
VB01621600965ZT
    RADIALL
    CBL ASSY 1.85MM JACK 38
VB01621600965ZT 数据手册
Technical Data Sheet PAGE 1/1 ISSUE 12/07/2021 SERIES TestPro VNA Series PART NUMBER VB01621600965ZT All dimensions are in mm For more details, please see connectors TDS ________________________________________________________________________________________ DESIGNATION ____________ Cable Connector Left Connector Right Assembly Length Assembly Weight VNA cable - P/N - VNA cable type VB 1.85 mm - NMD female - Stainless steel - P/N: R327920031 1.85 mm - Straight jack - Stainless steel - P/N: R327920041 965 mm / 37.99 inch (tolerance = ± 2%) 366.13 gr / 12.91 oz (tolerance = ± 5%) ________________________________________________________________________________________ _____________________________ ELECTRICAL CHARACTERISTICS Characteristic impedance Max operating frequency Assembly Typ Insertion Loss Assembly Typ VSWR Assembly Max. Insertion Loss Assembly Max VSWR Assembly Max Return Loss Dielectric withstanding voltage Insulation resistance Other 50 Ohms 67.0 GHz 6.38 dB (at 20 °C, at 67.0 GHz ) 1.45 (at 67.0 GHz ) 7.43 dB (at 20 °C, at 67.0 GHz ) 1.50 (at 67.0 GHz ) 14.0 dB (at 67.0 GHz ) 500 V 5000 M.Ohms Typical amplitude stability (dB) 0,03 @ 50GHz / 0,04 @ 67GHz Typical phase stability 3,5° @50GHz / 5,5° @ 67GHz Note: Max IL are indicative only when superior to 40dB ________________________________________________________________________________________ _____________________________ MECHANICAL CHARACTERISTICS Cable Outer diameter Static bending radius Dynamic bending radius Other 14.1 mm Max | 0.555 inch 50.0 mm | 1.97 inch 100.0 mm | 3.94 inch Flexure life cycle > 50,000 Mating cycles durability > 5,000 ________________________________________________________________________________________ _________________________________ ENVIRONMENTAL CHARACTERISTICS Temperature range Fire resistance RoHS Lab conditions 23±5°C Yes Yes This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary.
VB01621600965ZT 价格&库存
很抱歉,暂时无法提供与“VB01621600965ZT”相匹配的价格&库存,您可以联系我们找货
