RC1190-RC232
RC1190-RC232
    RADIOCRAFTS
    Module
    LOW COST - GENERAL PURPOSE 902-9
RC1190-RC232 数据手册
Radiocrafts Embedded Wireless Solutions RC11xx-RC232 Low Cost Multi-Channel RF Transceiver Module Product Description The RC11XX-RC232 RF Transceiver Modules are compact surface-mounted high performance modules for FSK operation with embedded protocol. The modules are completely shielded and pre-certified for operation under the European radio regulations for license-free use. RC1170- and RC1190-RC232 conforms with regulations for operation under FCC (USA and Canada) and under the directives given by G.S.R. (India) respectively. Applications Wireless Sensor Networks Automatic Meter Reading Alarm and security systems Point-of-sales terminals Bar code scanners Telemetry stations Fleet management Features Small size (12.7 x 25.4 x 3.3 mm), shielded and optimized for SMD mounting Low sleep current consumption, well suited for battery operated equipment Embedded RC232™ protocol with Addressing and Error check Up to 1018 byte data buffer Two-wire UART interface for easy RS232/422/485 wire replacement (handshake optional) No external components No configuration required for single-channel use Easy to use data interface Wide supply voltage range, 2.0 – 3.9 V RC1140/80-RC232 conforms with EU R&TTE directive (EN 300 220, EN 301 489, EN 60950) RC1190-RC232 conforms with regulations for operation under FCC CFR 47 part 15 RC1170-RC232 complies with G.S.R.564(E) (G.S.R.168(E)). Quick Reference Data Parameter Frequency bands Number of channels Data rate Max output power Sensitivity Supply voltage Current consumption, RX / TX Current consumption, SLEEP Temperature range 2010 Radiocrafts AS RC1140RC232 433.05 – 433.79 17 1.2 - 100 10 -110 2.0 – 3.9 24 / 35 RC1170RC232 865.0 – 867.0 RC1180RC232 868.0 – 870.0 RC1190RC232 902 – 915 15 1.2 - 100 10 -110 2.0 – 3.9 24 / 35 16 1.2 - 100 10 -110 2.0 – 3.9 24 / 37 50 1.2 - 100 -1 -110 2.0 – 3.9 24 / 37 Typ. 0.3 Typ. 0.3 Typ 0.3 Typ 0.3 uA -40 to +85 -40 to +85 -40 to +85 -40 to +85 C RC11xx-RC232 Data Sheet (rev. 1.44) Unit MHz kbit/s dBm dBm Volt mA Page 1 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 Typical application circuit VCC Optional { To host meter or RS232/422/485 driver GND CTS RTS CONFIG TXD RXD GND GND VCC RESET NC GND RF GND Antenna NC See page 19 for additional schematic information regarding recommended Reset and Power supply filtering, and how to include a firmware upgrade connector. Quick Product Introduction How do I transmit data? Send your data to the RXD pin on the module. Use the UART format with settings (19200, 8, 1, N, no flow control). Up to 1018 of payload bytes are buffered in the module (total of 1024 including header bytes). The module will transmit the data when the max packet length is reached the unique end character is sent the modem timeout limit is reached The packet length, end character and timeout limit are configurable in-circuit. How do I receive data? Any received data packet with correct address and check sum will be sent on the TXD pin using the same UART format as for transmit. What about the antenna? In most cases a simple quarter wavelength wire or a PCB track will do. Connect a piece of wire to the RF pin with length corresponding to the quarter of a wavelength. For space limited products, contact Radiocrafts and we will recommend the best antenna solution for your application. How do I change the RF channel or any other parameter? To change configurable parameters, assert the CONFIG pin, and send the command string using the same serial interface as for transmitting data. Parameters can be changed permanently and stored in non-volatile memory in the module. RCTools RCTools is a powerful and easy to use PC suite that helps you during test, development and deployment of the RC11XX-RC232. Visit www.radiocrafts.com for a free download and full documentation. 2010 Radiocrafts AS RC11xx-RC232 Data Sheet (rev. 1.44) Page 2 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 Pin Assignment 30 GND 29 28 27 26 25 24 23 1 14 GND CTS/RXTX 2 13 VCC RTS/SLEEP 3 12 CONFIG 4 11 TXD 5 10 RXD 6 9 GND 7 8 15 16 17 18 19 20 21 RESET NC GND RF GND 22 Pin Description Pin no Pin name 1 GND Pin type Description System ground 2 Output 3 4 5 6 7 CTS/RXTX RTS/SLEEP CONFIG TXD RXD GND 2010 Radiocrafts AS Input Input Output Input UART Clear to Send or UART RXTX UART Request to Send. Set low to enter Sleep mode if RTS handshake is not in use. (See Note 2) Configuration Enable. Active low. Should normally be set high. (See Note 2) UART TX Data UART RX Data. Use external max 8k2 kohm pull-up resistor if connected to an open collector output from a host MCU or other high impedance circuitry like level shifters. (See Note 1) System ground RC11xx-RC232 Data Sheet (rev. 1.44) Equivalent circuit GND VCC Input: 20k Output: VCC GND Page 3 of 25 Radiocrafts Embedded Wireless Solutions 8 9 GND RF RC11xx-RC232 System ground RF I/O connection to antenna RF 10k 10 GND 11 12 NC RESET System ground Input GND Not connected Main reset (active low). Should normally be left open. Internal 12 kΩ pullup resistor. VCC 12k RESET 13 VCC Supply voltage input. Internally regulated. 1.8 V VREG VCC 2u2 14 GND System ground 15-22 RESERVED 23-30 RESERVED Test pins or pins reserved for future use. Do not connect! Test pins or pins reserved for future use. Do not connect! GND Note 1: For UART communication the TXD and RXD are used for serial data, and CTS and RTS for flow control (optional). RXD must be high when not sending data to the module and when module is in sleep mode. Note 2: The internal pull-ups on CONFIG and RTS/SLEEP pin are disabled in Sleep mode to minimise the sleep current. 2010 Radiocrafts AS RC11xx-RC232 Data Sheet (rev. 1.44) Page 4 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 Block Diagram GND GND Voltage Regulator CTS RTS Communication controller RESET NC CONFIG TXD VCC RF Transceiver GND RXD RF GND GND Circuit Description The module contains a communication controller with embedded RC232™ protocol software, a high performance RF transceiver and an internal voltage regulator. The communication controller handles the radio packet protocol, the UART interface and controls the RF transceiver. Data to be sent by the host is received at the RXD pin and buffered in the communication controller. The data packet is then assembled with preamble, start-of-frame delimiter (SOF), address information and CRC check sum before it is transmitted on RF. The preamble and SOF is always used. The address and CRC are optional. The RF transceiver modulates the data to be transmitted on RF frequency, and demodulates data that are received. Received data are checked for correct address and CRC by the communication controller. If the address matches the modules own address, and no CRC errors were detected, the data packet is sent to the host on the TXD line after removing the header. The asynchronous UART interface consists of RXD and TXD. Optionally CTS, RTS can be used for hardware handshake flow control. RXTX can be used to control the direction of an RS485 driver circuit. When the CONFIG pin is asserted the communication controller interprets data received on the RXD pin as configuration commands. There are commands to change the radio channel, the output power, the destination address etc. Permanent changes of the configuration is also possible and are then stored in internal non-volatile memory. The RF protocol and the configuration commands are described in detail in the RC232™ User Manual. The supply voltage is connected to the VCC pin. The module contains an internal voltage regulator and can therefore operate over a wide supply voltage range. 2010 Radiocrafts AS RC11xx-RC232 Data Sheet (rev. 1.44) Page 5 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 RC232™ Embedded Protocol The module offers a buffered packet radio in the RC232™ embedded protocol. Using the buffered packet radio mode, all data to be sent is stored in the module before they are transmitted by the RF circuitry. Likewise, when data is received they are stored in the module before they are sent to the host. This allows the communication controller to add address information and to do error check of the data. In buffered mode the UART interface is used to communicate with the host. The embedded protocol, configuration commands and configuration memory is described in the RC232™ User Manual. This protocol is used in a wide range of RF modules available from Radiocrafts. Please refer to the latest revision available on Radiocrafts web-site. Power Management The module can be set in SLEEP mode in order to reduce the power consumption. When the SLEEP pin is not enabled (RF_SLEEP_MODE = 0x00) the module can be set in Sleep mode by activating CONFIG and sending a ‘Z’ command. The module is woken up when CONFIG is deactivated (goes high). Note: During Sleep the CONFIG pin does not have any internal pull-up, so the CONFIG pin must be driven high in order to wake the module. Any activity on the RXD pin will make the module wake up, but immediately return to Sleep as long as CONFIG is kept low. Such activity on the RXD pin should be avoided in order to reduce current consumption. When the SLEEP pin is enabled (RF_SLEEP_MODE = 0x02) the module can be set in Sleep mode by activating RTS/SLEEP (asserting low). The module is woken up when RTS/SLEEP is deactivated (goes high). Note: During Sleep the RTS/SLEEP pin does not have any internal pullup, so the RTS/SLEEP pin must be driven high in order to wake up the module. Any activity on the RXD or CONFIG pins will not make the module wake up. Activity on module pin 16 and 17 can wake the module and must be avoided (do not connect, as previously stated in this document). CONFIG must be high when awakening the module to avoid setting the module directly in configuration mode. All configuration settings and RAM values are retained during Sleep. The pull-ups on RTS/SLEEP and CONFIG pin are disabled during sleep mode in order to minimise the sleep current consumption. If the module is shut completely off, all configuration settings in non-volatile memory is restored, but values in RAM are overwritten with default settings. 2010 Radiocrafts AS RC11xx-RC232 Data Sheet (rev. 1.44) Page 6 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 Enter SLEEP Mode Using RTS/SLEEP pin RTS/SLEEP MODE IDLE SLEEP IDLE Enter SLEEP Mode Using CONFIG and Z Comand CONFIG UART Comand MODE 2010 Radiocrafts AS Z IDLE CONFIG SLEEP RC11xx-RC232 Data Sheet (rev. 1.44) IDLE Page 7 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 Timing Information The figure and table below shows the timing information for the module when changing between different operating states. The IDLE state is the normal state where the module search for preamble on the air and wait for a character to be received on the UART. RXD is the state when receiving characters from the host filling up the internal buffer. TX state is when the data is transmitted on the air. RX state is when data is received from the air after preamble detection. TXD is the state where the received data is sent to the host on the UART. CONFIG is the state entered by asserting the CONFIG pin and used during parameter configuration, while MEMORY CONFIG is the sub-state entered by the ‘M’ command where the configuration memory is being programmed. Note the limitation on maximum number of write cycles using the ‘M’ command, see Electrical Specifications. tTXD tTXD-IDLE tRX-TXD RX IDLE TXD Preamble detected First character on UART TXD tRXD-CTS IDLE RXD First character on UART RXD 2010 Radiocrafts AS tPACKET_TIMEOUT IDLE Last character on UART TXD tTX tTX-IDLE tRXD-TX TX IDLE Last character on UART RXD RC11xx-RC232 Data Sheet (rev. 1.44) Page 8 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 tOFF-IDLE OFF IDLE tRESET-IDLE RESET IDLE tSLEEP-IDLE SLEEP IDLE tCONFIG-PROMPT IDLE tC-CONFIG CONFIG MEMORY CONFIG ’M’ Symbol tRX-TXD Value 180 us tTXD Min 590 us tTXD-IDLE 900 us TRXD-CTS 20 us tRXD-TX 960 us TTX-IDLE 960 us tOFF-IDLE tRESET-IDLE tSLEEP-IDLE tCONFIG- 3.2 ms 3.0 ms 1.28 ms 590 us IDLE ’X’ ’C’ CONFIG set low CONFIG tCONFIG-IDLE CONFIG tCONFIG-IDLE tMEMORY-CONFIG CONFIG 0xFF IDLE ’X’ Description / Note Time from last byte is received from the air until first character is sent on the UART tTXD = # bytes received x 590 us/char (10 bits at 19.2 kBd + 70 us delay per character) Time from last character is sent on the UART until module is in IDLE mode (ready for RXD and RX) Time from last character is received by the UART (including any timeout) until CTS is activated Time from last character is received by the UART (including any timeout) until the module sends the first byte on the air. Time from last character is sent on the air until module is in IDLE mode (ready for RXD and RX) Time from CONFIG pin is set low until prompt (“>”) PROMPT tC#-CONFIG 1.1 ms tMEMORY- 30.52 ms CONFIG TCONFIG- Delay after channel-byte is sent until prompt (“>”). (For other commands like ’M’, ’T’ there is no delay but immediate prompt) In this period the internal flash is programmed. Do not reset, turn the module off, or allow any power supply dips in this period as it may cause permanent error in the Flash configuration memory. After 0xFF the host should wait for the ‘>’ prompt before any further action is done to ensure correct re-configuration. 1.42 ms IDLE tTX Min 20 ms TRSSI 4 ms 2010 Radiocrafts AS tTX = # bytes to send x 1.67 ms/byte (at 4.8 kbit/s) + 7 bytes preamble, sync and length + 2 bytes address + 2 bytes CRC Time from end of S command to start of RSSI byte received on UART RC11xx-RC232 Data Sheet (rev. 1.44) Page 9 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 RF Frequency, Output Power Levels and Data Rates The following table shows the available RF channels and their corresponding frequencies, nominal output power levels and available data rates. Model RC1140-RC232 RC1170-RC232 2010 Radiocrafts AS RF channel 1: 433.100 MHz 2: 433.200 MHz 3: 433.300 MHz 4: 433.400 MHz 5: 433.500 MHz 6: 433.600 MHz 7: 433.700 MHz 8: 433.800 MHz 9: 433.900 MHz 10: 434.000 MHz 11: 434.100 MHz 12: 434.200 MHz 13: 434.300 MHz 14: 434.400 MHz 15: 434.500 MHz 16: 434.600 MHz 17: 434.700 MHz 1: 865.100 MHz 2: 865.300 MHz 3: 865.500 MHz 4: 865.700 MHz 5: 865.900 MHz 6: 866.100 MHz 7: 866.300 MHz 8: 866.500 MHz 9: 866.700 MHz 10: 866.900 MHz 11: 867.100 MHz 12: 867.300 MHz 13: 867.500 MHz 14: 867.700 MHz 15: 867.900 MHz Output power 1: -20 dBm 2: -10 dBm 3: 0 dBm 4: 5 dBm 5: 10 dBm Data rate 1: 1.2 kbit/s 2: 4.8 kbit/s 3: 19.0 kbit/s 4: 32.768 kbit/s 5: 76.8 kbit/s 6: 100 kbit/s 7: For future use 1: -20 dBm 2: -10 dBm 3: 0 dBm 4: 5 dBm 5: 10 dBm 1: 1.2 kbit/s 2: 4.8 kbit/s 3: 19.0 kbit/s 4: 32.768 kbit/s 5: 76.8 kbit/s 6: 100 kbit/s 7: For future use RC11xx-RC232 Data Sheet (rev. 1.44) Page 10 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 RC1180-RC232 1: 868.050 MHz 2: 868.150 MHz 3: 868.250 MHz 4: 868.350 MHz 5: 868.450 MHz 6: 868.550 MHz 7: 868.650 MHz 8: 868.750 MHz 9: 868.850 MHz 10: 868.950 MHz 11: 869.050 MHz 12: 869.150 MHz 13: 869.525 MHz 14: 869.750 MHz 15: 869.850 MHz 16: 869.950 MHz 1: -20 dBm 2: -10 dBm 3: 0 dBm 4: 5 dBm 5: 9 dBm 1: 1.2 kbit/s 2: 4.8 kbit/s 3: 19.0 kbit/s 4: 32.768 kbit/s 5: 76.8 kbit/s 6: 100 kbit/s 7: For future use RC1190-RC232 50 channels: 1: -20 dBm 2: -10 dBm 3: 0 dBm 4: not recommended* 5: not recommended* 1: 1.2 kbit/s 2: 4.8 kbit/s 3: 19.0 kbit/s 4: 32.768 kbit/s 5: 76.8 kbit/s 6: 100 kbit/s 7: For future use 902+nx0.5 MHz for n = [1, 50] default: 1: 902.5 MHz * Not recommended due to higher output power than the FCC limit. RF channel and output power level can be set using the configuration commands ‘C’ and ‘P’ respectively. The data rate can only be changed in configuration memory by using the ‘M’ command setting RF_DATA_RATE. The default RF channel and output power level can be set in the configuration memory by using the ‘M’ command setting RF_CHANNEL and RF_POWER. The default values are used after power ON and RESET. The default factory settings are shown in bold in the table above. For channels 1, 6, 7, 12, 14 and 16 the maximum RF data rate is 19.2 kbit/s due to limitations in modulation bandwidth at the given sub band-edge. For more details on changing the RF channel, output power or data rate, refer to the description of the configuration commands. The use of RF frequencies, maximum allowed RF power and duty-cycles are limited by national regulations. The RC1180-RC232 and RC1140-RC232 is complying with the applicable directives within the European Union when used within these limitations. RC1190-RC232 is pending approval under FCC for use in the US and Canada. For more information see section “Regulatory Compliance Information”. 2010 Radiocrafts AS RC11xx-RC232 Data Sheet (rev. 1.44) Page 11 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 RSSI Reading The module provides a digital Received Signal Strength Indicator (RSSI) through the ‘S’ command, or attached to received messages. The module returns an 8 bit character (one byte) indicating the current input signal strength (followed immediately by a second character which is the prompt (‘>’) when in command mode). The signal strength can be used as an indication of fading margin, or as a carrier sense signal to avoid collisions. The signal strength measure by the S command is the instantaneous value. The RSSI value appended to a received message (RSSI_MODE = 1) is the signal strength of that received packet. The RSSI value increases with increased input signal strength in 0.5 dB steps. Input signal strength is given by (typ.): P = - RSSI / 2 [dBm] The dynamic range of the RSSI (P) goes from the Sensitivity level up to typical -30 dBm (RSSI saturation level). Temperature Reading The module provides readings of a digital temperature monitoring sensor (TEMP) through the ‘U’ command. The module returns an 8 bit character (one byte) indicating the current temperature in degrees Celsius (°C) followed immediately by a second character which is the prompt (‘>’). The TEMP value increases with increased temperature in 1 °C steps and accuracy of +/- 2 °C. Temperature is given by: T = TEMP(dec) – 128 [°C] (example: TEMP=0x98 equals +24 °C) Power Supply voltage Reading The module provides readings of an internal power supply voltage monitoring sensor (VCC) through the ‘V’ command. The module returns an 8 bit character (one byte) indicating the current power supply voltage level followed immediately by a second character which is the prompt (‘>’). The command can be useful for battery power monitoring. The VCC value increases with increased power supply voltage in 30 mV steps. The power supply voltage is given by: V = VCC(dec)*0.030 [V] (example: VCC=0x68 equals 3.12 V) 2010 Radiocrafts AS RC11xx-RC232 Data Sheet (rev. 1.44) Page 12 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 Module Configuration The configuration of the module can be changed in-circuit from the host during operation, at the time of installation of the equipment, at the manufacturing test, or even as a standalone module. The configuration is changed sending commands on the UART interface after the module is set in configuration mode. The configuration mode is entered by asserting the CONFIG pin (set low). In command mode the module will respond by sending a ‘>’ prompt on the TXD pin. This indicates that the module is ready to receive commands. The CONFIG pin can then be deasserted. Note that the CONFIG pin must be de-asserted before the Exit command (‘X’) is sent to the module in order to return to normal operation. After a command is executed, the module responds with the ‘>’ prompt character again indicating it is ready for a new command. Do not send a new command before the ‘>’ prompt is received. The time required to execute a command can vary depending on the command (see the Timing Information section). There is no ‘>’ prompt after the ‘X’ exit command. The parameters that are set by commands directly take immediate effect after returning to normal operation (IDLE), but will not be stored in non-volatile memory, and will be lost in case the supply power is turned off or if the module is reset. These parameters are for example the radio channel and output power. A list of commands is shown in the table below. Parameter Command Argument in hex (decimal) Channel ‘C’ – 0x43 0x01-0x0C (1-12) Output power ‘P’ – 0x50 0x01-0x05 (1-5) Signal Strength (RSSI) Destination address Temperature monitoring Battery monitoring Memory Read one byte ‘S’ – 0x53 Returns one byte indicating the signal strength ‘T’ – 0x54 0x00 – 0xFF (0-255) Memory configuration Returns one byte indicating the temperature. ‘V’ – 0x56 Returns one byte indicating the power supply voltage. ‘Y’ – 0x59 0x00 – 0x7F (The argument is the address in the configuration memory.) ‘M’ – 0x4D (Address, Data): see list of parameters below. 0xFF exits memory configuration. ‘U’ – 0x55 Memory Reset ‘@RC’ No arguments, but CONFIG must be low for this command. Exit command ‘X’ – 0x58 (none) Sleep mode ‘Z’ – 0x5A (none) 2010 Radiocrafts AS RC11xx-RC232 Data Sheet (rev. 1.44) Note Data is stored in volatile memory only. Data is stored in volatile memory only. See page 10 for details Data is stored in volatile Memory only. See page 10 for details See page 10 for details Return one byte value from the configuration memory. Used to enter memory configuration menu. Parameters changed are stored in non-volatile memory. Resets the configuration memory back to factory default values in the whole non-volatile memory. Exit to normal operation mode. All changes of parameters take effect. CONFIG pin must be Page 13 of 25 Radiocrafts Embedded Wireless Solutions Test mode 0 ‘0’ – 0x30 (none) Test mode 1 Test mode 2 ‘1’ – 0x31 ‘2’ – 0x32 (none) (none) Test mode 3 Test Mode 4 ‘3’ – 0x33 ‘4’ – 0x34 (none) (none) RC11xx-RC232 asserted while in SLEEP mode. Exit sleep mode by releasing CONFIG pin. List all configuration memory parameters TX carrier TX modulated signal PN9 sequence RX mode Radio off mode (RX and TX off) Note: ASCII characters are written as ‘X’, hexadecimal numbers are written like 0x00, and decimal numbers are written like 10 throughout the text. A table of ASCII characters and their respective hex and decimal values are found in the Appendix. Commands must be sent as ASCII characters or their corresponding binary value. All arguments must be sent as binary values to the module (not as ASCII representation for hex or decimal). Any invalid command will be ignored and the ‘>’ prompt will be re-sent. The CONFIG line must be de-asserted after the first ‘>’ prompt was received, but before the ‘X’ command. To make permanent changes to default values and other parameters, the Memory Configuration command ‘M’ is used. This command should be followed by pairs of byte being the memory address and the new value to be stored at that address. In order to exit the Memory Configuration mode command ‘X’ must be sent. Example: To select RF channel 3, send the follow sequence after asserting the CONFIG line and the ‘>’ prompt is received: Command Hex Response CONFIG asserted ‘>’ ‘C’ 0x43 ‘>’ 3 0x03 ‘>’ [A new command could be issued here] ‘X’ 0x58 (none) Comment/Note De-assert CONFIG after ‘>’ prompt Wait for ‘>’ prompt Module returns to IDLE state It is important to enter Test mode 3 before exiting the configuration mode (‘X’) if Test mode 1 or 2 has been used. This will ensure proper operation in normal mode. 2010 Radiocrafts AS RC11xx-RC232 Data Sheet (rev. 1.44) Page 14 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 Configuration Memory The table below shows the complete list of configurable parameters stored in non-volatile memory. These values can be changed using the ‘M’ command. All addresses and arguments must be sent as binary values to the module (not as ASCII representation for hex or decimal). Parameter Radio configuration RF_CHANNEL RF_POWER Description Address hex Argument (dec) Factory setting hex (dec) Comment Default RF channel 0x00 RC1140: 1-17 RC1180: 1-16 RC1190: 1-50 1-5 0x01 (1) See table page 10 for details 0x05 (5) See table page 10 for details 1-7 0x03 (3) See table page 10 for details 0: SLEEP pin disabled 1: reserved 2: SLEEP pin enabled 0x00 (0) 0-1 0x00 (0) When enabled, the module will enter sleep mode by asserting sleep pin low. Do not use in combination with enabled UART flow control. 0: No RSSI append No 1: RSSI append 0x01-0x03 (0-3) 0x00 (0) 0x01-0x80 (1-128) 0x80 (128) 0x00-0xFE (0-254) 0x00 (0): None 0x01 (1): 32 ms 0x02 (2): 48 ms 0x03 (3): 64 ms 0x7C (124): 2 s 0xF9 (249): 4 s 0x7C (124) 0x00: Off 0x01-0xFF: On 0x00 SLEEP_MODE Default RF 0x01 output power Default RF data 0x02 rate Sleep Mode 0x04 RSSI_MODE Append RSSI RF_DATA_RATE 0x05 Radio packet configuration PACKET_LENGTH_H Max packet 0x0E length high byte. PACKET_LENGTH_L Max packet 0x0F length low byte. PACKET_TIMEOUT Time before modem timeout and transmitting the buffer PACKET_END_ CHARACTER 0x10 0x11 Medium access, addressing and network management ADDRESS_MODE 0x14 0, 2, 8 CRC_MODE 0x15 UNIQUE_ID1 (UID1) SYSTEM_ID1 (SID1) UNIQUE_ID2 (UID2) SYSTEM_ID2 (SID2) UNIQUE_ID3 (UID3) 0x19 0x1A 0x1B 0x1C 0x1D 2010 Radiocrafts AS Timeout value is (PACKET_TIMOEOUT x 16 ms) + 0/16 ms min/max 0x02 (2) 0x02 (2) 0-255 0-255 0-255 0-255 0-255 Packet length > 128 was introduced in FW rev 1.28. For older revisions always use PACKET_LENGTH_H=0. If PACKET_LENGHT_H=0 for FW rev 1.28 and newer, then the packet format is backward compatible with FW rev 1.27 and older. None means packet timeout is disabled (not 0 s). 0x01 (1) 0x01 (0) 0x01 (1) 0x01 (0) 0x01 (1) RC11xx-RC232 Data Sheet (rev. 1.44) 0xFE (254) is max, giving 4.080 sec. Default is 2 s = 0x7C (124) 0: No end character 1-255: Use value as end character 0: No addressing 2: 1 byte addressing 8: 4 byte addressing (FW rev 1.28 and newer) Using addressing adds the SID and DID bytes to the radio packet. 0: None 2: CRC16 ADDRESS_MODE=8 UID=UID4:UID3:UID2:UID1 SID=SID4:SID3:SID2:SID1 DID=DID4:DID3:DID2:DID1 Page 15 of 25 Radiocrafts Embedded Wireless Solutions SYSTEM_ID3 (SID3) 0x1E UNIQUE_ID4 (UID4) 0x1F SYSTEM_ID4 (SID4) 0x20 DESTINATION_ID1(D 0x21 ID1) DESTINATION_ID2(D 0x22 ID2) DESTINATION_ID3(D 0x23 ID3) DESTINATION_ID4(D 0x24 ID4) BROADCAST_ 0x28 ADDRESS Data and configuration interface, UART Serial Port UART_BAUD_RATE Baud rate 0x30 UART_NUMBER_OF _BITS UART_PARITY 0x31 UART_STOP_BITS 0x33 0x32 RC11xx-RC232 0-255 0-255 0-255 0-255 0x01 (0) 0x01 (1) 0x01 (0) 0x01 (1) 0-255 0x01 (1) 0-255 0x01 (1) 0-255 0x01 (1) 0-255 0xFF (255) 0x00: Not used 0x01: 2400 0x02: 4800 0x03: 9600 0x04. 14400 0x05: 19200 0x06: 28800 0x07: 38400 0x08: 56700 0x09: 76800 0x0A: 115200 0x0B: 230400 8: 8 bits 9: 8 bits +1 parity 0: even parity 1: odd parity 1: 1 stop bit 2: 2 stop bits 0x05 (5) BID=BID:BID:BID:BID ADDRESS_MODE=2 UID=UID1 SID=SID1 DID=DID1 BID=BID BE CAREFUL IFCHANGING AS HOST MAY LOOSE CONTACT WITH MODULE! Does not take effect until module is re-booted / reset. 0x08 (8) 0x00 (0) 0x01 (1) BE CAREFUL IF CHANGING AS HOST MAY LOOSE CONTACT WITH MODULE! Parity bit only an option when address 0x31=0x09 (9 bits) Does not take effect until module is re-booted / reset. UART_FLOW_CTRL UART flow control PART_NUMBER HW_REV_NO FW_REV_NO 0x35 0x3C0x49 0x4B0x4E 0x500x53 0: None 1:CTS only 3:CTS/RTS 4:RXTX(RS485) 0x00 (0) RCxxxx RC232 x.yz x.yz x, y and z; Any number 0d9d x, y and z; Any number 0d9d Note: Address location not listed should not be changed from the default value. Antenna Connection The antenna should be connected to the RF pin. The RF pin is matched to 50 Ohm. If the antenna connector is placed away from the module at the motherboard, the track between the RF pin and the connector should be a 50 Ohm transmission line. On a two layer board made of FR4 the width of a microstrip transmission line should be 1.8 times the thickness of the board, assuming a dielectric constant of 4.8. The line should be run at the top of the board, and the bottom side should be a ground plane. Example: For a 1.6 mm thick FR4 board, the width of the trace on the top side should be 1.8 x 1.6 mm = 2.88 mm. 2010 Radiocrafts AS RC11xx-RC232 Data Sheet (rev. 1.44) Page 16 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 The simplest antenna to use is the quarter wave whip antenna. A quarter wave whip antenna above a ground plane yields 37 Ohm impedance and a matching circuit for 50 Ohm are usually not required. A PCB antenna can be made as a copper track where the ground plane is removed on the back side. The rest of the PCB board should have a ground plane as large as possible, preferably as large as the antenna itself, to make it act as a counterweight to the antenna. If the track is shorter than a quarter of a wavelength, the antenna should be matched to 50 ohms. The lengths of a quarter wave antenna for different operational frequencies are given in the table below. Frequency [MHz] 433 865-867 868 915 2010 Radiocrafts AS Length [cm] 16.4 8.2 8.2 7.8 RC11xx-RC232 Data Sheet (rev. 1.44) Page 17 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 PCB Layout Recommendations The recommended layout pads for the module are shown in the figure below. All dimensions are in thousands of an inch (mil). The circle in upper left corner is an orientation mark only, and should not be a part of the copper pattern. A PCB with two or more layers and with a solid ground plane in one of the inner- or bottom layer(s) is recommended. All GND-pins of the module shall be connected to this ground plane with vias with shortest possible routing, one via per GND-pin. On the back side of the module there are several test pads. These test pads shall not be connected, and the area underneath the module should be covered with solder resist. If any routing or vias is required under the module, the routing and vias must be covered with solder resist to prevent short circuiting of the test pads. It is recommended that vias are tented. Reserved pins should be soldered to the pads but the pads must be left floating. Note that Radiocrafts technical support team is available for schematic and layout review of your design. 2010 Radiocrafts AS RC11xx-RC232 Data Sheet (rev. 1.44) Page 18 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 Mechanical Drawing 1.9 mm Radiocrafts Part nr: RCXXXX Lot code: YYYYWW (YYYY=prod. year, WW= prod. week) Hardware revision: A.BB Approval marking: NN = CE, FCC or others Top view RCXXXX YYYYWW A.BB NN End view 3.2 mm Side view 10.9 mm 23.6 mm 3.3 mm Bottom view 0.38 mm 25.4 mm 12.7 mm 2.1 mm 1.4 mm 2.1 mm 8.5 mm 0.9 mm 13.6 mm Drawings are not to scale Mechanical Dimensions The module size is 12.7 x 25.4 x 3.3 mm. Carrier Tape and Reel Specification Carrier tape and reel is in accordance with EIA Specification 481. Tape width 44 mm Component Hole pitch pitch 16 mm 4 mm Reel diameter 13” Units per reel Max 1000 Soldering Profile Recommendation JEDEC standard IEC/JEDEC J-STD-020B (page 11 and 12), Pb-Free Assembly is recommended. The standard requires that the heat dissipated in the “surroundings” on the PCB is taken into account. The peak temperature should be adjusted so that it is within the window specified in the standard for the actual motherboard. Aperture for paste stencil is normally areal-reduced by 20-35%. Nominal stencil thickness of 0.1 0-12 mm is recommended. Consult your production facility for best experience aperture reduction. 2010 Radiocrafts AS RC11xx-RC232 Data Sheet (rev. 1.44) Page 19 of 25 Radiocrafts Embedded Wireless Solutions Absolute Maximum Ratings Parameter Min Supply voltage, VCC -0.3 Voltage on any pin -0.3 Input RF level Storage temperature Operating temperature -50 -40 RC11xx-RC232 Max 3.9 VCC+0.3V max 3.9V 10 150 85 Unit V V dBm C C Caution ! ESD sensitive device. Precaution should be used when handling the device in order to prevent permanent damage. Under no circumstances the absolute maximum ratings given above should be violated. Stress exceeding one or more of the limiting values may cause permanent damage to the device. Electrical Specifications T=25 C, VCC = 3.0V if nothing else stated. Parameter Min Operating frequency RC1140 433.05 RC1170 865.0 RC1180 868.0 RC1190 902.0 Number of channels RC1140 RC1170 RC1180 Rc1190 Input/output impedance Typ. Max Unit 434.79 868.0 870.0 928.0 MHz Condition / Note 17 15 16 50 Ohm 50 Data rate 1.2 4.8 19.0 32.768 76.8 100 Frequency stability Frequency stability aging Transmit power FSK deviation Channel Filter bandwidth kbit/s +/-40 1 ppm ppm/year -20 9 dBm 5.2 58 127 540 kHz kHz -36 -30 dBm Spurious emission, TX < 1 GHz > 1 GHz 47 – 74 MHz 87.5 – 118 MHz 174 – 230 MHz 470 – 862 MHz Sensitivity 1.2 kbit/s 4.8 kbit/s 19.0 kbit/s 32.768 kbit/s 76.8 kbit/s 100 kbit/s Adjacent channel rejection -110 -106 -104 -101 -99 -97 29 dBm Alternate channel selectivity 53 dB Image channel rejection 28 dB 2010 Radiocrafts AS Including 10 years of aging. Starting after 10 years Depends on data rate Depends on data rate -54 -54 -54 -54 1% packet error rate, 20 bytes packet length dB RC11xx-RC232 Data Sheet (rev. 1.44) Page 20 of 25 Radiocrafts Embedded Wireless Solutions Blocking / Interferer rejection / desensitization +/- 1 MHz +/- 2 MHz +/- 5 MHz +/- 10 MHz Saturation Spurious emission, RX Supply voltage Current consumption, RX/IDLE RC1140 TX Current consumption, TX -20 dBm -10 dBm 0 dBm 5 dBm 9 dBm RC1170/1180/1190 TX Current consumption, TX -20 dBm -10 dBm 0 dBm 5 dBm 9 dBm Current consumption, SLEEP Digital I/O Input logic level, low Input logic level, high Output logic level, low (1μA) Output logic level, high(-1μA) RESET pin Input logic level, low Input logic level, high UART Baud Rate tolerance Configuration memory write cycles RC11xx-RC232 dB 30 35 50 60 43 49 68 72 -14 -57 3.9 2.0 Wanted signal 3 dB above sensitivity level, CW interferer. Minimum numbers corresponds to class 2 receiver requirements in EN300220. dBm dBm V 24 mA 18 20 22 25 35 mA 16 17 22 30 37 0.3 mA 1.0 uA 30 % V 70 % 0 Apply over entire supply voltage range Apply over entire supply voltage range Of VCC Of VCC VCC 30 % V Minimum 250 ns pulse width 70 % +/- 2 % 1000 UART receiver and transmitter The guaranteed number of write cycles using the ‘M’ command is limited Regulatory Compliance Information The use of RF frequencies and maximum allowed RF power is limited by national regulations. The RC1140-RC232 and RC1180-RC232 has been designed to comply with the R&TTE directive 1999/5/EC. According to R&TTE directives, it is the responsibility of Radiocrafts’ customers (i.e. RC11XX-RC232 end user) to check that the host product (i.e. final product) is compliant with R&TTE essential requirements. The use of a CE marked radio module can avoid re-certification of the final product, provided that the end user respects the recommendations given by Radiocrafts. A Declaration of Conformity is available from Radiocrafts on request. The RC1190-RC232 has been tested towards FCC regulations for license free operation under part 15. However, a final approval is required by FCC for the end product. The RC1170-RC232 has been tested towards G.S.R.564(E) and G.S.R.168(E) for license free use in India. The Gazettes are available from Radiocrafts on request. The relevant regulations are subject to change. Radiocrafts AS do not take responsibility for the validity and accuracy of the understanding of the regulations referred above. Radiocrafts only guarantee that this product meets the specifications in this document. Radiocrafts is exempt from any responsibilities related to regulatory compliance. 2010 Radiocrafts AS RC11xx-RC232 Data Sheet (rev. 1.44) Page 21 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 Power Supply Noisy external circuitry may under certain scenarios affect the transmitted signal on RC11XX-RC232 and precaution should be taken for EU R&TTE conformity. Example of circuits that can generate noise on the RC11XX-RC232 transmitted spectrum may be DC/DC converters and some level converters like RS232 and RS485. To increase spectrum margin it is important to add an EMI filter bead on the VCC pin of the RC11XX-RC232 module. Alternatively the RC11XX-RC232 may be powered form a separate voltage regulator. This will ensure that potential switching noise is filtered out from the power supply to the RC11XX-RC232. A block diagram of a typical PC serial port interface is illustrated below. Suggested part numbers: Component EMI filter bead Manufacturer Murata Part number BLM11A102S, ordering code BLM18xx102xN1D Programming Interface For future firmware updates and possible custom variants it is recommended to include a 2x5 pins programming connector to the module programming pins. The connector should be a 2.54 mm pitch pin-row (same pitch in both directions), SMD or through-hole version, with the connections shown below. Reset connection To minimize effect of noise on the Reset-line, the Reset pin on the module (pin 12) must be connected to external circuitry via an RC-network. It is recommended to connect Reset to either a supervisory circuit or microcontroller I/O-pin. If the Reset is driven by a push-pull output, an additional series resistor of 5k6 shall be inserted as shown in the figure, to allow an external programmer used for firmware upgrade to assert Reset low. In noisy surroundings and where Reset is not driven by a pushpull output, it is recommended that the connection ‘A’ below is pulled to VCC via one or more resistors where the equivalent pull-up resistor is close to 5k6 VCC EMI f ilter bead, place close to VCC pin Place directly on Reset-pin as close as possible on pin VCC RS232-, RS485-, RS422- or USB levelshif ter or microcontroller (MCU) GND VCC RESET RTS CTS CONFIG TXD RXD 2k7 A 5k6 Connect to supervisory circuit or MCU I/O-pin 1nF Connect to programming connector pin Reset To programming connector GND To Pin 20, Debug clock 1 2 To VCC 3 4 To Pin 19, Debug Data 7 To Pin 12, Reset 2010 Radiocrafts AS RC11xx-RC232 Data Sheet (rev. 1.44) Page 22 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 Appendix: ASCII Table HEX 0 1 2 3 4 5 6 7 8 9 0A 0B 0C 0D 0E 0F 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 20 21 22 23 24 25 26 27 28 29 2A 2B 2C DEC 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 CHR NUL SOH STX ETX EOT ENQ ACK BEL BS HT LF VT FF CR SO SI DLE DC1 DC2 DC3 DC4 NAK SYN ETB CAN EM SUB ESC FS GS RS US SP ! " # $ % & ' ( ) * + , 2D 2E 2F 30 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 3E 3F HEX 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F 60 61 62 63 64 65 66 67 68 69 6A 6B 6C DEC 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 CHR @ A B C D E F G H I J K L M N O P Q R S T U V W X Y Z [ \ ] ^ _ ` a b c d e f g h i j k l . / 0 1 2 3 4 5 6 7 8 9 : ; < = 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 7B 7C 7D 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 m n o p q r s t u v w x y z { | } 62 > 7E 126 ~ 63 ? 7F 127 DEL 2010 Radiocrafts AS CTRL ^@ ^A ^B ^C ^D ^E ^F ^G ^H ^I ^J ^K ^L ^M ^N ^O ^P ^Q ^R ^S ^T ^U ^V ^W ^X ^Y ^Z RC11xx-RC232 Data Sheet (rev. 1.44) Page 23 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 Document Revision History Document Revision 1.0 1.1 Changes First release Pull-up description during sleep and additional info regarding channel selection is added. Updated timing table, Reset connection. Minor correction Mechanical drawing update, Product status change and minor corrections New commands added (U, V, Y and @RC). Sensitivity corrected. I/O pin direction and stencil thickness included. RSSI timing added. Updated application circuit. Minor text correction RTS/SLEEP pin info and configuration added. VCC range clarified to be max 3.9 V. RSSI dynamic range added and minor corrections. -Max packet length increased to 1024 bytes. -New address mode option for 4 byte addressing -UART number of bits and parity option added -Introduced part number RC1170-RC232 Changes harmonize to RC232 firmware revision 1.28 -Clarification of data rate limitations for EN300-220-2 V2.4.1 compliance 1.2 1.21 1.30 1.40 1.41 1.42 1.43 1.44 Product Status and Definitions Current Data Sheet Identification Status Product Status Advance Information Planned or under development Preliminary Engineering Samples and First Production No Identification Noted Full Production Obsolete Not in Production X 2010 Radiocrafts AS Definition This data sheet contains the design specifications for product development. Specifications may change in any manner without notice. This data sheet contains preliminary data, and supplementary data will be published at a later date. Radiocrafts reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. This data sheet contains final specifications. Radiocrafts reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. This data sheet contains specifications on a product that has been discontinued by Radiocrafts. The data sheet is printed for reference information only. RC11xx-RC232 Data Sheet (rev. 1.44) Page 24 of 25 Radiocrafts Embedded Wireless Solutions RC11xx-RC232 Disclaimer Radiocrafts AS believes the information contained herein is correct and accurate at the time of this printing. However, Radiocrafts AS reserves the right to make changes to this product without notice. Radiocrafts AS does not assume any responsibility for the use of the described product; neither does it convey any license under its patent rights, or the rights of others. The latest updates are available at the Radiocrafts website or by contacting Radiocrafts directly. As far as possible, major changes of product specifications and functionality, will be stated in product specific Errata Notes published at the Radiocrafts website. Customers are encouraged to check regularly for the most recent updates on products and support tools. Trademarks RC232™ is a trademark of Radiocrafts AS. The RC232™ Embedded RF Protocol is used in a range of products from Radiocrafts. The protocol handles host communication, data buffering, error check, addressing and broadcasting. It supports point-to-point, point-to-multipoint and peer-to-peer network topologies. All other trademarks, registered trademarks and product names are the sole property of their respective owners. Life Support Policy This Radiocrafts product is not designed for use in life support appliances, devices, or other systems where malfunction can reasonably be expected to result in significant personal injury to the user, or as a critical component in any life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Radiocrafts AS customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Radiocrafts AS for any damages resulting from any improper use or sale. © 2010, Radiocrafts AS. All rights reserved. Contact Information Web site: www.radiocrafts.com Address: Radiocrafts AS Sandakerveien 64 NO-0484 OSLO NORWAY Tel: +47 4000 5195 Fax: +47 22 71 29 15 E-mail: radiocrafts@radiocrafts.com sales@radiocrafts.com support@radiocrafts.com 2010 Radiocrafts AS RC11xx-RC232 Data Sheet (rev. 1.44) Page 25 of 25
RC1190-RC232 价格&库存
很抱歉,暂时无法提供与“RC1190-RC232”相匹配的价格&库存,您可以联系我们找货
