Radiocrafts
Embedded Wireless Solutions
RC1xxx-MPC1
Wireless M-Bus RF Transceiver Module
(EN 13757-4:2013) with Pulse Counter inputs
Product Description
The MPC1 Wireless M-Bus module is a stand-alone Wireless M-Bus module with Pulse
counter, Tamper and Install inputs. The module communicates with the Radiocrafts
MBUS3/MBUS4 modules and automatically at configurable intervals, transmit EN137574:2013 packets containing pulse counter values. The MPC1 module automatically wakes up
from sleep, detects and counts pulses from the two pulse inputs. The module also support
Over The Air (OTA) configuration for easy configuration of a stand-alone module not having a
host controller connected to the UART.
Applications
Water, gas, electricity meters with pulse output
Features
2 pulse inputs with programmable pull-up.
Tamper input
Install input
OTA (Over The Air configuration)
Encryption
Configurable TX intervals
Embedded Wireless M-Bus protocol supporting EN
EN13757-4:2013 mode T (868 MHz, -MBUS3) and mode N (169 MHz, -MBUS4)
12.7 x 25.4 x 3.3 mm compact module for SMD mounting
Ultra low power modes for extended battery lifetime
Completely Shielded module for SMD mounting
No external components
Quick module overview
The MPC1 protocol is running in same module as RC1180-MBUS3 for 868 MHz and
RC1701HP-MBUS4 for 169 MHz. For hardware and RF performance details please see
RC1701HP-MBUS4/RC1180-MBUS3 data sheet.
Module
RC1180-MPC1
RC1701HP-MPC1
RC1701-MPC1
Frequency band
868 MHz
169 MHz
169 MHz
Max output Power
+10 dBm
+27 dBm
+14 dBm
MPC1 Embedded Protocol
The MPC1 protocol is described in details in the MPC1 User Manual.
2015 Radiocrafts AS
RC1xxx-MPC1 Shortform Datasheet (rev. 1.0)
Page 1 of 3
Radiocrafts
RC1xxx-MPC1
Pin Assignment
Pin 31-42 is not available for RC1180-MPC1.
Pin Description
Pin no
1
2
3
4
5
6
7
8
9
10
11
12
13
14
17
18
27
28
29
30
41
15-16
19-26
31-40
42
Pin name
GND
CTS
RTS
CONFIG
TXD
RXD
GND
GND
RF
GND
VDD
Reset
VCC
GND
INSTALL
TAMPER
PULSE1
PULSE2
STATUS LED1
STATUS LED0
VCC_PA
I/O
I/O
I/O
I/O
2015 Radiocrafts AS
Description
System ground
UART Clear to Send / RXTX control (RS485)
UART Request to Send
Configuration Enable. Active low.
UART TX Data
UART RX Data
System ground
System ground
RF I/O connection to antenna
System ground
Not Connected, Internal Regulator Output
RESET_N. Active Low
Supply voltage input. Internally regulated.
System ground
Pull to ground to start installation message transmission
Tamper input
Interrupt pulse counter
LED output for status
Supply voltage for high power variant (RC1701HP-MPC1).
For future use and test status pin, Do not connect
Page 2 of 3
Radiocrafts
RC1xxx-MPC1
Mechanical Drawing
Mechanical Dimensions
The module size is 12.7 x 25.4 x 3.3 mm
© 2015 Radiocrafts AS. All rights reserved.
Radiocrafts AS, Sandakerveien 64, NO-0484 OSLO, NORWAY
E-mail: sales@radiocrafts.com Web site: www.radiocrafts.com
Phone: (+47) 4000 5195
Fax: (+47) 22 71 29 15
2015 Radiocrafts AS
Page 3 of 3
很抱歉,暂时无法提供与“RC1180-MPC1-DK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2708.973111+352.15774
