IO-LINK
PLUG. SET. PLAY.
www.rafi.de
WE CONNECT HUMAN ACTIONS WITH IO-LINK
WE CONNECT
HUMAN ACTIONS
WITH IO-LINK
Enterprise level
Operations control level
Process control level
Control level
The direction in automation is clear: more networking and data, less complexity. That’s why IO-LINK has become established as a standardized, fully bus-independent interface at sensor and actuator level. At RAFI, we are
dedicated to maintaining our reputation as a technology leader and actively
supporting our partners on their journey into the future.
Our IO-LINK products offer you a smooth entry. Using standardized M12
plugs, you can integrate these products into your existing environment fast.
Easily connected and individually parameterized, our control and signaling
units give you countless possibilities. The TILTED DIAMOND + and E-BOX
IO-LINK types equip you today for tomorrow’s challenges.
2
Field level
3
PLUG.
SET.
PLAY.
REPEAT.
The IO-LINK portfolio from RAFI impresses with fast integration and flexible parameterization. We show you how you
and your customers benefit from this equally.
E-BOX IO-LINK
The combination of IO-LINK and control device
box is unique on the market – especially in this
quality.
TILTED DIAMOND+ IO-LINK
The ultra-bright signal lamp is quickly
assembled and vibration-resistant.
YOUR BENEFITS AT A GLANCE
4
PLUG & PLAY
RELIABLE & SAFE
PROFITABILITY IN ALL AREAS
• The M12 terminal enables rapid assembly and commissioning
• You benefit from shorter downtimes thanks to quick
device replacement
• No need to worry: Thanks to IO-LINK, our portfolio
is bus-independent and can be integrated in all field
buses worldwide
• The minimal wiring work saves you time and money
• No need to manufacture expensive special connectors
• Lower personnel costs: Mistakes during wiring are
not possible, so even untrained employees can
perform installation
• Retrievable device diagnosis data enables predictive maintenance
• Fewer maintenance errors thanks to device identification: Incorrectly installed devices are reported
to the control unit
• T he system designer can refer to standards and respond flexibly to customer wishes with
regard to button color, lighting modes and labelling
• Parameterization covers all types. That means fewer products for Purchasing to manage and
earlier achievement of economies of scale
• Fewer products means less storage space and capital tie-up
• Due to the parameterization and reduced work for commissioning and assembly, production can
remain constant over all machine types
• Management benefits from optimized processes, reduced downtimes and greater system
availability
• Customer Service works faster, with fewer mistakes. Staff in spare parts logistics also benefit
from the standardized hardware. Predictive maintenance is also possible.
• Simple wiring with an unshielded, three-core cable saves time and money
• T he diagnosis function enables the production line foreman to identify and remedy mistakes
quickly
CONVENIENT PARAMETERIZATION
• Reduced product variety: Parameterize the button
color, brightness and flashing modes with ease via
the control unit
• Simple replacement: Stored parameters are automatically transferred to new devices
• World innovation: The first button box available
with IO-LINK
5
DATEN & FAKTEN
FACTS AND
FIGURES
ASSEMBLY
TECHNICAL DATA
E-BOX IO-LINK
• On aluminum profile using the assembly clip
• T he assembly clip can also be screwed onto other
surfaces
PROTECTION CLASSES
• E -BOX IO-LINK: IP 65
• TILTED DIAMOND+ IO-LINK: IP 66, IP 67
• Screw fastening from below
• Optionally with support tube and mounting base
PARAMETERIZATION
E-BOX IO-LINK
• Night mode with different brightness levels
• Flexible color selection: 5 standard colors plus
3 freely selectable RGB colors
• 4 different flashing modes
• C an be diagnosed via the control unit
• 8 different flashing modes
All details are available to download at www.rafi.de/io-link or in our
eCatalog
ARTICLE NUMBERS
E-BOX IO-LINK
• 1.24.100.001/0000
1 pushbutton, white bezel, with RGB-LED
• 1.24.200.001/0000
2 pushbuttons, white bezel, with RGB-LED
• 1.69.010.101/1000
Other types available on request
OPERATING VOLTAGE
• 18 – 30 V
OPERATING CURRENT
• max. 200 mA
IO-LINK
• Interface and System Specification Version 1.1.2
• IODD to download at rafi-group.com/io-link or
available in our eCatalog
TERMINALS
• M12 4-pin
PIN ASSIGNMENT
2
3
1
4
1 L+
2 n.c.
3 L4 C/Q
OPERATING TEMPERATURE
• - 30°C to +60°C
ILLUMINATION
• RGB LEDs
APPROVALS
E-BOX IO-LINK DIMENSIONS
• Outside dimension, length: 123.2 mm
• Outside dimension, width: 40 mm
• Outside dimension, height: 35.6 mm
TILTED DIAMOND+ IO-LINK DIMENSIONS
• Mounting depth: 14.5 mm
• Mounting height: 70.1 mm
• Collar dimension: 56.8 mm
Full data in eCatalog
ACCESSORIES
E-BOX IO-LINK
• FLEXLAB labelling sheet for individual legending
• Mounting base
• Support tubes in various lengths and angled
i
6
“FAST INTEGRATION AND
CUSTOM PARAMETERIZATION
ENSURE SEAMLESS INTEGRATION OF RAFI’S IO-LINK
PORTFOLIO IN PROCESSES.”
in our eCatalog
7
10 / 2020
The information in this brochure contains general descriptions and performance
characteristics which may not apply exactly in the specific application and/or
which can change due to further development of the products. The technical data,
images and other details of our products are merely the results of individual technical tests. These and other performance characteristics are only binding when
they are expressly agreed upon conclusion of the contract. Otherwise, the follow-
RAFI GmbH & Co. KG
Ravensburger Str. 128 – 134, D- 88276 Berg /Ravensburg
Phone.: +49 751 89-0, Fax: +49 751 89 -1300
www.rafi.de, info@rafi.de
ing applies:
We reserve the right to change delivery options and technical details. Products are
similar to the illustrations and other forms of representation.
All product designations can be brands or product names of the RAFI Group or
other suppliers whose use by third parties for their own purposes may violate the
owner’s rights.
很抱歉,暂时无法提供与“1.24.200.001/0000”相匹配的价格&库存,您可以联系我们找货
