technical data sheet
5.04.013.041/0000
RAMO 22 EDGE
fields of application
Measurement-control-regulation
Electrical engineering
Mechanical and system engineering
Signalling systems
Vehicle construction
Chemical industry
Industrial robots
description
With the EDGE mounting bracket, the RAMO can be mounted on profiles and without additional insulating material housing. This
offers freedom in mounting and new possibilities to place the components away from the central machine or device control panel.
technical data
general
Packaging unit
2 pcs.
direct links
MOQ order
2 pcs.
RAFI eCatalog
RoHS compliant
Yes
REACH compliant
Yes
Mounting hole
22.3 mm
Grid, min.
40 mm
mounting diameters
mechanical data
Resistance to force on the side
100 N
The information in this data sheet only contains general descriptions and / or performance features, which may not apply precisely as
described to the respective application, and which my change due to further product enhancements. The technical data, illustrations and
other information about our products are the mere results of individual technical testing. These descriptions and other product features are
only binding if they expressly agreed upon at the time of the conclusion of a binding contract. In all other cases, we reserve the right to
make technical changes as well as changes of availability. Pictures and other graphic illustrations are approximations only. All product names
may be trademarks or brand names of the RAFI Group or any other sub-supplier of RAFI. The use of such by any third parties for their own
purposes may infringe the rights of the respective entity holding those rights.
date: Oct 28, 2021 page: 1/2
RAFI GmbH & Co. KG
Ravensburger Str. 128-134
88276 Berg / Ravensburg
Germany
www.rafi-group.com,
info.headquarters@rafi-group.com
5.04.013.041/0000
drawings
Dimensioned drawing
date: Oct 28, 2021 page: 2/2
RAFI GmbH & Co. KG
Germany
www.rafi-group.com,
很抱歉,暂时无法提供与“5.04.013.041/0000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+109.378951+14.14568
- 10+94.3909810+12.20732
- 26+88.7759526+11.48115
- 50+85.1239150+11.00884
- 100+81.41032100+10.52857
- 250+76.73820250+9.92434
- 500+73.37619500+9.48954
- 1000+70.155091000+9.07296
