RASPBERRY PI COMPUTE MODULE
    RASPBERRYPI(树莓派)
    RASPBERRY PI COMPUTE KIT BCM2835
RASPBERRY PI COMPUTE MODULE 数据手册
COMPUTE MODULE DEVELOPMENT KIT The Compute Module Development Kit is a prototyping kit for those who wish to make use of the Raspberry Pi in a more flexible form factor, intended for industrial applications. The compute module contains the guts of a Raspberry Pi (the BCM2835 processor and 512Mbyte of RAM) as well as a 4Gbyte eMMC Flash device (which is the equivalent of the SD card in the Pi). The accompanying IO Board is a simple, opensource breakout board that you can plug a Compute Module into. The board hosts 120 GPIO pins, an HDMI port, a USB port, two camera ports and two display ports. Designing the module into a custom system should be relatively straightforward as we’ve put all the tricky bits onto the module itself, and you have the freedom to add extra components and place parts exactly where your product needs them. The compute module is available for purchase in single units, or in batches of hundreds or thousands. https://www.raspberrypi.org/products/compute-module-development-kit/ 7/29/2016
RASPBERRY PI COMPUTE MODULE 价格&库存
很抱歉,暂时无法提供与“RASPBERRY PI COMPUTE MODULE”相匹配的价格&库存,您可以联系我们找货
