RASPBERRY PI A+
RASPBERRY PI A+
    RASPBERRYPI(树莓派)
    RASPBERRY PI MODEL A+ BCM2835
RASPBERRY PI A+ 数据手册
RASPBERRY PI 1 MODEL A+ The Model A+ is the low-cost variant of the Raspberry Pi. It replaced the original Model A in November 2014. Compared to the Model A it has: • More GPIO. The GPIO header has grown to 40 pins, while retaining the same pinout for the first 26 pins as the Model A and B. • Micro SD. The old friction-fit SD card socket has been replaced with a much nicer push-push micro SD version. • Lower power consumption. By replacing linear regulators with switching ones we’ve reduced power consumption by between 0.5W and 1W. • Better audio. The audio circuit incorporates a dedicated low-noise power supply. • Smaller, neater form factor. We’ve aligned the USB connector with the board edge, moved composite video onto the 3.5mm jack, and added four squarelyplaced mounting holes. Model A+ is approximately 2cm shorter than the Model A. We recommend the Model A+ for for embedded projects and projects which require very low power, and which do not require Ethernet or multiple USB ports. https://www.raspberrypi.org/products/model-a-plus/ 7/28/2016
RASPBERRY PI A+ 价格&库存
很抱歉,暂时无法提供与“RASPBERRY PI A+”相匹配的价格&库存,您可以联系我们找货
