SC0025
SC0025
    RASPBERRYPI(树莓派)
    智能,智慧,发光二极管,图形 红色,绿色,蓝色(RGB) TFT - 彩色 7"(177.80mm) 800 x 480
SC0025 数据手册
RASPBERRY PI TOUCH DISPLAY The 7″ Touchscreen Monitor for Raspberry Pi gives users the ability to create all-inone, integrated projects such as tablets, infotainment systems and embedded projects. The 800 x 480 display connects via an adapter board which handles power and signal conversion. Only two connections to the Pi are required; power from the Pi’s GPIO port and a ribbon cable that connects to the DSI port present on all Raspberry Pis.  Touchscreen drivers with support for 10-finger touch and an onscreen keyboard will be integrated into the latest Raspbian OS for full functionality without a physical keyboard or mouse. • Turn your Raspberry Pi into a touch screen tablet, infotainment system, or standalone device. • Truly Interactive – the latest software drivers will support a virtual ‘on screen’ keyboard, so there is no need to plug in a keyboard and mouse. • Make your own Internet of Things (IoT) devices including a visual display. Simply connect your Raspberry Pi, develop a Python script to interact with the display, and you’re ready to create your own home automation devices with touch screen capability. • A range of educational software and programs available on the Raspberry Pi will be touch enabled, making learning and programming easier on the Raspberry Pi. https://www.raspberrypi.org/products/raspberry-pi-touch-display/ 7/28/2016
SC0025 价格&库存
很抱歉,暂时无法提供与“SC0025”相匹配的价格&库存,您可以联系我们找货
