308FX2 Industrial Ethernet Switch
N-Tron Networking Series
Unmanaged Industrial Ethernet Switch
The N-Tron® 308FX2, an unmanaged Industrial
Ethernet switch, is designed for use in industrial data
acquisition, control, and Ethernet I/O applications.
The rugged DIN-RAIL enclosure protects the switch from harsh environmental conditions,
enabling flawless performance in extreme settings.
APPLICATIONS
PRODUCT HIGHLIGHTS
>> Shipboard Applications
>> Compact Industrial Design
>> Electric Utility Substations
>> Full IEEE 802.3 and 1613 Compliance
>> Traffic Control
>> NEMA TS1/TS2 Compliance
>> Extended Environmental Specifications
>> Store-and-Forward Technology
>> N-View monitoring option available
FEATURES & BENEFITS
>> Six 10/100 BaseTX RJ-45 Ports
>> Two 100BaseFX Ports, ST or SC (shown)
>> Supports Full/Half Duplex Operation
>> LED Link/Activity Status Indication
>> Auto Senses Speed and Flow Control
>> MDIX Auto Cable Sensing (RJ-45)
>> Up to 2.6 Gb/s Maximum Throughput
>> Rugged Industrial DIN-Rail Enclosure
>> Redundant Power Inputs (10-30 VDC)
>> B
i-Color Status LEDs For Link, Speed,
Activity & Duplex
>> Port Control
>> N-View™ Monitoring Option
N-View capable models provide tools to
remotely monitor network traffic and error
conditions. Five switch level variables and
forty-one traffic indicators per port are
accessible using the N-View PC application
provided with the switch. An OPC server,
capable of delivering the data to OPC
capable applications, is also provided.
compliant
308FX2 Industrial Ethernet Switch Specifications
DIMENSIONS in inches (mm)
SWITCH PROPERTIES
Number of MAC Addresses: 4,000
Latency (typical): 2.1 μs
Backplane Speed: 2.6 Gb/s
Switching Method: Store & Forward
CASE DIMENSIONS
Height: 5.9” (15cm)
Width: 2.3” (5.8cm)
Depth: 3.8” (9.7cm)
Weight: 1.7 lbs (0.8kg)
Din-Rail: 35mm
ELECTRICAL
Redundant Input Voltage: 10-30 VDC
Input Current: 380 mA@24V
Inrush: 8.5Amp/0.2ms@24V
BTU/hr: 31.1@24V
ENVIRONMENTAL
Operating and Storage Temp: -40ºC to 85ºC
Operating Humidity: 10% to 95% (Non Condensing)
Operating Altitude: 0 to 10,000 ft.
SHOCK AND VIBRATION (BULKHEAD MOUNTING)
Shock: 200g@10ms
Vibration/Seismic: 50g, 5-200Hz, Triaxial
RELIABILITY
MTBF: >2 Million Hours
NETWORK MEDIA
10BaseT: ≥Cat3 Cable
100BaseTX: ≥Cat5 Cable
100BaseFX:
Multimode 50-62.5/125μm
Singlemode 7-10/125μm
CONNECTORS
10/100BaseTX: Six (6) RJ-45 Copper Ports
100BaseFX: Two (2) SC or ST Duplex Ports
ORDERING GUIDE
PART NUMBER
SERIAL CONFIGURATION PORT
Com Parameters: 9600,n,8,1
RECOMMENDED WIRING CLEARANCE
Front: 4” (10.16 cm)
Top: 1” (2.54 cm)
REGULATORY APPROVALS
FCC (CFR 47, Part 15, Subpart B, Class A and ANSI C63.4)
ICES-003
CE (IEC 60068: 2-1/2/6/30 and IEC 60533-7)
US - UL Listed UL508, ANSI/ISA 12.12.01-2007 for use in Class I
and II, Division 2 and Class III Division 1 and 2 Hazardous
Locations Groups A,B,C,D,T4A
Canada - C22.2 No. 142-M1987 and C22.2 No. 213-1987 for
use in Class I, Division 2 Hazardous Locations
EN 60079-0/15 ATEX
GOST-R Certified, RoHS Compliant
Designed to comply with:
IACS UR E10 (ABS Type-Approval)
IEEE 1613 for Electric Utility Substations
NEMA TS1/TS2 for Traffic Control
Americas
sales@redlion.net
Asia-Pacific
asia@redlion.net
w w w. re d l i o n . n e t
Europe
Middle East
Africa
europe@redlion.net
Connect. Monitor. Control.
+1 (717) 767-6511
DESCRIPTION
308FX2-N-XX
8-port (6 10/100BaseTX, 2 100BaseFX Fiber Uplink) Industrial Ethernet
Switch with N-View technology, DIN-Rail
308FXE2-N-XX-YY
Switch with N-View technology, singlemode, DIN-Rail
308FX2-XX
Switch, DIN-Rail
308FXE2-XX-YY
Switch, singlemode, DIN-Rail
URMK
NTPS-24.1.3
19” Universal Rack Mount Kit
N-TRON Power Supply (1.3 amp@24 VDC)
Where: N
= N-View Option
E = Singlemode
XX = ST for ST style fiber connector, SC for SC style fiber connector
YY = Segment length:
15 for 15km max. fiber segment length
40 for 40km max. fiber segment length
80 for 80km max. fiber segment length
FIBER TRANSCEIVER CHARACTERISTICS
FIBER LENGTH
2km
15km
40km
80km
TX POWER MIN
-19dBm
-15dBm
-5dBm
-5dBm
RX SENSITIVITY MAX
-31dBm
-31dBm
-34dBm
-34dBm
WAVELENGTH
1310nm
1310nm
1310nm
1550nm
As the global experts in communication, monitoring and control for
industrial automation and networking, Red Lion has been delivering
innovative solutions for over forty years. Our automation, Ethernet and
cellular M2M technology enables companies worldwide to gain real-time
data visibility that drives productivity. Product brands include Red Lion,
N-Tron® and Sixnet®. With headquarters in York, Pennsylvania, the company
has offices across the Americas, Asia-Pacific and Europe. Red Lion is
part of Spectris plc, the productivity-enhancing instrumentation and
controls company. For more information, please visit www.redlion.net.
ADLD0305 110415 ©2015 Red Lion Controls, Inc. All rights reserved. Red Lion, the Red Lion logo, N-Tron and Sixnet are
registered trademarks of Red Lion Controls, Inc. All other company and product names are trademarks of their respective owners.
