RAM-6800-AT-MX
RAM-6800-AT-MX
    REDLIONCONTROLS(美国红狮)
    1ETH,1SRLGSM,AC4-PINMOLEX
RAM-6800-AT-MX 数据手册
RAM® 6000 3G Cellular RTUs Sixnet® Networking Series Rugged Cellular RTUs with Local Control Red Lion’s Sixnet series RAM 6000 cellular RTUs with 3G network support, provide advanced control and communication in IIoT applications for remote assets and processes in extreme conditions. RAM 6000 industrial cellular RTUs seamlessly connect Modbus and DNP3 enabled SCADA equipment via 3G connectivity to remote networks or select Industrial Internet of Things (IIoT) Cloud platforms. Featuring a web-based event engine that can trigger I/O or send SMS text messages based on real-time operational data, RAM cellular RTUs can perform advanced local edge control and alert personnel of critical events. A builtin I/O concentrator allows the RAM to collect sensor data and optimize cellular data consumption by optionally reporting only on an exception or only transmitting relevant data points. With built-in Ethernet, serial and I/O, RAM RTUs easily integrate with existing equipment enabling remote monitoring and control for M2M applications in industries including oil and gas, water/wastewater, utility, transportation and mining. APPLICATIONS PRODUCT HIGHLIGHTS >> Mining >> Reliable 3G Cellular Connectivity >> Oil & Gas >> Natively Supports Modbus & DNP3 Protocols >> Transportation >> Cloud Connectivity to IIoT Cloud Platforms >> Utility >> Routing Capabilities Provide Secure, Reliable Communication >> Water/Wastewater SUPPORTED IIOT PLATFORMS** >> Event Engine can Trigger I/O or Send SMS Messages >> Optional PoE (Powered Device) Support • • • • • • • • • • • • Amazon®—AWS™ IoT AT&T®—M2X Autodesk®—Fusion Connect Cumulocity Inductive Automation’s Ignition SCADA LEC—IQ Web SCADA Microsoft—Azure® Nokia—IMPACT Set-Point Control—IPwebcontrol Skkynet®—SkkyHub™ Telenor—Connexion Cloud Connect Telit®—deviceWISE® FEATURES & BENEFITS • Integrates with deviceWISE, Fusion Connect, IPwebcontrol, IQ Web SCADA and Skkynet platforms >> Multiple Communication Ports • One RS-232 serial port and up to five Ethernet ports provide seamless connectivity to remote devices >> Out-Of Band Management (OOBM) • Secure remote CLI access via serial port >> Rugged, Industrial Design • Pre-loaded with many console port configurations • Reliable operation in extreme environments >> Secure Ethernet Connectivity • -40° to 75°C operating temperature* • Routing capabilities for reliable communication • DIN-rail and panel mounting options • Stateful firewall, SSL, GRE and VPN services reduce the risk of unwanted access >> Modbus and DNP3 Support • Easily communicates with SCADA equipment with native protocols >> Advanced Event Engine Functionality • Easily configure control engine via drop-down menus >> Cloud Connectivity to IIoT Cloud Platforms • Trigger I/O, alarms and send SMS messages based on operational data • Allows for seamless communication with leading IIoT cloud platforms using MQTT messaging protocol C UL R LISTED US compliant RAM 6000 3G Specifications WIRELESS INTERFACE Verizon EVDO with fallback to GSM SELECTABLE IIOT CLOUD PLATFORMS** Amazon® - AWS™ IoT AT&T® – M2X Autodesk® – Fusion Connect Cumulocity Inductive Automation’s Ignition SCADA LEC – IQ Web SCADA Microsoft – Azure® Nokia – IMPACT Set-Point Control – IPwebcontrol Skkynet® – SkkyHub™ Telenor – Connexion Cloud Connect Telit® – deviceWISE® PROGRAMMABLE PLATFORM Configurable Events: up to 99 events can be triggered by over 200 system variable which in turn can send text messages or control I/O Software Development Kit (SDK) C/C++/Perl SYSTEM PERFORMANCE 32-bit ARM9 400 MHz CPU 512 MB NAND 128 MB RAM TUNNELING IPsec, GRE, OpenVPN ROUTING PROTOCOLS OSPF, BGP, RIP CLUSTERING VRRP IP NAT, Port Forwarding, Dynamic DNS, DHCP Stateful Inspection Firewall, IP Transparency CONNECTORS Ethernet: One (1) or five (5) 10/100Base-T RJ-45 ports WAN capability on port 5 Serial: One (1) RS-232 (DB9) 115,200bps USB: One (1) USB 2.0 (mini) Antennas: Two (2) SMA connectors (antenna, diversity) DIMENSIONS INPUTS & OUTPUTS Input: One (1) digital/analog Output: One (1) digital (open-collector) POWER INPUT Input Voltage: 8-30 VDC (12 or 24 VDC nominal) Standby Power: 1.4W - 4.0W (typical) Transmitting: 660x: 2.0W – 2.9W 6621: 3.6W – 4.5W PoE Operation (EB models only) IEEE 802.3af compliant Powered Device (PD) PoE Input: 37-57 VDC (48 VDC nominal) Heat dissipation: 30 BTU/hour max MECHANICAL RAM-6x0x Dimensions: 120 x 96 x 32 mm (4.7” x 3.77” x 1.25”) Weight: 453g (1 lb) RAM-6x21 Dimensions:120 x 96 x 51 mm (4.7” x 3.77” x 2.0”) Weight: 500g (1.1 lbs) ENVIRONMENTAL Operating Temperature: -40° to +75°C* Shock: IEC60068-2-27 Vibration: IEC60068-2-6 Humidity: 5 to 95% non-condensing Ingress: IP30 protection CERTIFICATION EMI/EMC: Emissions: FCC, Part 15 and Industry Canada, ICES-003; Class A; EN55022, IEC61000-6-4 Immunity: IEC61000-6-2 (EN61000-4-2,3,4,5,6,8) Hazardous Locations: Class I, Div. 2, Groups A, B, C, D, ISA 12.12.01 Electrical safety: UL508/CSA22.2/14 (CUL); IEC61010-1 Carrier Specific Approvals RoHS compliant WARRANTY 3 years on design and manufacturing defects Specifications are subject to change. Visit www.redlion.net for more information. * See Hardware Manual for thermal considerations. ** Monthly service fees may be required for cloud platform access, not every platform client is preloaded. RAM 6000 3G Specifications ORDER GUIDE PART NUMBER PRODUCT LINE SERIAL RS-232 ETHERNET 10/100 CELLULAR RAM RAM RAM RAM RAM RAM RAM RAM 1 1 1 1 1 1 1 1 1 1 1 1 1 1 5 5 3G/CDMA 3G/CDMA 3G/CDMA 3G/CDMA 3G/CDMA 3G/CDMA 3G/CDMA 3G/CDMA RAM-6600-(Carrier Code) RAM-6600-(Carrier Code)-AC RAM-6600-(Carrier Code)-MX RAM-6601-(Carrier Code) RAM-6601-(Carrier Code)-AC RAM-6601EB-(Carrier Code) RAM-6621-(Carrier Code) RAM-6621-(Carrier Code)-AC POWER CONNECTOR Molex end connector cable AC adapter AC adapter/Molex end connector DC powered AC adapter PoE (Power Over Ethernet) DC powered AC adapter CARRIER CODES (VZ) Verizon Note: See Band/Frequency table for compatibility FREQUENCY SPECIFICATIONS PART NUMBER BANDS/FREQUENCIES RAM-66XX-VZ EVDO: 800/1900 MHz CDMA: 800/1900 MHz Americas sales@redlion.net Asia-Pacific asia@redlion.net w w w. re d l i o n . n e t Europe Middle East Africa europe@redlion.net Connect. Monitor. Control. +1 (717) 767-6511 As the global experts in communication, monitoring and control for industrial automation and networking, Red Lion has been delivering innovative solutions for over forty years. Our automation, Ethernet and cellular M2M technology enables companies worldwide to gain real-time data visibility that drives productivity. Product brands include Red Lion, N-Tron and Sixnet. With headquarters in York, Pennsylvania, the company has offices across the Americas, Asia-Pacific and Europe. Red Lion is part of Spectris plc, the productivity-enhancing instrumentation and controls company. For more information, please visit www.redlion.net. ADLD0429 012318 © 2017 Red Lion Controls, Inc. All rights reserved. Red Lion, the Red Lion logo, N-Tron and Sixnet are registered trademarks of Red Lion Controls, Inc. All other company and product names are trademarks of their respective owners.
RAM-6800-AT-MX
物料型号:Sixnet® Networking Series RAM 6000 3G Cellular RTUs
器件简介:Red Lion的Sixnet系列RAM 6000是一款支持3G网络的坚固型蜂窝RTU,专为IIoT应用设计,可在极端条件下提供高级控制和通信。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 支持Modbus和DNP3协议 - 支持云连接到IIoT云平台 - 具有事件引擎,可触发I/O或发送短信 - 可选的PoE(Power over Ethernet)支持
功能详解: - 提供多达五个以太网端口和RS-232串行端口 - 适用于极端环境的坚固工业设计 - 支持通过MQTT消息协议与领先的IIoT云平台进行通信 - 支持设备管理(OOBM)和安全的以太网连接
应用信息:适用于采矿、石油和天然气、交通、公用事业、水/废水处理等行业。
封装信息:文档中未提供封装信息,但提供了产品的尺寸和重量。
RAM-6800-AT-MX 价格&库存
很抱歉,暂时无法提供与“RAM-6800-AT-MX”相匹配的价格&库存,您可以联系我们找货
