02650-102
02650-102
    REES
    2.25 INCH RED MR PLUNDER W/LATCH
02650-102 数据手册
1/12/2021 | Page 1 of 3 Rees, Inc. 405 S Reed Rd Fremont, IN 46737 Phone: 260.495.9811 Fax: 260.495.2186 Email: sales@reesinc.com Website: www.reesinc.com ITEM # 02650-102, 2.25 INCH MUSHROOM PLUNGER WITH SPRING LATCH Features/Applications The following switch is a hand operated, spring latchable, control circuit device, rated ‘Heavy Duty’ normally for use with electromagnetic equipment. The yellow cover, painted with a dry powder paint, is made from die-cast zinc. The red mushroom plastic plunger is molded from DuPont Delrin 100ST Acetal for improved impact resistance and is solid color throughout. Gold plated contacts eliminate high resistance tarnishing Complies with IEC/EN 60947-5-5 for Emergency Stop Applications Nema 12/13, IP 65 Each captive terminal will accept (2) #14 AWG stranded wires. Each switch is supplied with all mounting hardware and a solid santoprene rubber gasket which provides an oil tight seal upon installation. The mechanical life of this device is 500,000 operations. This switch can be found in a variety of uses on industrial machines. Presses and press brakes use them as “STOP” buttons.   Electrical Ratings “HEAVY DUTY – A600 / N300” Listed under UL 508 – File # E 58589 Certified under CSA C22.2 – File # LR 3648 CE Compliant IEC/EN 60947-5-5 Third party certified under DEMKO File # FI-17205 Environmental Temperature Range List Price $334.30 1/12/2021 | Page 2 of 3 Operating: +32oF to +131oF (0oC to +55oC) Storage: -40oF to +185oF (-40oC to +85oC) Note: Operating temperatures at 0oC are based on the absence of freezing moisture and liquids. Normal Potential a b Normal Current Inrush Current 110-120 aca volts 6.0 amp. 60.0 amp. 220-240 aca 3.0 amp. 30.0 amp. 440-480 aca 1.5 amp. 15.0 amp. 550-600 aca 1.2 amp. 12.0 amp. 115-125 dcb 2.2 amp. ----- 230-250 dcb 1.1 amp. ----- Power factor 0.35 or less Inductive loads as specified in Section 125 of Industrial Control Devices, Controllers and Assemblies, ANSI / NEMA ICS 2-1988 WARNING - DANGER These products should only be used where point-ofoperation guarding devices have been properly installed & maintained so that appropriate OSHA and ANSI B11.1 regulations & standards are met.  Misapplication of the products on machinery lacking effective point-of operation safeguards can cause serious injury to the operator of that machinery. -------------------------------------------------------------------------------------------------------------------AVERTISSMENT - DANGER Ces produit doivent seulement être utilisés sur des postes à risque correctement sécurisés et entretenus a n d’être conforme aux standards et régulations en vigueur (CSA, CLC). Un mauvais usage de ces produits sur des machines et des postes de travail non sécurisés de manière ef cace peut causer des blessures graves au technicien maniant ces machines. 1/12/2021 | Page 3 of 3 SPECIFICATIONS Plunger Color Red Cover Color Yellow Operating Force 10.5 lb Latch/Plunger Operation Latches when depressed Operate latch to release Positive Opening Contact   Contact Arrangement #11 NC + NC Contact Type Slow-Make Slow-Break Approx. Shipping Weight 1.60 lb Old Catalog Number 2650 Switches comply with IEC/EN 60947-5-5 for Emergency Stop Applications
02650-102 价格&库存
很抱歉,暂时无法提供与“02650-102”相匹配的价格&库存,您可以联系我们找货
