40102-122
40102-122
    REES
    30.5 MM RED PB W/ 2NO/2NC CONTAC
40102-122 数据手册
1/12/2021 | Page 1 of 3 Rees, Inc. 405 S Reed Rd Fremont, IN 46737 Phone: 260.495.9811 Fax: 260.495.2186 Email: sales@reesinc.com Website: www.reesinc.com ITEM # 40102-122, 30.5MM MUSHROOM AND ROPE PULL OPERATORS Features/Applications The following switch is a hand operated, control circuit device, rated ‘Heavy Duty’ normally for use with electromagnetic equipment. The body is made from diecast zinc. The red mushroom ergonomic shaped plunger is molded from DuPont Delrin 100ST Acetal for improved impact resistance and is solid color throughout. UL/NISD E357870 Nema 12/13, IP 65 Positive Break, Gold Plated Contacts Sliding Padlock Attachment The operator will accept up to three tiers of two contact blocks for a total of six separate circuits. Each operator is supplied with all mounting hardware and a solid neoprene rubber gasket which provides an oil tight seal upon installation. The mechanical life of this unit is 1,000,000 operations. This device can be found on a variety of machinery, used to perform such operations as ‘stop’, ‘top stop’, ‘jog’, ‘off’, ‘forward’, ‘reverse’, etc. This series satisfies the requirements of IEC 60947-5-5 – 3.9 direct opening action (positive opening action) (of a contact element); when fitted with one or more of any of our normally closed contact blocks. This is commonly referred to as “Positive Break”, meaning the breaking of the normally closed contacts is not dependent upon springs.   Electrical Ratings List Price $249.70 1/12/2021 | Page 2 of 3 “HEAVY DUTY – A600 / N150” Environmental Temperature Range Operating: +32oF to +131oF (0oC to +55oC) Storage: -40oF to +185oF (-40oC to +85oC) Note: Operating temperatures at 0oC are based on the absence of freezing moisture and liquids. Normal Potential a b Normal Current Inrush Current 110-120 aca volts 6.0 amp. 60.0 amp. 220-240 aca 3.0 amp. 30.0 amp. 440-480 aca 1.5 amp. 15.0 amp. 550-600 aca 1.2 amp. 12.0 amp. 115-125 dcb 2.2 amp. ----- 230-250 dcb 1.1 amp. ----- Power factor 0.35 or less Inductive loads as specified in Section 125 of Industrial Control Devices, Controllers and Assemblies, ANSI / NEMA ICS 2-1988 WARNING - DANGER These products should only be used where point-ofoperation guarding devices have been properly installed & maintained so that appropriate OSHA and ANSI B11.1 regulations & standards are met.  Misapplication of the products on machinery lacking effective point-of operation safeguards can cause serious injury to the operator of that machinery. -------------------------------------------------------------------------------------------------------------------AVERTISSMENT - DANGER Ces produit doivent seulement être utilisés sur des postes à risque correctement sécurisés et entretenus a n d’être conforme aux standards et régulations en vigueur (CSA, CLC). Un mauvais usage de ces produits sur des machines et des postes de travail non sécurisés de manière ef cace peut causer des blessures graves au technicien maniant ces machines. 1/12/2021 | Page 3 of 3 SPECIFICATIONS Operator Color Red Operator Material, Size, Style 2.00 in. Plastic Mushroom Padlock Feature Yes Switch Type Maintained UL/NISD Positive Opening Contact   Contact Block(s) Included (2) 50703 (2) NO/NC Operating Force 8.0 lb Approx. Shipping Weight 0.80 lb Plunger Head Operator Replacement 43200-042 Old Catalog Number R102 Operating Type Maintained
40102-122 价格&库存
很抱歉,暂时无法提供与“40102-122”相匹配的价格&库存,您可以联系我们找货
