0.375X4.0FLT6061T6511-48 数据手册
ALUMINUM 6061 BAR, ROD, & ANGLE DATA SHEET - REMINGTON INDUSTRIES
Remington Industries is a proud supplier of 6061 Aluminum T6511 Mill Stock Flat Bars, Round Rods, and Angles. Aluminum 6061 is a lightweight, general-purpose
aluminum alloy that can easily be machined or welded. It has a high resistance to corrosion and an excellent weight-to-strength ratio. Its T6511 temper also means
that it has been heat treated for additional strength (Yield Strength: 35,000 psi). Additionally, this 6061 aluminum meets ASTM B221 specifications.
We offer aluminum bars, rods, and angles in many different sizes; take a look at our selection using the charts below. If you can't find a piece of raw material that
meets your specifications, feel free to contact Remington Industries to see how we can help you with our Custom Raw Materials Services.
· Material: 6061 General Purpose Aluminum, Extruded
· Specification: ASTM B221
· Temper: T6511
· Available Shapes:
· Finish: Unpolished (Mill)
- Flat Bar/Plate
- Round Rod
· Yield Strength: 35,000 psi
- Angle
· Easily welded or machined
ALUMINUM FLAT BAR
AVAILABLE DIMENSIONS
THICKNESS
1
3
1
4"
1
(6.35 mm)
8"
2"
WIDTH
1" (25.40 mm)
1" (25.40 mm)
2" (50.80 mm)
(9.53 mm)
1 2" (38.10 mm)
(12.70 mm)
2" (50.80 mm)
1
2 12" (63.50 mm)
5
3
8"
4"
(15.88 mm)
3" (76.20 mm)
(19.05 mm)
1" (25.40 mm)
ALUMINUM FLAT BAR
LENGTH
(12.70 mm)
2"
DIAMETER
1
5
4" (101.60 mm)
10" (254.00 mm)
36" (914.40 mm)
1
4 " x 4" x 8"
(9.53 x 9.53 x 3.18 mm)
1" x 1" x 18"
(25.40 x 25.40 x 3.18 mm)
1" x 1" x 1 4"
(25.40 x 25.40 x 6.35 mm)
1 1 2" x 1 12" x 1 8"
(38.10 x 38.10 x 3.18 mm)
1 1 2" x 1 1 2" x 1 4"
(38.10 x 38.10 x 6.35 mm)
1
2" x 2" x 8"
(50.80 x 50.80 x 3.18 mm)
(7.94 mm)
ALUMINUM ROUND ROD
8"
2"
(12.70 mm)
5
8"
(15.88 mm)
LENGTH
3
4"
(19.05 mm)
7
8"
(22.23 mm)
1" (25.40 mm)
1" (25.40 mm)
8" (203.20 mm)
Aluminum 6061
Data Sheet
is proud to offer our
Custom Raw
Materials Services
We are proud to offer a range
of custom services for raw
materials to best meet your
needs. With our extensive
knowledge of raw materials,
experience in the industry, and
relevant connections, we can
determine product availability
and source the materials you
need to complete your project.
We also offer Value-Added
Services for your raw materials:
- Cut to Length
- CNC Turning & Milling
- Grinding
- CAD Drawings
- Prototyping
If you have any questions or
need any information about our
Raw Materials Services, feel
free to contact us! It only takes
one call to get experienced
assistance.
Contact us by phone:
(815) 385-1987
Contact us by email:
sales@remingtonindustries.com
10" (254.00 mm)
1 1 8" (28.58 mm)
2" (50.80 mm)
12" (304.80 mm)
4" (101.60 mm)
8" (203.20 mm)
4" (101.60 mm)
6" (152.40 mm)
48" (1219.20 mm)
6" (152.40 mm)
1" (25.40 mm)
(9.53 mm)
1
12" (304.80 mm)
6" (152.40 mm)
3
16"
LENGTH
2" (50.80 mm)
ALUMINUM ANGLE
3
(6.35 mm)
3
8" (203.20 mm)
24" (609.60 mm)
WIDTH x HEIGHT x THICKNESS
4"
6" (152.40 mm)
4" (101.60 mm)
8" (203.20 mm)
ALUMINUM ROUND ROD
Aluminum Flat Bars,
Round Rods, & Angles
ALUMINUM ANGLE
1 1 4" (31.75 mm)
1 3 8" (34.93 mm)
DATE | ISS. | REVISION | BY
Drawn by:
Drawing rev.:
AG 1/31/20
24" (609.60 mm)
10" (254.00 mm)
12" (304.80 mm)
24" (609.60 mm)
1 1 2" (38.10 mm)
36" (914.40 mm)
3
1 4" (44.45 mm)
36" (914.40 mm)
48" (1219.20 mm)
2" (50.80 mm)
48" (1219.20 mm)
3521 N. Chapel Hill Rd
Johnsburg, IL 60051 USA
0.375X4.0FLT6061T6511-48 价格&库存
很抱歉,暂时无法提供与“0.375X4.0FLT6061T6511-48”相匹配的价格&库存,您可以联系我们找货
