18STRVIOGXL1000
18STRVIOGXL1000
    REMINGTON
    HOOK-UP STRND 18AWG VIOLET 1000
18STRVIOGXL1000 数据手册
Stranded GXL Automotive Primary Hook Up Wire from Remington Industries is ideal for higher temperature, more rugged circuit wiring applications that specify SAEƒJ1128 requirements, such as automotive, electric motor, and generator applications. The multi conductor wire is made from bare copper that offers high quality performance for most electrical applications. Additionally, the XLPE insulation protects the wire against abrasion, chemicals, fuels, oils, and solvents, while also remaining flexible enough to fit wherever it might be needed. This hook up wire is available in several wire gauges (from 14 to 18 AWG) to meet your specific requirements. It is also available in a variety of bold colors (see below) to allow for easy circuit identification, as well as numerous spool sizes (see below) for your convenience. GXL HOOK UP WIRE DATA SHEET - REMINGTON INDUSTRIES x Conductor Material: Bare Copper x Insulation Material: Cross-Linked Polyethylene (XLPE / PEX / XPE) x Type: SAE J1128 GXL Hook Up Wire, Stranded x Voltage Rating: 60 V x Temperature Rating: -40°C (-40°F) to 125°C (257°F) x Colors Available: Black, Blue, Brown, Gray, Green, Orange, Red, Violet, White, Yellow x Spool Sizes Available: 25 ft, 100 ft, 250 ft, 500 ft, 1000 ft, 2500 ft, 5000 ft x Also available in pre-built kits (6 or 10 different colors / 25 ft or 100 ft per spool) x Specifications: Ford ESB-M1L 85-B, & Chrysler MS-8900 x RoHS & REACH Compliant OVERALL DIAMETER STRANDED WIRE GAUGE STRANDING WIRE DIAMETER Stranded Data Sheet Remington Industries is proud to offer our Custom Wire Services Our exclusive inventory of in-stock wire and ability to procure wire of all kinds makes us the perfect partner for wire purchasing and custom wire services. We are proud to provide essential, high quality wire for engineering projects, educational science projects, coil winding, and electronics applications. Some of our many wire services include the following: - Wire Re-Packaging - Bifilar & Trifilar Windings - Wire Processing - Coil Winding - Wire Procurement Services WIRE DIAMETER PART NUMBER GXL Hook Up Wire OVERALL DIAMETER If you have any questions or need any information about our Wire Services, feel free to contact us! It only takes one call to get experienced assistance. Contact us by phone: (815) 385-1987 14STRGXL 14 AWG 19/27 16STRGXL 16 AWG 19/29 0.056" 0.102" 18STRGXL 18 AWG 19/30.5 0.045" 0.091" 0.071" 0.114" Contact us by email: sales@remingtonindustries.com DATE | ISS. | REVISION | BY Drawn by: Drawing rev.: AG 4/29/20 -- 3521 N. Chapel Hill Rd Johnsburg, IL 60051 USA remingtonindustries.com
18STRVIOGXL1000
物料型号:GXL Hook Up Wire Stranded,符合SAE J1128标准。
器件简介:这种线缆适用于高温、更坚固的电路布线应用,如汽车、电动机和发电机等。由裸铜制成的多导体线提供大多数电气应用所需的高品质性能。XLPE绝缘材料保护电线免受磨损、化学物质、燃料、油和溶剂的侵害,同时保持足够的柔韧性以适应各种需要。
引脚分配:文档中未提及具体的引脚分配信息。
参数特性: - 导体材料:裸铜 - 绝缘材料:交联聚乙烯(XLPE/PEX/XPE) - 类型:SAE J1128 GXL Hook Up Wire, Stranded - 额定电压:60V - 温度范围:-40°C (-40°F) 至 125°C (257°F) - 颜色选择:黑色、蓝色、棕色、灰色、绿色、橙色、红色、紫罗兰色、白色、黄色 - 卷筒尺寸:25英尺、100英尺、250英尺、500英尺、1000英尺、2500英尺、5000英尺
功能详解:文档中未提供详细的功能详解
应用信息:适用于工程项目、教育科学项目、线圈绕制和电子应用。
封装信息:文档中未提供封装信息
18STRVIOGXL1000 价格&库存
很抱歉,暂时无法提供与“18STRVIOGXL1000”相匹配的价格&库存,您可以联系我们找货
