26STRBLUMILW1000
26STRBLUMILW1000
    REMINGTON
    26 AWG GAUGE STRANDED HOOK UP WI
26STRBLUMILW1000 数据手册
Stranded MIL-W-16878 Hook Up Wire from Remington Industries is used across a variety of engineering and electronics industries. The multi conductor wire is made from tinned copper that offers high quality performance for all general-purpose electrical applications, and the PVC insulation protects the wire against abrasion, chemicals, oils, and solvents. By conforming to UL and MIL-spec specifications, the hook up wire provides excellent uniformity for processing, stripping, and terminating. This hook up wire is available in two wire gauges (from 26 & 28 AWG). It is also available in a variety of colors (see below) to allow for easy circuit identification, as well as numerous spool sizes (see below) for your convenience. · Conductor Material: Tinned Copper · Insulation Material: PVC (0.011" Thick) · Type: MIL-W-16878 Hook Up Wire, Stranded · Voltage Rating: 600 V MIL-W-16878 HOOK UP WIRE DATA SHEET - REMINGTON INDUSTRIES · Temperature Rating: 105°C (221°F) · Colors Available: Black, Blue, Brown, Gray, Green, Orange, Red, Violet, White, Yellow · Spool Sizes Available: 25 ft, 100 ft, 250 ft, 500 ft, 1000 ft, 2500 ft, 5000 ft · Also available in pre-built kits (6 or 10 different colors / 25 ft or 100 ft per spool) MIL-W-16878 Hook Up Wire Stranded Data Sheet Remington Industries is proud to offer our Custom Wire Services Our exclusive inventory of in-stock wire and ability to procure wire of all kinds makes us the perfect partner for wire purchasing and custom wire services. We are proud to provide essential, high quality wire for engineering projects, educational science projects, coil winding, and electronics applications. Some of our many wire services include the following: - Wire Re-Packaging - Bifilar & Trifilar Windings - Wire Processing - Coil Winding - Wire Procurement Services OVERALL DIAMETER STRANDED If you have any questions or need any information about our Wire Services, feel free to contact us! It only takes one call to get experienced assistance. WIRE DIAMETER Contact us by phone: (815) 385-1987 Contact us by email: sales@remingtonindustries.com DATE | ISS. | REVISION | BY PART NUMBER WIRE GAUGE 26MILWSTR 28MILWSTR STRANDING WIRE DIAMETER OVERALL DIAMETER 26 AWG 7/34 0.0190" 0.061" 28 AWG 7/36 0.0126" 0.057" Drawn by: Drawing rev.: AG 1/28/20 -- 3521 N Chapel Hill Rd Johnsburg, IL 60051 USA remingtonindustries.com
26STRBLUMILW1000
1. 物料型号:文档中列出了两种型号的钩线,分别是26MILWSTR(26AWG)和28MILWSTR(28AWG),它们都是多股线。
2. 器件简介:钩线由镀锡铜制成,提供高质量的性能,适用于各种通用电气应用。PVC绝缘材料保护电线免受磨损、化学物质、油脂和溶剂的侵害。
3. 引脚分配:文档中没有提供引脚分配信息,因为它是关于电线的数据表,而不是电子元件。
4. 参数特性: - 温度等级:105°C(221°F) - 颜色选择:黑色、蓝色、棕色、灰色、绿色、橙色、红色、紫罗兰色、白色、黄色 - 卷筒尺寸:25英尺、100英尺、250英尺、500英尺、1000英尺、2500英尺、5000英尺 - 符合UL和MIL规格标准
5. 功能详解:钩线适用于工程和电子行业的多种用途,包括工程项目、教育科学项目、线圈绕制和电子应用。
6. 应用信息:Remington Industries提供定制电线服务,包括电线重新包装、双股和三股绕线、电线加工、线圈绕制和电线采购服务。
7. 封装信息:文档提供了两种线规的详细尺寸信息,包括线径和整体直径。
8. 联系方式:文档提供了Remington Industries的联系电话和电子邮件地址。
26STRBLUMILW1000 价格&库存
很抱歉,暂时无法提供与“26STRBLUMILW1000”相匹配的价格&库存,您可以联系我们找货
