28STRPTFEKIT10COLOR100
    REMINGTON
    28 AWG GAUGE STRANDED HOOK UP WI
28STRPTFEKIT10COLOR100 数据手册
PTFE HOOK UP WIRE DATA SHEET - REMINGTON INDUSTRIES PTFE-Coated, Stranded Hook Up Wire from Remington Industries is utilized in a variety of general-purpose electrical applications. The multi conductor wire is made from silver-plated copper that offers high quality performance and excellent electrical conductivity. The extruded PTFE insulation (short for Polytetrafluoroethylene -also known as Teflon) allows for use in high temperature electronic applications, while also protecting the wire against abrasion, chemicals, oils, and solvents. The insulation is also highly resistant to thermal aging, solder damage, flame, and moisture. The wire conforms to MIL-spec specifications and provides great uniformity for processing, stripping, and terminating. This hook up wire is available in many wire gauges (from 16 to 30 AWG) to meet your specific requirements. It is also available in a variety of colors (see below) to allow for easy circuit identification, as well as numerous spool sizes (see below) for your convenience. · Conductor Material: Silver-Plated Copper · Temperature Rating: 200°C (392°F) · Insulation Material: PTFE (Teflon) · Colors Available: Black, Blue, Brown, Gray, Green, Orange, Red, Violet, White, Yellow · Type: MIL-W-16878/4 Type E, Stranded Wire · Spool Sizes Available: 25 ft, 100 ft, 250 ft, 500 ft, 1000 ft, 2500 ft, 5000 ft · Voltage Rating: 600 V · Also available in pre-built kits (6 or 10 different colors / 25 ft or 100 ft per spool) OVERALL DIAMETER WIRE DIAMETER WIRE GAUGE STRANDING 16PTFESTR 16 AWG 18PTFESTR Stranded Data Sheet Remington Industries is proud to offer our Custom Wire Services Our exclusive inventory of in-stock wire and ability to procure wire of all kinds makes us the perfect partner for wire purchasing and custom wire services. We are proud to provide essential, high quality wire for engineering projects, educational science projects, coil winding, and electronics applications. Some of our many wire services include the following: - Wire Re-Packaging - Bifilar & Trifilar Windings - Wire Processing - Coil Winding - Wire Procurement Services STRANDED PART NUMBER PTFE Hook Up Wire WIRE DIAMETER OVERALL DIAMETER 19/29 0.0508" 0.080" 18 AWG 19/30 0.0403" 0.069" 20PTFESTR 20 AWG 19/32 0.0320" 0.058" 22PTFESTR 22 AWG 19/34 0.0253" 0.051" 24PTFESTR 24 AWG 19/36 0.0201" 0.045" 26PTFESTR 26 AWG 7/34 0.0190" 0.039" 28PTFESTR 28 AWG 7/36 0.0126" 0.035" 30PTFESTR 30 AWG 7/38 0.0100" 0.032" If you have any questions or need any information about our Wire Services, feel free to contact us! It only takes one call to get experienced assistance. Contact us by phone: (815) 385-1987 Contact us by email: sales@remingtonindustries.com DATE | ISS. | REVISION | BY Drawn by: Drawing rev.: AG 1/28/20 -- 3521 N. Chapel Hill Rd Johnsburg, IL 60051 USA remingtonindustries.com
1. 物料型号:文档列出了不同线规(AWG)的PTFE钩线型号,例如16PTFESTR、18PTFESTR等,直至30PTFESTR。 2. 器件简介:PTFE涂层钩线用于多种通用电气应用,由镀银铜制成,提供高质量性能和出色的电导率。PTFE(聚四氟乙烯,也称为特氟龙)绝缘材料允许在高温电子应用中使用,同时保护电线免受磨损、化学物质、油脂和溶剂的侵害。 3. 引脚分配:文档中没有提供关于引脚分配的具体信息。 4. 参数特性: - 导体材料:镀银铜 - 绝缘材料:PTFE(特氟龙) - 类型:MIL-W-16878/4 Type E,绞合线 - 电压等级:600V - 温度等级:200°C(392°F) 5. 功能详解:PTFE绝缘提供抗磨损、耐化学、耐油脂、耐溶剂和抗热老化的特性,同时对焊接损伤、火焰和潮湿具有很高的抵抗力。 6. 应用信息:适用于工程项目、教育科学项目、线圈绕制和电子应用。 7. 封装信息:提供多种线规(16至30 AWG)、多种颜色以及多种卷筒尺寸(从25英尺到5000英尺)。
28STRPTFEKIT10COLOR100 价格&库存
很抱歉,暂时无法提供与“28STRPTFEKIT10COLOR100”相匹配的价格&库存,您可以联系我们找货
