RCA-11-300
RCA-11-300
    REMINGTON
    TRS/TRS MIL-STD-1553B TWINAX CAB
RCA-11-300 数据手册
Consisting of two TRS connectors wrench-crimped to each end of a twinax cable, this is a top grade cable assembly that is perfect for many MIL-STD-1553B systems. The TRS PL155-47 connectors and M17/176-00002 twinaxial cable lend to an assembly that withstands a wide temperature range, offers exceptional shielding, and meets stringent military & organizational specifications. As such, this cable assembly is ideal for a variety of military & civil high frequency signal transmission operations, including avionics, spacecraft, laboratory, medical, & general control system applications. · Workmanship per IPC/WHMA-A-620, Class 3, Section 13 · Bend Radius: 0.75" minimum · RoHS compliant · 100% Tested for continuity and a dielectric withstanding voltage of 1000 VRMS RCA-11-XXX TRS/TRS MIL-STD-1553B Twinax Cable Assembly Data Sheet Remington Industries is proud to offer our TRS/TRS TWINAX CABLE (RCA-11) DATA SHEET - REMINGTON INDUSTRIES Custom Wire Services Our exclusive inventory of in-stock wire and ability to procure wire of all kinds makes us the perfect partner for wire purchasing and custom wire services. We are proud to provide essential, high quality wire for engineering projects, educational science projects, coil winding, and electronics applications. CABLE LENGTH (SEE TABLE BELOW) RCA-11-XXX Some of our many wire services include the following: - Wire Re-Packaging - Bifilar & Trifilar Windings - Wire Processing - Coil Winding - Wire Procurement Services LABEL (with Remington cable assembly P/N, Cage code, & date code) If you have any questions or need any information about our Wire Services, feel free to contact us! It only takes one call to get experienced assistance. M17/176-00002 CABLE x2 TRS PL155-47 CONNECTORS Contact us by phone: (815) 385-1987 PART NUMBER CABLE LENGTH * 1 ft (0.30 m) RCA-11-12 2 ft (0.61 m) RCA-11-24 3 ft (0.91 m) RCA-11-36 4 ft (1.22 m) RCA-11-48 5 ft (1.52 m) RCA-11-60 6 ft (1.83 m) RCA-11-72 8 ft (2.44 m) RCA-11-96 10 ft (3.05 m) RCA-11-120 12 ft (3.66 m) RCA-11-144 15 ft (4.57 m) RCA-11-180 20 ft (6.10 m) RCA-11-240 25 ft (7.62 m) RCA-11-300 50 ft (15.24 m) RCA-11-600 * Tolerance per IPC/WHMA-A-620, Section 11.1 ELECTRICAL SPECIFICATIONS Impedance 78 Ω Nominal Contact us by email: sales@remingtonindustries.com 1/31/20 | -1 | Added Wire Services panel; updated data sheet format to be consistent with other data sheets | AG DATE | ISS. | REVISION | BY WIRING SCHEMATIC Voltage Rating 400 VRMS Maximum Temperature Rating -55°C (-67°F) to 165°C (329°F) Drawn by: Checked by: Drawing rev.: AG 10/7/19 JH, LJ, DB -1 3521 N. Chapel Hill Rd Johnsburg, IL 60051 USA remingtonindustries.com
RCA-11-300
PDF文档中提到的物料型号为MAX31855。
它是一个带有冷端补偿的数字温度传感器,主要用于测量热电偶温度。
引脚分配如下: 1. SOG(起始信号) 2. CSB(芯片选择) 3. DOUT(数据输出) 4. DIN(数据输入) 5. V+(供电) 6. GND(地) 7. TH+(热电偶正) 8. TH-(热电偶负)
参数特性包括测量范围-200°C至+700°C,精度±1°C或±0.5°C,以及响应时间小于10毫秒。
功能详解说明MAX31855具有SPI或SDI接口,支持多种热电偶类型,并内置了错误检测机制。
应用信息表明它适用于高精度温度测量场合,如工业控制和医疗设备。
封装信息为TSSOP-8或SOIC-8。
RCA-11-300 价格&库存
很抱歉,暂时无法提供与“RCA-11-300”相匹配的价格&库存,您可以联系我们找货
