0.25X0.50FLT304SS-12
    REMINGTON
    1/4X1/2 304 STNLSS STL FLT 12"L
0.25X0.50FLT304SS-12 数据手册
Remington Industries is a proud supplier of 304 Stainless Steel Mill Stock Flat Bars and Round Rods. Stainless Steel 304 is a general-purpose steel alloy that can be easily welded or formed. It has a high resistance to heat & corrosion, and it responds well to hardening by cold working. Made up of 8 percent nickel and 18 percent chromium, it possesses great oxidation resistance even when used in temperatures up to 871°C (1600°F). This 304 stainless steel meets ASTM A276 specifications. STAINLESS STEEL 304 BAR & ROD DATA SHEET - REMINGTON INDUSTRIES We offer stainless steel bars and rods in many different sizes; take a look at our selection using the charts below. If you can't find a piece of raw material that meets your specifications, feel free to contact Remington Industries to see how we can help you with our Custom Raw Materials Services. · Material: 304 General Purpose Stainless Steel · Specification: ASTM A276 · Available Shapes: · Finish: Unpolished (Mill) - Flat Bar/Plate · Can be hardened by cold working - Round Rod · Great strength & corrosion resistance; easily welded or formed STAINLESS STEEL FLAT BAR STAINLESS STEEL ROUND ROD Stainless Steel Flat Bars & Round Rods Stainless Steel 304 Data Sheet Remington Industries is proud to offer our Custom Raw Materials Services We are proud to offer a range of custom services for raw materials to best meet your needs. With our extensive knowledge of raw materials, experience in the industry, and relevant connections, we can determine product availability and source the materials you need to complete your project. We also offer Value-Added Services for your raw materials: - Cut to Length - CNC Turning & Milling - Grinding - CAD Drawings - Prototyping STAINLESS STEEL FLAT BAR AVAILABLE DIMENSIONS THICKNESS WIDTH STAINLESS STEEL ROUND ROD AVAILABLE DIMENSIONS LENGTH 1" (25.40 mm) 1 1 4" 2" DIAMETER 1 (12.70 mm) 2" (50.80 mm) (6.35 mm) 4" (6.35 mm) 1 2" (12.70 mm) 3 4" (19.05 mm) 4" (101.60 mm) 1" (25.40 mm) 6" (152.40 mm) 1 2" (12.70 mm) LENGTH 1" (25.40 mm) If you have any questions or need any information about our Raw Materials Services, feel free to contact us! It only takes one call to get experienced assistance. Contact us by phone: (815) 385-1987 Contact us by email: sales@remingtonindustries.com 2" (50.80 mm) 4" (101.60 mm) 6" (152.40 mm) 8" (203.20 mm) 1" (25.40 mm) 8" (203.20 mm) 10" (254.00 mm) 1 1 4" (31.75 mm) 10" (254.00 mm) DATE | ISS. | REVISION | BY Drawn by: Drawing rev.: AG 1/31/20 -- 2" (50.80 mm) 12" (304.80 mm) 3" (76.20 mm) 1 1 2" (38.10 mm) 24" (609.60 mm) 1" (25.40 mm) 36" (914.40 mm) 4" (101.60 mm) 48" (1219.20 mm) 12" (304.80 mm) 24" (609.60 mm) 1 3 4" (44.45 mm) 2" (50.80 mm) 36" (914.40 mm) 48" (1219.20 mm) 3521 N. Chapel Hill Rd Johnsburg, IL 60051 USA remingtonindustries.com
0.25X0.50FLT304SS-12 价格&库存
很抱歉,暂时无法提供与“0.25X0.50FLT304SS-12”相匹配的价格&库存,您可以联系我们找货
