14UL1007SLDBLU100
14UL1007SLDBLU100
    REMINGTON
    14 AWG GAUGE UL1007 SOLID HOOK-U
14UL1007SLDBLU100 数据手册
Stranded or Solid UL1007 Hook Up Wire from Remington Industries is used across a variety of engineering and electronics industries. The single or multi conductor wire is made from tinned copper that offers high quality performance for all general-purpose electrical applications, and the PVC insulation protects the wire against abrasion, chemicals, oils, and solvents. By conforming to UL and MIL-spec specifications, the hook up wire provides excellent uniformity for processing, stripping, and terminating. This hook up wire is available in several wire gauges (from 14 to 28 AWG) to meet your specific requirements. It is also available in a variety of colors (see below) to allow for easy circuit identification, as well as numerous spool sizes (see below) for your convenience. UL1007 HOOK UP WIRE DATA SHEET - REMINGTON INDUSTRIES · Conductor Material: Tinned Copper · Insulation Material: PVC (0.016" Thick) · Type: UL1007 Hook Up Wire, Stranded or Solid · Voltage Rating: 300 V · Temperature Rating: 105°C (221°F) · Colors Available: Black, Blue, Brown, Gray, Green, Orange, Red, Violet, White, Yellow · Spool Sizes Available: 25 ft, 100 ft, 250 ft, 500 ft, 1000 ft, 2500 ft, 5000 ft · Also available in pre-built kits (6 or 10 different colors / 25 ft or 100 ft per spool) OVERALL DIAMETER STRANDED WIRE DIAMETER 14UL1007STR 14UL1007SLD 16UL1007STR 16UL1007SLD 18UL1007STR 18UL1007SLD 20UL1007STR 20UL1007SLD 22UL1007STR 22UL1007SLD 24UL1007STR 24UL1007SLD 26UL1007STR 26UL1007SLD 28UL1007STR 28UL1007SLD WIRE GAUGE 14 AWG 16 AWG 18 AWG 20 AWG 22 AWG 24 AWG 26 AWG 28 AWG STRANDING 41/30 Solid 26/30 Solid 16/30 Solid 10/30 Solid 7/30 Solid 7/32 Solid 7/34 Solid 7/36 Solid WIRE DIAMETER 0.0641" 0.0508" 0.0403" 0.0320" 0.0254" 0.0201" 0.0190" 0.0126" Stranded or Solid Data Sheet Remington Industries is proud to offer our Custom Wire Services Our exclusive inventory of in-stock wire and ability to procure wire of all kinds makes us the perfect partner for wire purchasing and custom wire services. We are proud to provide essential, high quality wire for engineering projects, educational science projects, coil winding, and electronics applications. Some of our many wire services include the following: - Wire Re-Packaging - Bifilar & Trifilar Windings - Wire Processing - Coil Winding - Wire Procurement Services SOLID PART NUMBER UL1007 Hook Up Wire 0.105" If you have any questions or need any information about our Wire Services, feel free to contact us! It only takes one call to get experienced assistance. 0.097" Contact us by phone: (815) 385-1987 0.094" Contact us by email: sales@remingtonindustries.com OVERALL DIAMETER 0.083" 0.080" 0.073" 0.070" 0.064" 0.062" DATE | ISS. | REVISION | BY Drawn by: Drawing rev.: AG 1/27/20 -- 0.058" 0.056" 0.053" 0.050" 0.050" 0.046" 0.046" 3521 N. Chapel Hill Rd Johnsburg, IL 60051 USA remingtonindustries.com
14UL1007SLDBLU100
1. 物料型号:文档列出了不同线规(AWG)的UL1007钩线,包括14至28 AWG,分为绞合线(Stranded)和实心线(Solid)两种类型。
2. 器件简介:UL1007钩线由Remington Industries生产,适用于各种工程和电子行业。这种单根或多根导体线由镀锡铜制成,提供高质量的性能,适用于所有通用电气应用。PVC绝缘材料保护电线免受磨损、化学物质、油脂和溶剂的侵害。
3. 引脚分配:文档中没有提及引脚分配,因为它是关于电线而非电子元件的。
4. 参数特性: - 温度等级:105°C(221°F) - 颜色选择:黑色、蓝色、棕色、灰色、绿色、橙色、红色、紫罗兰色、白色、黄色 - 绝缘厚度:0.016英寸 - 电压等级:300V
5. 功能详解:UL1007钩线符合UL和MIL规格,提供出色的一致性,便于加工、剥离和终止。它提供多种线规和颜色,以满足特定要求,并允许轻松的电路识别。
6. 应用信息:适用于工程项目、教育科学项目、线圈绕制和电子应用。
7. 封装信息:提供多种卷筒尺寸,包括25英尺、100英尺、250英尺、500英尺、1000英尺、2500英尺和5000英尺。还提供预制套件,包含6或10种不同颜色的线,每种颜色25英尺或100英尺。
8. 定制服务:Remington Industries提供定制电线服务,包括重新包装、双线和三线绕制、电线加工、线圈绕制和电线采购服务。
9. 联系方式:可以通过电话(815) 385-1987或电子邮件sales@remingtonindustries.com联系Remington Industries。
14UL1007SLDBLU100 价格&库存
很抱歉,暂时无法提供与“14UL1007SLDBLU100”相匹配的价格&库存,您可以联系我们找货
