22UL1015STRWHI25
22UL1015STRWHI25
    REMINGTON
    HOOKUP STRND 22AWG 600V WHT 25
22UL1015STRWHI25 数据手册
Stranded UL1015 Hook Up Wire from Remington Industries is used across a variety of engineering and electronics industries. The multi conductor wire is made from tinned copper that offers high quality performance for all general-purpose electrical applications, and the PVC insulation protects the wire against abrasion, chemicals, oils, and solvents. By conforming to UL and MIL-spec specifications, the hook up wire provides excellent uniformity for processing, stripping, and terminating. This hook up wire is available in several wire gauges (from 14 to 24 AWG) to meet your specific requirements. It is also available in a variety of colors (see below) to allow for easy circuit identification, as well as numerous spool sizes (see below) for your convenience. UL1015 HOOK UP WIRE DATA SHEET - REMINGTON INDUSTRIES · Conductor Material: Tinned Copper · Insulation Material: PVC (0.030" Thick) · Type: UL1015 Hook Up Wire, Stranded · Voltage Rating: 600 V · Temperature Rating: 105°C (221°F) · Colors Available: Black, Blue, Brown, Gray, Green, Orange, Red, Violet, White, Yellow · Spool Sizes Available: 25 ft, 100 ft, 250 ft, 500 ft, 1000 ft, 2500 ft, 5000 ft · Also available in pre-built kits (6 or 10 different colors / 25 ft or 100 ft per spool) OVERALL DIAMETER STRANDED UL1015 Hook Up Wire Stranded Data Sheet Remington Industries is proud to offer our Custom Wire Services Our exclusive inventory of in-stock wire and ability to procure wire of all kinds makes us the perfect partner for wire purchasing and custom wire services. We are proud to provide essential, high quality wire for engineering projects, educational science projects, coil winding, and electronics applications. Some of our many wire services include the following: - Wire Re-Packaging - Bifilar & Trifilar Windings - Wire Processing - Coil Winding - Wire Procurement Services WIRE DIAMETER PART NUMBER WIRE GAUGE STRANDING WIRE DIAMETER OVERALL DIAMETER 14UL1015STR 14 AWG 41/30 0.0641" 0.141" If you have any questions or need any information about our Wire Services, feel free to contact us! It only takes one call to get experienced assistance. Contact us by phone: (815) 385-1987 Contact us by email: sales@remingtonindustries.com 16UL1015STR 16 AWG 26/30 0.0508" 0.124" 18UL1015STR 18 AWG 16/30 0.0403" 0.110" DATE | ISS. | REVISION | BY 20UL1015STR 20 AWG 10/30 0.0320" 0.100" 22UL1015STR 22 AWG 7/30 0.0254" 0.095" 24UL1015STR 24 AWG 7/32 0.0201" 0.088" Drawn by: Drawing rev.: AG 1/28/20 -- 3521 N. Chapel Hill Rd Johnsburg, IL 60051 USA remingtonindustries.com
22UL1015STRWHI25
1. 物料型号:文档列出了不同线规的型号,如14UL1015STR、16UL1015STR等,覆盖从14 AWG到24 AWG的线规。
2. 器件简介:UL1015型绞合线由镀锡铜制成,具有PVC绝缘层,适用于各种工程和电子行业的通用电气应用。它符合UL和MIL规格标准,提供加工、剥离和终止的一致性。
3. 引脚分配:文档中没有提及引脚分配,因为它是关于电线而非电子元件。
4. 参数特性: - 温度等级:105°C - 可提供颜色:黑色、蓝色、棕色、灰色、绿色、橙色、红色、紫罗兰色、白色、黄色 - 卷筒尺寸:25英尺、100英尺、250英尺、500英尺、1000英尺、2500英尺、5000英尺 - 导体材料:镀锡铜 - 绝缘材料:PVC(0.030英寸厚) - 额定电压:600V
5. 功能详解:文档强调了电线的多功能性,适用于工程项目、教育科学项目、线圈绕制和电子应用。
6. 应用信息:Remington Industries提供定制电线服务,包括电线重新包装、双线和三线绕制、电线加工、线圈绕制和电线采购服务。
7. 封装信息:文档提供了不同线规的绞合线直径和整体直径数据。
8. 联系方式:提供了Remington Industries的联系电话和电子邮件地址。
22UL1015STRWHI25 价格&库存
很抱歉,暂时无法提供与“22UL1015STRWHI25”相匹配的价格&库存,您可以联系我们找货
