MDD2-250-10
MDD2-250-10
    REMINGTON
    QUICK CONNECT TERMINALS, MALE, P
MDD2-250-10 数据手册
WIRE TERMINALS DATA SHEET - REMINGTON INDUSTRIES Wire Terminals Wire terminals are used to easily connect wires to screws, posts, and other terminals/wires. They are available in a variety of wire gauges and connection types. Remington Industries offers a wide variety of wire terminals to help you make clean, convenient terminations between wires in your project; take a look at the chart below to see what we offer. The tin-plated copper or brass base of these terminals provides good electrical connectivity while also allowing for a quick, solderless crimp connection. Additionally, on insulated terminals, PVC insulation protects the connection against abrasion, chemicals, oils, fuels, and solvents. Fork, Ring, Butt, Quick Connect, & Lug Our wire terminals are available in different wire sizes (see table below) and sometimes varying stud sizes (see table below). We also offer the terminals in packages of 10 pieces or 100 pieces for your convenience. Remington Industries is also glad to provide Custom Wire Services: We can find and add most wire terminals to a wire/cable of your choice so that it is ready for your project straight out of the box. Feel free to contact Remington Industries if you would like our assistance. · See table below for specifications by terminal type · Package Quantities Available: x10 pieces or x100 pieces · Termination Type: Crimp Remington Industries is proud to offer our Data Sheet Custom Wire Services Our exclusive inventory of in-stock wire and ability to procure wire of all kinds makes us the perfect partner for wire purchasing and custom wire services. We are proud to provide essential, high quality wire for engineering projects, educational science projects, coil winding, and electronics applications. Some of our many wire services include the following: - Wire Re-Packaging - Bifilar & Trifilar Windings - Wire Processing - Coil Winding - Wire Procurement Services FORK TERMINAL RING TERMINAL QUICK CONNECT (MALE) TERMINAL QUICK CONNECT (FEMALE) TERMINAL BUTT TERMINAL If you have any questions or need any information about our Wire Services, feel free to contact us! It only takes one call to get experienced assistance. Contact us by phone: (815) 385-1987 PART NUMBER TERMINAL TYPE WIRE SIZE CURRENT RATING TEMPERATURE RATING STUD SIZES AVAILABLE TERMINAL MATERIAL INSULATION MATERIAL SVS2 Fork 14 to 16 AWG 27 A 75°C (167°F) #6, #8, #10 Tin-Plated Copper Blue PVC 19 A 75°C (167°F) #6, #8, #10 Tin-Plated Copper Red PVC #6, #8, #10 Tin-Plated Copper Blue PVC SVS1.25 Fork RVS2 Ring 14 to 16 AWG 27 A 75°C (167°F) RVS1.25 Ring 16 to 22 AWG 19 A 75°C (167°F) #6, #8, #10 Tin-Plated Copper Red PVC BV2 Butt / Splice 14 to 16 AWG 27 A 75°C (167°F) N/A Tin-Plated Copper Blue PVC BV1.25 Butt / Splice 16 to 22 AWG 19 A 75°C (167°F) N/A Tin-Plated Copper Red PVC MDD2-250 Quick Connect, Male 14 to 16 AWG 15 A 75°C (167°F) N/A Tin-Plated Brass Blue PVC MDD1.25-250 Quick Connect, Male 16 to 22 AWG 10 A 75°C (167°F) N/A Tin-Plated Brass Red PVC FDD2-250 Quick Connect, Female 14 to 16 AWG 15 A 75°C (167°F) N/A Tin-Plated Brass Blue PVC FDD1.25-250 Quick Connect, Female 16 to 22 AWG 10 A 75°C (167°F) N/A Tin-Plated Brass Red PVC 16 to 22 AWG SC35 Lug 2 AWG 36 A 160°C (320°F) 5 SC25 Lug 4 AWG 36 A 160°C (320°F) 5 3 16", 8" Tin-Plated Copper None 3 16", 8" Tin-Plated Copper None Contact us by email: sales@remingtonindustries.com DATE | ISS. | REVISION | BY Drawn by: Drawing rev.: AG 1/31/20 -- 3521 N. Chapel Hill Rd Johnsburg, IL 60051 USA remingtonindustries.com
MDD2-250-10
物料型号:包括Fork Terminal(叉形端子)、Ring Terminal(环形端子)、Butt/Splice Terminal(直通/搭接端子)、Quick Connect Terminal(快速连接端子)和Lug(端子)。
器件简介:这些线端用于方便地将电线连接到螺丝、柱子和其他端子/电线上。它们提供多种线规和连接类型。
引脚分配:文档中没有明确提到引脚分配,但提供了不同端子类型和适用的线规。
参数特性:包括电流额定值和温度额定值。例如,SVS2型号的Fork Terminal适用于14至16AWG线规,电流额定值为27A,温度额定值为75°C。
功能详解:端子的基座采用镀锡铜或黄铜材料,提供良好的电气连接性,并允许快速、无需焊接的压接连接。绝缘端子采用PVC绝缘材料,保护连接免受磨损、化学物质、油脂、燃料和溶剂的侵害。
应用信息:Remington Industries提供Custom Wire Services,可以为各种工程、教育科学项目、线圈绕制和电子应用提供必要的、高质量的电线。
封装信息:端子的包装数量有x10件或x100件。例如,SC35和SC25型号的Lug端子分别适用于2AWG和4AWG线规,电流额定值为36A,温度额定值为160°C,没有绝缘材料。
MDD2-250-10 价格&库存
很抱歉,暂时无法提供与“MDD2-250-10”相匹配的价格&库存,您可以联系我们找货
