R3112N201A-TR-FE
R3112N201A-TR-FE
    NISSHINBO(日清纺)
    SC-74A,SOT-753
    监控器 开路漏极或开路集电极 1 通道 SOT-23-5
R3112N201A-TR-FE 数据手册
*R3112Qxx2 (SC-88A) is the discontinued product as of March 2019. R3112x SERIES LOW VOLTAGE DETECTOR WITH OUTPUT DELAY NO. EA-087-160310 OUTLINE The R3112x Series are CMOS-based voltage detector ICs with high detector threshold accuracy and ultra-low supply current, which can be operated at an extremely low voltage and is used for system reset as an example. Each of these ICs consists of a voltage reference unit, a comparator, resistor net for detector threshold setting, an output driver, a hysteresis circuit, and an output delay circuit. The detector threshold is fixed with high accuracy internally and does not require any adjustment. Two output types, Nch open drain type and CMOS type are available. Three types of packages, SOT-23-5, small SC-82AB, SC-88A and ultra-small SON1612-6 can be selected so that high density mounting on boards is possible. FEATURES         Built-in Output Delay Circuit ............................................... Typ. 100ms with an external capacitor: 0.022F Supply Current ................................................................... Typ. 0.5A (R3112x27xA/C, VDD2.6V) Operating Voltage .............................................................. 0.7 to 6.0V (Topt25C) Detector Threshold............................................................. 0.9V to 5.0V (0.1V steps) Detector Threshold Accuracy ............................................. 2.0% Temperature-Drift Coefficient of Detector Threshold ............Typ. 100ppm/C Output Types ...................................................................... Nch Open Drain and CMOS Packages ........................................................................... SON1612-6, SC-82AB, SC-88A, SOT-23-5 APPLICATIONS       CPU and Logic Circuit Reset Battery Checker Window Comparator Wave Shaping Circuit Battery Back-up Circuit Power Failure Detector 1 *R3112Qxx2 (SC-88A) is the discontinued product as of March 2019. R3112x BLOCK DIAGRAMS R3112xxxxA R3112xxxxC OUT VDD VDD RD RD + + - - OUT Vref Vref GND GND CD CD SELECTION GUIDE The package type, the detector threshold, and the output type for the ICs can be selected at the users’ request. Product Name Package Quantity per Reel Pb Free Halogen Free R3112Dxx1-TR-FE SON1612-6 4,000 pcs Yes Yes R3112Qxx1-TR-FE SC-82AB 3,000 pcs Yes Yes R3112Qxx2-TR-FE SC-88A 3,000 pcs Yes Yes R3112Nxx1-TR-FE SOT-23-5 3,000 pcs Yes Yes xx : The detector threshold can be designated in the range from 0.9V(09) to 5.0V(50) in 0.1V steps.  : Designation of Output Type (A) Nch Open Drain (C) CMOS 2 *R3112Qxx2 (SC-88A) is the discontinued product as of March 2019. R3112x PIN CONFIGURATION  SON1612-6 6 5 4 4 (mark side) 1 2  SC-82AB 3  SC-88A 5 (mark side) (mark side) 3 1 2 4 1 2 3  SOT-23-5 5 4 (mark side) 1 2 3 PIN DESCRIPTION     SON1612-6 Pin No Symbol Pin Description 1 OUT Output Pin (Output "L" at detection) 2 GND Ground Pin 3 CD Pin for External Capacitor (for setting output delay) 4 NC No Connection 5 GND 6 VDD Ground Pin Voltage Supply Pin SC-82AB Pin No Symbol 1 VDD 2 GND 3 CD 4 OUT Pin Description Voltage Supply Pin Ground Pin Pin for External Capacitor (for setting output delay) Output Pin (Output "L" at detection) SC-88A Pin No Symbol Pin Description 1 VDD Voltage Supply Pin 2 NC No Connection 3 GND 4 CD 5 OUT Ground Pin Pin for External Capacitor (for setting output delay) Output Pin (Output "L" at detection) SOT-23-5 Pin No Symbol Pin Description 1 OUT Output Pin (Output "L" at detection) 2 VDD Voltage Supply Pin 3 GND 4 NC No Connection 5 CD Pin for External Capacitor (for setting output delay) Ground Pin 3 *R3112Qxx2 (SC-88A) is the discontinued product as of March 2019. R3112x ABSOLUTE MAXIMUM RATINGS Symbol VDD VOUT IOUT Item Rating Unit 6.5 V VSS0.3 to VDD0.3 V VSS0.3 to 6.5 20 V Supply Voltage Output Voltage (CMOS) Output Voltage (Nch) Output Current  PD Power Dissipation (SON1612-6) 500 Power Dissipation (SC-82AB) 380  mA mW Power Dissipation (SC-88A) 380 Power Dissipation (SOT-23-5) 420 Topt Operating Temperature Range 40 to 85 C Tstg Storage Temperature Range 55 to 125 C  ) For Power Dissipation, please refer to PACKAGE INFORMATION. ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. RECOMMENDED OPERATING CONDITIONS (ELECTRICAL CHARACTERISTICS) All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. 4 *R3112Qxx2 (SC-88A) is the discontinued product as of March 2019. R3112x ELECTRICAL CHARACTERISTICS  Topt25C R3112xxxxA/C Symbol Item -VDET Detector Threshold VHYS Detector Threshold Hysteresis Conditions -VDET
R3112N201A-TR-FE
物料型号:R3112x系列,包括R3112xxxxA和R3112xxxxC两种型号,分别代表Nch开漏型和CMOS型输出。
器件简介:R3112x系列是CMOS基础的电压检测集成电路,具有高精度的检测阈值和超低的供电电流,适用于系统重置等应用。
引脚分配: - SON1612-6:1-OUT,2-GND,3-Co,4-NC,5-GND,6-VDD - SC-82AB:1-VoD,2-GND,3-CD,4-OUT - SC-88A:1-VoD,2-NC,3-GND,4-Co,5-OUT - SOT-23-5:1-OUT,2-VoD,3-GND,4-NC,5-CD
参数特性: - 内置输出延迟电路,典型值100ms(与外部电容0.022μF配合) - 供电电流典型值0.5μA(R3112x27xA/C,VDD=2.6V) - 工作电压0.7至6.0V - 检测阈值0.9V至5.0V,步进0.1V - 检测阈值精度±2.0% - 检测阈值温度漂移系数典型值±100ppm/°C
功能详解:包括电压参考单元、比较器、用于设置检测阈值的电阻网络、输出驱动器、滞后电路和输出延迟电路。
应用信息:适用于CPU和逻辑电路重置、电池检查器、窗口比较器、波形整形电路、电池备份电路和电源故障检测器等。
封装信息:提供三种封装类型,SOT-23-5、小型SC-82AB、SC-88A和超小型SON1612-6,以实现高密度板载。
R3112N201A-TR-FE 价格&库存
很抱歉,暂时无法提供与“R3112N201A-TR-FE”相匹配的价格&库存,您可以联系我们找货
R3112N201A-TR-FE
  • 3000+2.088543000+0.27021
  • 6000+2.032946000+0.26302
  • 9000+2.005109000+0.25942
  • 15000+1.9742615000+0.25543
  • 21000+1.9562321000+0.25309
  • 30000+1.9389030000+0.25085
库存:26395
R3112N201A-TR-FE
  • 1+4.770951+0.61725
  • 10+3.3364610+0.43166
  • 25+2.9799825+0.38554
  • 100+2.59062100+0.33517
  • 250+2.40576250+0.31125
  • 500+2.29401500+0.29679
  • 1000+2.202131000+0.28491
库存:26395
