RB-LYN-870
RB-LYN-870
    LYNXMOTION
    HQUAD500 DRONE HARDWARE
RB-LYN-870 数据手册
Description  ● ● ● ● HQuad500 Frame and mounting hardware Tube and clamp design that allows for modularity Strong but lightweight construction at 383g for the assembly Requires: electronics, motors, propellers, battery The Lynxmotion HQuad500 Drone (Hardware Only) is a 500mm quadcopter built using the new Lynxmotion M.E.S. (MultiRotor Erector Set) system. The design uses our new aluminum clamps along with 16mm carbon fiber tubes. This combination of parts allows the frame to be: ● ● ● ● Incredibly rigid (minimal flexing) Versatile (Integrated mounting for upgrades) Lightweight (use of composites and Aluminum) Modular (change the frame / use different length tubes) We equipped the HQuad500 with a camera plate up front which is removable. Different plates will be available as well as a stabilized gimbal system. The flight controller mounting is located at the "dead center" of the frame with slots accommodating 30.5mm to 45mm mounting. The frame is compatible with the ​Lynxmotion Quadrino Nano Flight Controller​ (not included) with a section designed for the GPS antenna and access to the underside ports. There are integrated mounting plates for the ESCs which allow for easy access. What's Included  ● ● ● ● ● ● ● ● ● ● ● HQuad500 Hardware, which includes: 1x Center body (three plates) 4x Motor Mount (top and bottom) 4x Tip landing gear 4x Tip cover plate 4x ESC mounting plate 1x Camera plate 8x ​16mm Aluminum Clamps (2 per pack) 4x ​Carbon Fiber tube (16x14x220mm) 1x HQuad500 Hardware Bag 2x ​Lynxmotion battery strap Useful Links  PDF File ● User Guide Dimensions
RB-LYN-870 价格&库存
很抱歉,暂时无法提供与“RB-LYN-870”相匹配的价格&库存,您可以联系我们找货
