RB-LYN-976
RB-LYN-976
    LYNXMOTION
    MES POWER DISTRIBUTION BOARD
RB-LYN-976 数据手册
Description  ● ● ● Lynxmotion MES Power Distribution Board (PDB) for UAV Continuous current of 20A per motor (160A total for 8 motors) Pinout compatible with the ​Lynxmotion Quadrino Nano Drone/UAV Flight Controller (with GPS)​ (or with any multirotor system) ● ● ● Jumpers for BEC power management, battery monitoring and external device power selection Supports single or dual batteries setup On-board internally driven buzzer The Lynxmotion MES Power Distribution Board (PDB) for UAV is a highly versatile system; its two PCB design (separate positive and negative power planes), 4oz copper thickness and two battery inputs, allows it to easily power up to 8 UAV motors with a continuous current capacity of 20 amps each (160A total) and a peak / instantaneous current capacity of 35A per motor (280A total). This PDB has also an onboard, internally driven buzzer and a pinout directly compatible with the Quadrino Nano Flight Controller with ​this wiring harness​ . When connected to the Quadrino Nano, the MES-PDB will allow the user to gain Audible and as an option Visual (if a LED is connected) feedback for Battery Monitoring as well as other MultiWii functions. Note: Lynxmotion Quadrino Nano is not included. Features  ● Pinout compatible with the Lynxmotion Quadrino Nano Flight Controller, but can be used in any multirotor system ● ● ● ● ● ● Connect up to 8x motors using 3.5mm bullet connectors Positive and negative PCBs allow for high current Supports single or dual batteries setup Includes 1x XT60 to 3.5mm bullet connector battery cable adapter (additional cables sold separately). On-board internally driven buzzer Jumpers for battery elimination circuit (BEC) power management, battery monitoring and external device power selection ● Vin, GND and 5V pins broken out for the possibility of soldering an external 5V regulator Specifications  ● ● ● Continuous current of 20A per motor (160A total for 8 motors) Peak current of 35A (280A total for 8 motors) for several seconds Separate power PCBs : bottom PCB is connected to battery positive and top PCB is connected to battery negative ● ● 4oz copper thickness on both top and bottom PCBs 8 x 3.5mm male bullet connectors for ESCs positive leads + 2 x 3.5mm male bullet connectors for batteries positive leads ● 8 x 3.5mm female bullet connectors for ESCs negative leads + 2 x 3.5mm female bullet connectors for batteries negative leads ● On-board pre-amplified Buzzer : 5V 30mA 2.7kHz internally driven magnetic buzzer What's Included  ● ● ● ● ● ● 1 x MES-PDB assembled PCB 2 x Adhesive foam cover 1 x XT60 battery harness 150mm 10 x 3.5mm female bullet connectors 10 x 3.5mm male bullet connectors 20 x Shrink tube Useful Links  Website ● ZIP File Lynxmotion Website - Home ● Lynxmotion MES Power Distribution Board (PDB) for UAV - 3D Files ● ● Lynxmotion Wiki - Home Wiki Lynxmotion Wiki - MES Power Distribution Board (PDB) Dimensions
RB-LYN-976 价格&库存
很抱歉,暂时无法提供与“RB-LYN-976”相匹配的价格&库存,您可以联系我们找货
