05K1P4-S00S3
05K1P4-S00S3
    ROSENBERGER
    PRECISION N TYPE ADAPTER
05K1P4-S00S3 数据手册
TECHNICAL DATA SHEET ADAPTOR RPC-N 50 : JACK – RPC-SL PLUG 05K1P4-S00S3 All dimensions are in mm; tolerances according to ISO 2768 m-H Interface RPC-N according to RPC-SL IEC 60169-16 ; CECC 22 210 ; MIL-STD 348A/402 Interchangeable port connector system Documents N/A Material and plating RF_35/12.04/3.0 Connector parts Center contact Outer contact RPC-N Outer contact RPC-SL Coupling nut Dielectric Material Beryllium copper Stainless steel Stainless steel Stainless steel PPE Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating Gold, min. 1.27 μm, over chemical nickel Passivated Gold, 0.1 μm min. Passivated Tel.: +49 8684 18-0 Fax: +49 8684 18-499 email: info@rosenberger.de Page 1/2 TECHNICAL DATA SHEET ADAPTOR RPC-N 50 : JACK – RPC-SL PLUG 05K1P4-S00S3 Electrical data Impedance Frequency Return loss 50 : DC to 18 GHz t 21 dB, DC to 18 GHz Insertion loss Insulation resistance Center contact resistance RPC-N Outer contact resistance RPC-N Center contact resistance RPC-SL Outer contact resistance RPC-SL Test voltage Working voltage RF-leakage d 0.05 x f(GHz) dB t 5 G: d 1.0 m: d 1.0 m: d 3.0 m: d 2.0 m: 750 V rms 250 V rms t 90 dB up to 1 GHz Mechanical data Mating cycles RPC-N Mating cycles RPC-SL Center contact captivation Coupling test torque RPC-N Recommended torque RPC-N Recommended torque RPC-SL t 500 t 3000 t 28 N 1.70 Nm 0.70 Nm to 1.10 Nm 2 Nm Environmental data Temperature range Thermal shock Corrosion Vibration Shock Moisture resistance 2002/95/EC (RoHS) -40°C to +85°C IEC 61169-1, Subclause IEC 61169-1, Subclause IEC 61169-1, Subclause IEC 61169-1, Subclause IEC 61169-1, Subclause compliant 9.4.4 9.4.6 9.3.3 9.3.14 9.4.3 Tooling N/A Suitable cables N/A Packing Standard Weight 1 pce in box 33.4 g/pce RF_35/12.04/3.0 While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date Herbert Babinger 02/08/04 H. Babinger 08.02.07 c00 07-0101 B. Dandl 08.02.07 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel.: +49 8684 18-0 Fax: +49 8684 18-499 email: info@rosenberger.de Page 2/2
05K1P4-S00S3 价格&库存
很抱歉,暂时无法提供与“05K1P4-S00S3”相匹配的价格&库存,您可以联系我们找货
