09K721-40MS3
09K721-40MS3
    ROSENBERGER
    2.4mm(APC-2.4,OS-50) 连接器 插孔,母形插口 面板安装 压缩
09K721-40MS3 数据手册
Technical Data Sheet Straight Jack PCB RF_35/05.10/6.1 Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG RPC-2.40 09K721-40MS3 Economic Solderless Connector All dimensions are in mm; tolerances according to ISO 2768 m-H Interface According to Mechanically compatible with IEC 61169-40 RPC-1.85 Documents PCB Layout B 594 Material and plating Connector parts Center contact Outer contact Dielectric Material CuBe Stainless steel PTFE Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating Gold, min. 1.27 µm, over chemical nickel Passivated Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 1/2 Technical Data Sheet Straight Jack PCB RPC-2.40 09K721-40MS3 Economic Solderless Connector RF_35/05.10/6.1 Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG Electrical data Impedance Frequency Return loss 50  DC to 50 GHz  26 dB, DC to 26.5 GHz  21 dB, 26.5 GHz to 40 GHz  17.5 dB, 40 GHz to 50 GHz Insertion loss Insulation resistance Center contact resistance Outer contact resistance Test voltage Working voltage  0.05 x f(GHz) dB  5 G  4.0 m  2.5 m 500 V rms 150 V rms - Connector only, VSWR in application depends decisive on PCB layout - Mechanical data Mating cycles Mating Force PCB side Center contact captivation: axial Coupling test torque Recommended torque  500  23 N  20 N 1.65 Nm 0.80 Nm to 1.10 Nm Environmental data Storage temperature range Operating temperature range Thermal shock Corrosion Vibration Shock Moisture resistance RoHS -40°C to +85°C -0°C to +85°C IEC 61169-1, Subclause 9.4.4 IEC 61169-1, Subclause 9.4.6 IEC 61169-1, Subclause 9.3.3 IEC 61169-1, Subclause 9.3.14 IEC 61169-1, Subclause 9.4.3 compliant Accessories Available Screws DIN 7985-H-A2 UNF 0-80 (cylinder head screw) for different PCB thickness. 3/16” length = Standard (already included with the connector) DIN7985-H-A2 UNF 0-80x3/16 1/4” length = Optional (PCB thickness min. 1.2 mm to max. 4.2 mm) DIN7985-H-A2 UNF 0-80x1/4 5/16” length = Optional (PCB thickness min. 2.8 mm to max. 5.7 mm) DIN7985-H-A2 UNF 0-80x5/16 3/8” length = Optional (PCB thickness min. 4.4 mm to max. 7.4 mm) DIN7985-H-A2 UNF 0-80x3/8 7/16” length = Optional (PCB thickness min. 6.0 mm to max. 8.9 mm) DIN7985-H-A2 UNF 0-80x7/16 Tooling N/A Weight 2.3 g/pce While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date Martin Moder 21.01.16 Herbert Babinger 04.06.18 a00 18-s200 N. Topcagic 04.06.18 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 2/2
09K721-40MS3 价格&库存
很抱歉,暂时无法提供与“09K721-40MS3”相匹配的价格&库存,您可以联系我们找货
09K721-40MS3
  • 1+742.590031+96.45868
  • 10+681.3994310+88.51033
  • 25+655.1942925+85.10642
  • 50+633.3532350+82.26937
  • 100+598.41056100+77.73050
库存:2
