Technical Data Sheet
Insert
Mini-Coax
6 Channel Block
Right Angle
23C25G-40ML5
All dimensions are in mm; tolerances according to ISO 2768 m-H
Interface
According to
Rosenberger Mini-Coax
Documents
PCB - Layout
B 501B
Material and plating
Connector parts
Center contact
Outer contact male
Outer contact female
Body
Dielectric
Material
CuBe or equiv.
CuBe
Brass
Brass
PTFE
Rosenberger Hochfrequenztechnik GmbH & Co. KG
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Plating
AuroDur®, gold plated
Tel. : +49 8684 18-0
Email : info@rosenberger.de
Page
1/2
Insert
Mini-Coax
6 Channel Block
Right Angle
23C25G-40ML5
Electrical data
Impedance
Frequency
Return loss
50
DC to 40 GHz
25 dB @ DC to 3 GHz
20 dB @ 3 GHz to 6 GHz
16 dB @ 6 GHz to 20 GHz
12 dB @ 20 GHz to 40 GHz
Insertion loss
0.04 x
Insulation resistance
Center contact resistance
Outer contact resistance
Test voltage (at sea level)
Working voltage (at sea level)
RF-leakage
dB
1G
10 m
3m
750 V rms
500 V rms
80 dB @ DC to 1 GHz
60 dB @ 1 GHz to 4 GHz
- Connector only, VSWR in application depends decisive on PCB layout -
Mechanical data
Mating cycles
Engagement force
Extraction force
500
max. 40 N typical 30 N
max. 45 N typical 30 N
Environmental data
Temperature range
Climatic category
Dry heat
Damp heat
Shock
Max. soldering temperature
RoHS
-40 °C to +125 °C
IEC 60068-2-1 40/85/21
IEC 60068-2-2
IEC 60068-2-78
IEC 60068-2-27 (50g halfsinus, 2 shocks/axis during 11 sec.)
IEC 61760-1, +260 °C for 10 sec.
compliant
Tooling
N/A
Weight
3 g/pce
While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on
our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our
products, we reserve the right to make changes judged to be necessary.
Draft
Date
Approved
Date
Rev.
Engineering change number
Name
Date
Martin Moder
22.11.16
Herbert Babinger
15.03.18
200
17-2028
Andreas Plötz
12.03.18
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Page
2/2
很抱歉,暂时无法提供与“23C25G-40ML5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2382.496521+297.71607
- 10+2025.4721210+253.10240
- 30+1904.6686730+238.00684
